custom logs Topic is solved
Patricen
Domoticz version: Beta rel
custom logs
Post by Patricen »
Weather is getting very cold, and I would like to check how does the power (electricity, gas) consumption increases compared to the outside temp decreases.
The custom log shows only temperatures, there is no way to introduce any other analog values.
Would it be possible implementing a general charting that could trace any analog values?
Is there any workaround using domoticz.db?
Domoticz version: 2025.1
Re: custom logs
You can use Dashticz to make custom graphs or you could use the SQLite plugin for Grafana to make custom graphs based on the domoticz db
viewtopic.php?t=35101
