RFXtrx433 USB 433.92MHz problems
tjabas
Post by tjabas »
Hi!
i have been using my rfxtrx for many years now, but now i have got some issues.
it started a week ago, suddenly i started to get these error messages: Error: RFXCOM: Invalid data received!....
and my sensors and switshes stopped working, and on the hardware page it says version 0, i restarted the RPI and it started working again , but just for some hours, then back to errors in the log,
i tried to switch the usb settings in serial port, and then it started working again, but then died some hours later.
today i got it working again, but some of my remotes werent rekognized, some where.
some sensors suddenly changed id so my old where not updated but in the units menu , where i search after new devices, there they where but with different id,s.
i have tried everything but cant figure it out.
where can i see which version of the rfx harware i have? mabee i need to update it again?
b_weijenberg
Re: RFXtrx433 USB 433.92MHz problems
Post by b_weijenberg »
check with RFXmngr if the RFXtrx performs OK and check the version
RFX-433, RFX-433EMC, RFX-868
tjabas
Post by tjabas »
I have checked and it seems like i har the 433e version, which firmware do i use then?
b_weijenberg
In most cases the latest Pro1 firmware can be used.
See chapter 2.2 in the RFXtrx User Guide for the list of supported protocols in each firmware version
tjabas
Post by tjabas »
thanks, i will look into that.
