Hi there,
Currently on a project I would need to order a worm gear using a stepper motor is an L293D driver.
For this I have to use an ESP01 (no choice, space available) flash with the Tasmota Basic firmware.
The 1st part went smoothly, flashing the ESP01 with the tasmota firmware.
The second also no problem, part being the installation of the Domoticz system on PC, but it can also be on Raspberry or Linux PC.
The third part is the configuration on the Domoticz server and on the ESP01 and smartphone.
This is where I would need your knowledge and understanding to explain and help me in this task, because this is the first time I have used Domotics.
The idea being to press a button and the motor is triggered with the possibility of the most precise adjustment possible, either in a quarter turn or even less, or in ml/s and/or continuously and that it can stop with an ENDSTOP in both directions.
If it is possible at the same time, it is to know if we can choose to configure options such as the 1st motor then the 2nd, the 3rd, etc. and an option all at the same time.
Is it possible to control for example an esp01 which controls a stepper motor and at the same time a servo motor?
Example the stepper motor by in one direction and at the same time the servomotor by in the opposite direction?
I really have no idea what to order if someone could either tell me a complete tutorial or help me directly I would appreciate it
Thanking you in advance and thank you for your understanding and patience.
Besoin de votre aides esp01 + tasmota + Domoticz
- LaGirafe
- Domoticz version: 2022.2.1
LaGirafe - LaGirafe3Desing
C'est parce que la vitesse de la lumière est supérieure à celle du son que certains paraissent brillants avant d' avoir l' air con.
- Treve
- Domoticz version: v4.11474
Re: Besoin de votre aides esp01 + tasmota + Domoticz
this is a English forum.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- LaGirafe
indeed DSL here I have just rectified
