Strugling with ZWave-JS-UI
JuanUil
- Domoticz version: 4.11083
HI all,
I also have struggeld a lot with switching to ZWave-JS-UI.
But now all is working verry well and better then in OZW.
I have made a tutorial to complete install.
For the moment it is only in Dutch and maybe not complete.
Coming time I will translate and update.
you can download it from :
https://mega.nz/file/3JxQ3Y7R#LIFf5wcVo ... KTAX1e5dFA
good luck!
Jan
good luck!
Jan
JuanUil
Re: Strugling with ZWave-JS-UI
The englisch version of the manual can now be found on:
https://mega.nz/file/jQInXCJI#j-uMcnlrX ... YzUippScHs
Enjoy!
Jan
Enjoy!
Jan
- Egregius
- Domoticz version: v2024.7
Could you also add the settings of MQTT hardware in domoticz and those of MQTT/zwave/gateway/homeassistant in zwave-js-ui?
What's the purpose of Open Media Vault?
JuanUil
Will do this week.
OMV is very handy. Docker and portainer are easy to install and you can controll all of your settings of the PI.
sailmich
@JuanUil
I use Rpi 3b and Zstick gen5
I tried to install it according your manual without success. How did you install docker and docker compose? I got docker compose 2.0 and therefore the command to start docker compose changed from docker-compose up to docker compose up. When I start zwavejsui compose in a terminal I got a message WARN Z-WAVE: Z-Wave driver not inited, no port configured. I double checked the path in the docker-compose.yml of the Zstick and it's correct. When I use Openzwave USB within Domoticz Hardware the stick is connected and I can see my zwave devices. I tried it also with /dev/ttyACM0 without success. Seems to me that something wrong with syntax in docker-compose.yml.
Any suggestion?
Any suggestion?
- gizmocuz
I have Docker Compose version v2.14.0
the command is still
did you change the serial port field value?
Do you see any devices when you issue
docker-compose upDo you see any devices when you issue
ls /dev/serial/by-idQuality outlives Quantity!
sailmich
I have docker compose version v2.14.1
ls /dev/serial/by-id deliver usb-0658_0200-if00.
sailmich
This is what I use as my docker-compose.yml file. It's the same like in the manual, seems I have the same device. Is there a need to fill networks: zwave: volumes: zwave-config: ?
- Spoiler: show
- gizmocuz
All my serial devices have something like -port0 behind them
I am missing this in your serial string
Are you use it is not:
/dev/serial/by-id/usb-0658_0200-if00-port0
sailmich
@gizmocuz
I don't have this port0 behind. I double checked with another pi with domoticz already installed, same there.
Openzwave usb Hardware is running on both rpi's. There I have /dev/serial/by-id/usb-0658_0200-if00 in path.
I added /dev/serial/by-id/usb-0658_0200-if00-port0 in docker-compose.yml But also no success.
Off topic? Because I'm desperate I tried installing all as recommended with docker on a new bullsey lite image. I used manual from https://hub.docker.com/r/domoticz/domoticz. docker-compose up -d doesn't work! You have to use docker compose up -d
