Problem getting Zigbee2MQTT working
Posted: Tuesday 29 November 2022 13:48
I've been working for days now to get Zigbee2MQTT working within Domoticz, but so far it hasn't worked.
I followed the wiki for installation (https://www.domoticz.com/wiki/Zigbee2MQTT). Three docker containers are now running with Domoticz, Zigbee2MQTT and Mosquitto. These run in the same docker network so that they can connect to each other.
In Domoticz I have set everything under hardware as stated in the wiki:
To test I created a temperature device. When I send a test message from the Domoticz or Zigbee2MQTT container (with mosquitto_pub -h mosquitto -m '{ "idx" : 184, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in ') it is received by the Mosquitto container. But in Domoticz the temperature device is not updated. It seems that Domoticz is not receiving the message, but I can't find why.
This is the configuration of my docker containers (docker-compose):
Versions of software:
Domoticz: 2022.2
Zigbee2MQTT: 1.28.2 (commit #360a777)
Mosquitto: 2.0.15
Hopefully to get it working eventually...
Thanks for helping out!
version: '3.3'
services:
domoticz:
container_name: domoticz
build:
context: ./_build
restart: unless-stopped
devices:
- "/dev/ttyUSB-RFX433-A:/dev/ttyUSB1"
- "/dev/ttyUSB-SONOFF:/dev/ttyACM0"
ports:
- "8080:8080"
volumes:
- ./domoticz/config:/opt/domoticz/userdata
environment:
- TZ=Europe/Amsterdam
networks:
- domoticz
- proxy
zigbee2mqtt:
container_name: zigbee2mqtt
image: koenkk/zigbee2mqtt
restart: on-failure:2
volumes:
- ./zigbee2mqtt/data/zigbee2mqtt:/app/data
- /run/udev:/run/udev:ro
ports:
- 8081:8081
environment:
- TZ=Europe/Berlin
devices:
- /dev/ttyUSB-SONOFF:/dev/ttyACM0
networks:
- domoticz
depends_on:
- mosquitto
mosquitto:
image: eclipse-mosquitto:2
container_name: mosquitto
volumes:
- ./mosquitto/config:/mosquitto/config
- ./mosquitto/log:/mosquitto/log
- ./mosquitto/data:/mosquitto/data
ports:
- 1883:1883
networks:
- domoticz
networks:
domoticz:
driver: bridge
proxy:
external:
Domoticz: 2022.2
Mosquitto: 2.0.15
