z2mqtt Moes MS-105B dimmer set brightness issue
- Domoticz version: 2022.2
Hi all
I'm pretty new to domoticz so sorry if I'm not clear with the question or I posted it wrongly.
I have an issue with the Moes MS-105B 2 channel dimmer. Via domoticz I can switch it on and off, it will show the correct brightness however I can't change the brightness. Via MQTT2Zigbee I am able to set the correct brightness. With MQTT explorer I discovered a difference in the messages sent.
MQTT2Zigbee zigbee2mqtt/dimmer/l1= {"brightness":40,"state":"ON"}
via Domoticz it is zigbee2mqtt/dimmer/l1/set= {"brightness":40,"state":"ON"}
How/where can I change the stucture of the message? since it looks I only have to remove set from the path.
Thanks in advance.
Kjeld
I'm running zigbee2mqtt (v1.28.2)/domoticz (2022.2)/ConBee2 on raspberry pi 3 and at the moment mainly placed switches and dimmers to make current lights smart.
Thanks in advance.
Kjeld
- Domoticz version: 2024.7
Re: z2mqtt Moes MS-105B dimmer set brightness issue
Seems to be an issue in Zigbee2mqtt. But how do you connect zigbee2mqtt with Domoticz, by python plugin or MQTT Autodiscover gateway?
I'm using MQTT Auto Discovery Client Gateway with LAN interface.
The reason I thought that it could be related to domoticz is because setting the brightness via Zigbee2MQTT works fine.
I know too little from MQTT AD but I believe from zigbee2mqtt to domoticz the state topic is used to send the state of a device. The set topic is used to send de new state to set to zigbee2mqtt that will send it to the device.
thanks for trying.
From the mqtt log I see
below is mqtt log when changing the brightness correctly to 28 via the zigbee2mqtt frontend
debug 2022-11-27 20:40:26: Received MQTT message on 'zigbee2mqtt/dimmerWoonkamer/set' with data '{"brightness_l1":28}'
debug 2022-11-27 20:40:26: Publishing 'set' 'brightness' to 'dimmerWoonkamer'
below is mqtt log when changing brightness to 61 from domoticz, which fails.
debug 2022-11-27 20:42:37: Received MQTT message on 'zigbee2mqtt/dimmerWoonkamer/l1/set' with data '{"brightness":61,"state":"ON"}'
debug 2022-11-27 20:42:37: Publishing 'set' 'state' to 'dimmerWoonkamer'
So somehow it looks like the message from Domoticz is not what is is supposed to be.
Now I have to find a way of changing it.
And what is zigbee2mqtt log saying if the dimmer is set from Domoticz?
Edit: also check this page: https://www.zigbee2mqtt.io/devices/MS-105B.html
Same dimmer, same setup (with autodiscover), same issue.
Domoticz seems to target the first dimmer by encoding `l1` in the device path, while Zigbee2MQTT, when using its frontend, does target the "whole" device and encodes the `l1` dimmer in the brightness property of the data.
Is this some issue with how the device is advertised to domoticz using autodiscover? I also like to know how to fix this
Ps, I did not have this issue when setting the brightness for dimmer + z2m with autodiscover in a Home Assistant setup.
I suppose the Domoticz AD developers have not encountered this type of double chanel device yet. So I would advise to make a GitHub issue with al the data (mqtt discover, config and state payloads) necessary to recreate the device.
I'll create an issue
I can see the config and state payloads in MQTT Explorer, but I don't know where to look for the mqtt discover data. Is it the event topic below?
ps, where does AD devs stand for
topic: homeassistant/light/0x84ba20fffe655423/light_l1/config
"availability": [
"topic": "zigbee2mqtt/bridge/state",
"value_template": "{{ value_json.state }}"
"brightness": true,
"brightness_scale": 254,
"command_topic": "zigbee2mqtt/0x84ba20fffe655423/l1/set",
"device": {
"identifiers": [
"zigbee2mqtt_0x84ba20fffe655423"
"manufacturer": "Moes",
"model": "Smart dimmer module (2 gang) (MS-105B)",
"name": "0x84ba20fffe655423"
"name": "0x84ba20fffe655423 l1",
"schema": "json",
"state_topic": "zigbee2mqtt/0x84ba20fffe655423/l1",
"unique_id": "0x84ba20fffe655423_light_l1_zigbee2mqtt"
"data": {
"definition": {
"description": "Smart dimmer module (2 gang)",
"exposes": [
"endpoint": "l1",
"features": [
"access": 3,
"description": "On/off state of this light",
"endpoint": "l1",
"name": "state",
"property": "state_l1",
"type": "binary",
"value_off": "OFF",
"value_on": "ON",
"value_toggle": "TOGGLE"
"access": 3,
"description": "Brightness of this light",
"endpoint": "l1",
"name": "brightness",
"property": "brightness_l1",
"type": "numeric",
"value_max": 254,
"value_min": 0
"type": "light"
"endpoint": "l2",
"features": [
"access": 3,
"endpoint": "l2",
"name": "state",
"property": "state_l2",
"type": "binary",
"value_off": "OFF",
"value_on": "ON",
"access": 3,
"endpoint": "l2",
"property": "brightness_l2",
"type": "numeric",
"value_max": 254,
"value_min": 0
"type": "light"
"access": 1,
"description": "Link quality (signal strength)",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "MS-105B",
"options": [],
"supports_ota": false,
"vendor": "Moes"
"friendly_name": "0x84ba20fffe655423",
"ieee_address": "0x84ba20fffe655423",
"status": "successful",
"supported": true
"type": "device_interview"
Glad I'm not the only one with this issue
Great that you will continue with this, I don't feel knowledgeable enough yet to make a ticket with the correct info.
AD stands for Autodiscover so a little short for the MQTT Autodiscover gateway implementation.
An issue can be made here
https://github.com/domoticz/domoticz/issues
See also the instructions here: https://www.domoticz.com/wiki/MQTT#Debu ... er_devices
I've tested with MQexplorer and had the same results. But I see it's already been picked up and solved, waiting for the next release.
