z2mqtt Moes MS-105B dimmer set brightness issue
Posted: Saturday 26 November 2022 22:16
by Kjeld
Hi all
I'm pretty new to domoticz so sorry if I'm not clear with the question or I posted it wrongly.
I have an issue with the Moes MS-105B 2 channel dimmer. Via domoticz I can switch it on and off, it will show the correct brightness however I can't change the brightness. Via MQTT2Zigbee I am able to set the correct brightness. With MQTT explorer I discovered a difference in the messages sent.
MQTT2Zigbee zigbee2mqtt/dimmer/l1= {"brightness":40,"state":"ON"}
via Domoticz it is zigbee2mqtt/dimmer/l1/set= {"brightness":40,"state":"ON"}
How/where can I change the stucture of the message? since it looks I only have to remove set from the path.
Thanks in advance.
Kjeld
I'm running zigbee2mqtt (v1.28.2)/domoticz (2022.2)/ConBee2 on raspberry pi 3 and at the moment mainly placed switches and dimmers to make current lights smart.
Re: z2mqtt Moes MS-105B dimmer set brightness issue
Posted: Saturday 26 November 2022 23:44
by waltervl
Seems to be an issue in Zigbee2mqtt. But how do you connect zigbee2mqtt with Domoticz, by python plugin or MQTT Autodiscover gateway?
Posted: Sunday 27 November 2022 13:46
by Kjeld
I'm using MQTT Auto Discovery Client Gateway with LAN interface.
The reason I thought that it could be related to domoticz is because setting the brightness via Zigbee2MQTT works fine.
Posted: Sunday 27 November 2022 15:42
by waltervl
I know too little from MQTT AD but I believe from zigbee2mqtt to domoticz the state topic is used to send the state of a device. The set topic is used to send de new state to set to zigbee2mqtt that will send it to the device.
Posted: Tuesday 29 November 2022 19:53
by Kjeld
thanks for trying.
From the mqtt log I see
below is mqtt log when changing the brightness correctly to 28 via the zigbee2mqtt frontend
debug 2022-11-27 20:40:26: Received MQTT message on 'zigbee2mqtt/dimmerWoonkamer/set' with data '{"brightness_l1":28}'
debug 2022-11-27 20:40:26: Publishing 'set' 'brightness' to 'dimmerWoonkamer'
below is mqtt log when changing brightness to 61 from domoticz, which fails.
debug 2022-11-27 20:42:37: Received MQTT message on 'zigbee2mqtt/dimmerWoonkamer/l1/set' with data '{"brightness":61,"state":"ON"}'
debug 2022-11-27 20:42:37: Publishing 'set' 'state' to 'dimmerWoonkamer'
So somehow it looks like the message from Domoticz is not what is is supposed to be.
Now I have to find a way of changing it.
Posted: Tuesday 29 November 2022 20:23
by waltervl
And what is zigbee2mqtt log saying if the dimmer is set from Domoticz?
Edit: also check this page:
https://www.zigbee2mqtt.io/devices/MS-105B.html
Posted: Tuesday 29 November 2022 22:03
by GeflapteAppel
Same dimmer, same setup (with autodiscover), same issue.
Domoticz seems to target the first dimmer by encoding `l1` in the device path, while Zigbee2MQTT, when using its frontend, does target the "whole" device and encodes the `l1` dimmer in the brightness property of the data.
Is this some issue with how the device is advertised to domoticz using autodiscover? I also like to know how to fix this
Ps, I did not have this issue when setting the brightness for dimmer + z2m with autodiscover in a Home Assistant setup.
Posted: Tuesday 29 November 2022 23:10
by waltervl
I suppose the Domoticz AD developers have not encountered this type of double chanel device yet. So I would advise to make a GitHub issue with al the data (mqtt discover, config and state payloads) necessary to recreate the device.
Posted: Thursday 01 December 2022 20:22
by GeflapteAppel
waltervl wrote: Tuesday 29 November 2022 23:10
I'll create an issue
Just in the main domoticz repo?
I can see the config and state payloads in MQTT Explorer, but I don't know where to look for the mqtt discover data. Is it the event topic below?
ps, where does
AD devs stand for
topic: homeassistant/light/0x84ba20fffe655423/light_l1/config
"availability": [
"topic": "zigbee2mqtt/bridge/state",
"value_template": "{{ value_json.state }}"
"brightness": true,
"brightness_scale": 254,
"command_topic": "zigbee2mqtt/0x84ba20fffe655423/l1/set",
"device": {
"identifiers": [
"zigbee2mqtt_0x84ba20fffe655423"
"manufacturer": "Moes",
"model": "Smart dimmer module (2 gang) (MS-105B)",
"name": "0x84ba20fffe655423"
"name": "0x84ba20fffe655423 l1",
"schema": "json",
"state_topic": "zigbee2mqtt/0x84ba20fffe655423/l1",
"unique_id": "0x84ba20fffe655423_light_l1_zigbee2mqtt"
topic: zigbee2mqtt/bridge/event
"data": {
"definition": {
"description": "Smart dimmer module (2 gang)",
"exposes": [
"endpoint": "l1",
"features": [
"access": 3,
"description": "On/off state of this light",
"endpoint": "l1",
"name": "state",
"property": "state_l1",
"type": "binary",
"value_off": "OFF",
"value_on": "ON",
"value_toggle": "TOGGLE"
"access": 3,
"description": "Brightness of this light",
"endpoint": "l1",
"name": "brightness",
"property": "brightness_l1",
"type": "numeric",
"value_max": 254,
"value_min": 0
"type": "light"
"endpoint": "l2",
"features": [
"access": 3,
"endpoint": "l2",
"name": "state",
"property": "state_l2",
"type": "binary",
"value_off": "OFF",
"value_on": "ON",
"access": 3,
"endpoint": "l2",
"property": "brightness_l2",
"type": "numeric",
"value_max": 254,
"value_min": 0
"type": "light"
"access": 1,
"description": "Link quality (signal strength)",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "MS-105B",
"options": [],
"supports_ota": false,
"vendor": "Moes"
"friendly_name": "0x84ba20fffe655423",
"ieee_address": "0x84ba20fffe655423",
"status": "successful",
"supported": true
"type": "device_interview"
Posted: Thursday 01 December 2022 20:43
by Kjeld
Glad I'm not the only one with this issue
Great that you will continue with this, I don't feel knowledgeable enough yet to make a ticket with the correct info.
Posted: Thursday 01 December 2022 21:17
by waltervl
AD stands for Autodiscover so a little short for the MQTT Autodiscover gateway implementation.
An issue can be made here
https://github.com/domoticz/domoticz/issues
See also the instructions here:
https://www.domoticz.com/wiki/MQTT#Debu ... er_devices
Posted: Friday 02 December 2022 21:46
by GeflapteAppel
Posted: Sunday 04 December 2022 10:12
by Kjeld
I've tested with MQexplorer and had the same results. But I see it's already been picked up and solved, waiting for the next release.
Posted: Sunday 04 December 2022 10:29
by GeflapteAppel
Kjeld wrote: Sunday 04 December 2022 10:12
If you're on beta, you can now update to the latest version
