I have a problem with switch - when I on-off switch-bulb in Domoticz the relay with Domoticz everything works, but when I use the RF Toggle switch the domoticz light bulb changes as it should, but the relay does not work. Commands - the script inside the switch is executed and I can toggle the switch on/off using, for example, the HTTP command //ip.../cm?cmnd=Power1%20(On or Off). This is some internal domoticz bug? Have any ideas?
log toggle with RF:
Test: Light/Switch (Taras_led)
log with press bulb in Domoticz:
Status: User: Admin (IP...) initiated a switch command (54/Taras_led/On)
