AfterSec(10) gives error
willemdomotica
Post by willemdomotica »
Hi, I am getting this error when using AfterSec(10) in a dzVents scripts execute section
dz.devices('Siren Alarm').switchOff().AfterSec(10)
Error: attempt to call a nil value
The script works perfectly fine when I remove the option 'AfterSec(10)'
The device here is a coolcam siren, which I would like to silence 10 seconds later.
Tried to search for the answer in the dzVents documentation and on the forum, without luck so far.
Would appreciate if anybody can point me in the right direction.
Using:
Version: 2022.2
Build Hash: eea9db734
Compile Date: 2022-11-05 13:05:35
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Oct 31 2022, 14:04:00) [GCC 8.3.0]
willemdomotica
Re: AfterSec(10) gives error
Here is the whole script, in case you wonder:
on = { devices = { 'ZW-Deur_1' } },
logging = { level = domoticz.LOG_INFO, marker = "reset-alarm"} ,
execute = function(dz, device)
local siren = 'Siren Alarm'
if (device.state == 'Off') and (dz.devices(siren).state == 'On') then
	dz.log('Alarm ' .. siren .. ' uitgeschakelen over 5 seconden  ', dz.LOG_INFO)
	dz.devices(siren).switchOff().AfterSec(5)
end -- if
end -- execute function
} -- return
willemd
Domoticz version: 2024.1
Post by willemd »
willemdomotica
I seem to have answered my own question: LUA is case sensitive. hence dzVents is also case sensitive.
This means that the statement above must be correctly written as:
afterSec(5)
HvdW
Domoticz version: 2023.2
Post by HvdW »
Maybe this script can help you.
-- Elektrische deken
The if construct is different.
local Sonof = 'Elektrische deken'
return
    on =
        devices =
            Sonof,
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
        marker = 'Elektrische deken',
    execute = function(dz, item)
        local Sonof = dz.devices(Sonof)
        if item == Sonof and item.active then
            Sonof.switchOff().afterMin(59)
I made it to switch off the electric blanket after one hour.
Bugs bug me.
