Page 1 of 2
script to load ENTSOE day ahead electricity prices
Posted: Thursday 24 November 2022 10:39
by willemd
Below is a script (for re-use) to load day-ahead electricity prices into domoticz historic variables.
Data is published by the EU transparency website. These are the base prices for dynamic electricity pricing contracts. Your provider will add surcharges and taxes to it. Please adapt it to your needs (for example country), as per documentation.
note: an example to get the dynamic prices from a electricty provider in JSON format is available here at this post:
viewtopic.php?p=294965#p294965
-- Script to load day-ahead electricity prices into Domoticz historic variables, as a base for further processing.
-- New prices are available every day at 15:00 for the coming 24 hrs.
-- These are base prices. Providers of dynamic electricity contracts will add their surcharges and government taxes to it.
-- API documentation at: https://transparency.entsoe.eu/content/static_content/Static%20content/web%20api/Guide.html
-- To get this data yourself (it is free):
--    1) Register for an account at https://transparency.entsoe.eu/dashboard/show
--    2) Send an email with subject "Restful API access" and your account email address in the body to [email protected]
--    3) After receipt of their confirmation, go into your account and generate your token.
--    4) Store the token in a domoticz user variable and note down the idx.
--    5) Adapt the idx on the line below.
local idxEUtoken=12  -- idx of the user variable with the API token
		timer = {
		    'at 15:05'  -- Adapt timer to your needs. Normally new prices are available after 15:00.
		httpResponses = {
			'EUprices' -- must match with the callback passed to the openURL command in the code below
	data =  {
            ElDayPrices               = { history = true, maxItems = 24 }
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'EU day ahead electricity prices',
	    local ElDayPrices = domoticz.data.ElDayPrices
	    if (item.isTimer) then
	        -- section to launch the API get request
	        local UrlStart='https://web-api.tp.entsoe.eu/api?'  -- the API website
	        local EUtoken=domoticz.variables(idxEUtoken)        -- user variable with API token
	        local DocType='A44'                                 -- day ahead prices document type
	        local PriceRegion='10YNL----------L'                -- region is set to The Netherlands (adapt to your need as per API documentation)
	        local dayahead=0
    	        if tonumber(os.date("%H"))>=15 then                 -- day ahead available after 15:00, otherwise retrieve current day, depending on the time this script is launched
    	            dayahead=24*60*60  -- seconds for full day ahead
    	        local PricePeriodStart=os.date("%Y%m%d",os.time()+ dayahead) .. "0000"  -- range 00:00 to 23:00, this will return full day anyway
    	        local PricePeriodEnd=os.date("%Y%m%d", os.time()+ dayahead) .. "2300"    -- depending on time the script is launched, get current day or tomorrow's data
	        -- compose the full URL
	        local EUurl=UrlStart .. 'securityToken=' .. EUtoken.value .. '&documentType=' .. DocType .. '&in_Domain=' .. PriceRegion .. '&out_Domain=' .. PriceRegion .. '&periodStart=' .. PricePeriodStart .. '&periodEnd=' .. PricePeriodEnd
	        -- launch the URL
			domoticz.openURL({
				url = EUurl,
				method = 'GET',
				callback = 'EUprices', -- must match httpResponses above
		    if (item.isHTTPResponse) then
		        -- response to openURL (HTTP GET) request was received
			    if (item.ok) then
			        if (item.isXML) then   -- should be XML
			            -- domoticz.utils.dumpTable(item.xml)  -- dumpTable can be used for debugging
			            ElDayPrices.reset()  -- remove historic prices from previous run
			            for id = 1, 24 do
                            domoticz.log('adding price : ' .. item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'],domoticz.LOG_INFO)
                            ElDayPrices.add(item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'])
			            -- here you can add any further processing of these variables
				        domoticz.log('No XML received', domoticz.LOG_INFO)
				    domoticz.log('There was a problem handling the request. Item not ok', domoticz.LOG_INFO)
				    domoticz.log(item, domoticz.LOG_INFO)
Re: script to load ENTSOE day ahead electricity prices
Posted: Sunday 18 December 2022 11:47
by willemd
Here is the script updated to load both dynamic electricity prices (change once per hour, published after 15:00 for full next day) and gas prices (change once per day, published after 00:00 for current day and few hours next day) and calculate the costs.
Please adapt for your own country.
-- devices
local idxElectricityP1=1
local idxGasP1=2
local idxCurrentDynamicElPrice=102
local idxDynamicElCosts=103
local idxDynamicElCostsCntr=104  -- counters are just added for testing, work fine as long as costs are positive
local idxCurrentDynamicGasPrice=107
local idxDynamicGasCosts=108
local idxDynamicGasCostsCntr=109 -- counters are just added for testing, work fine as long as costs are positive
-- user variables
local idxBTWpercentage=13 -- user variable with BTW/VAT percentage
local idxDayElTransport=3 -- user variable for fixed daily transport costs
local idxMonthElFixed=8   -- user variable for fixed monthly costs
local idxDayGasTransport=6 -- user variable for fixed daily transport costs
local idxMonthGasFixed=8   -- user variable for fixed monthly costs
		timer = {
		    'at *:45',  -- Timer to get new electricity prices. Adapt timer to your needs. Normally new electricty prices are available after 15:00.
		                -- Timer to get new gas prices. Prices received are in UTC so 1 hour shift needed for me.
		                -- Prices are now re-loaded every hour, to avoid using old prices when there is one error loading once per day.
		    'at *:59',   -- trigger to calculate the costs of the past hour (missing 1 minute, added to next hour, except end of day)
		    'at *:01'    -- trigger to copy price from list (24 historic variables) to device with current price
		httpResponses = {
			'EUprices', -- must match with the callback passed to the openURL command in the code below
			'EZGASprices',
	data =  {
            ElDayPrices               = { history = true, maxItems = 24 },
            GasDayPrices              = { history = true, maxItems = 24 },
            PreviousHrCumElCosts      = { initial = 0},
            PreviousHrCumElNett       = { initial = 0},
            PreviousHrCumGasCosts      = { initial = 0},
            PreviousHrCumGasNett       = { initial = 0}
	logging = {
		marker = 'EU and EZ day ahead prices',
	    local GasDayPrices = domoticz.data.GasDayPrices
	    local todayEl = domoticz.devices(idxElectricityP1).counterToday
	    local todayElreturn = domoticz.devices(idxElectricityP1).counterDeliveredToday
	    local todayGas = domoticz.devices(idxGasP1).counterToday
	        if (item.trigger == 'at *:01') then
	            -- copy dynamic price to device holding the current price
	            local VarIndex=24-tonumber(os.date("%H")) -- last price of day is index 1
	            local CurrentElPrice=tonumber(ElDayPrices.get(VarIndex).data)/1000 -- from EURO/MWh to EURO/kWh
	            domoticz.log('Current Dynamic El price EURO/kWh :' .. CurrentElPrice,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicElPrice).updateCustomSensor(CurrentElPrice)
	            -- also copy gas prices to current device
	            if tonumber(os.date("%H"))==0 then
	                VarIndex=1
	                VarIndex=24-tonumber(os.date("%H"))+1
	            local CurrentGasPrice=tonumber(GasDayPrices.get(VarIndex).data) -- Euro per m3, last price is for 00:00 to 01:00 next day.
	            domoticz.log('Current Dynamic Gas price :' .. CurrentGasPrice,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicGasPrice).updateCustomSensor(CurrentGasPrice)
	            if (tonumber(os.date("%H")) == 0) then
	                domoticz.devices(idxDynamicElCosts).updateCustomSensor(domoticz.data.PreviousHrCumElCosts)
	                domoticz.devices(idxDynamicGasCosts).updateCustomSensor(domoticz.data.PreviousHrCumGasCosts)
	            if (item.trigger == 'at *:59') then
    	            -- first calculate cumulative daily total and last hour electricity usage
    	            local todayElNett=domoticz.devices(idxElectricityP1).counterToday-domoticz.devices(idxElectricityP1).counterDeliveredToday
    	            domoticz.log('counterToday :' .. domoticz.devices(idxElectricityP1).counterToday,domoticz.LOG_INFO)
    	            domoticz.log('counterDeliveredToday :' .. domoticz.devices(idxElectricityP1).counterDeliveredToday,domoticz.LOG_INFO)
    	            domoticz.log('todayElNett :' .. todayElNett,domoticz.LOG_INFO)
    	            local lastHrElNett = todayElNett - domoticz.data.PreviousHrCumElNett
    	            domoticz.log('lastHrElNett :' .. lastHrElNett,domoticz.LOG_INFO)
    	            -- then calculate the costs and add to device
    	            local lastHrElCosts = lastHrElNett * domoticz.devices(idxCurrentDynamicElPrice).sensorValue * (100 + domoticz.variables(idxBTWpercentage).value)/100
    	            domoticz.log('lastHrElCosts :' .. lastHrElCosts,domoticz.LOG_INFO)
    	            local CumElCosts = domoticz.utils.round(domoticz.data.PreviousHrCumElCosts + lastHrElCosts,2)
    	            domoticz.log('CumElCosts :' .. CumElCosts,domoticz.LOG_INFO)
    	            domoticz.devices(idxDynamicElCosts).updateCustomSensor(CumElCosts)
    	            local previousCounter=0
		            local divider=100
		            previousCounter=domoticz.devices(idxDynamicElCostsCntr).counter
		            --domoticz.devices(idxDynamicElCostsCntr).updateCounter(lastHrElCosts*divider + previousCounter*divider)
		            domoticz.devices(idxDynamicElCostsCntr).updateCounter(CumElCosts*divider)
		            domoticz.log('previousCounter :' .. previousCounter,domoticz.LOG_INFO)
		            domoticz.log('newcounter :' .. lastHrElCosts + previousCounter,domoticz.LOG_INFO)
    	            -- if end of day, reset the cumulative daily totals
    	            if (tonumber(os.date("%H"))==23) then
    	                domoticz.data.PreviousHrCumElCosts=domoticz.utils.round(domoticz.variables(idxDayElTransport).value+domoticz.variables(idxMonthElFixed).value/31,2)
    	                domoticz.data.PreviousHrCumElNett=0
    	                domoticz.data.PreviousHrCumElCosts=CumElCosts
    	                domoticz.data.PreviousHrCumElNett=todayElNett
    	            -- first calculate cumulative daily total and last hour gas usage
    	            local todayGasNett=domoticz.devices(idxGasP1).counterToday
    	            domoticz.log('counterToday :' .. domoticz.devices(idxGasP1).counterToday,domoticz.LOG_INFO)
    	            domoticz.log('todayGasNett :' .. todayGasNett,domoticz.LOG_INFO)
    	            local lastHrGasNett = todayGasNett - domoticz.data.PreviousHrCumGasNett
    	            domoticz.log('lastHrGasNett :' .. lastHrGasNett,domoticz.LOG_INFO)
    	            local lastHrGasCosts = lastHrGasNett * domoticz.devices(idxCurrentDynamicGasPrice).sensorValue * (100 + domoticz.variables(idxBTWpercentage).value)/100
    	            domoticz.log('lastHrGasCosts :' .. lastHrGasCosts,domoticz.LOG_INFO)
    	            local CumGasCosts = domoticz.utils.round(domoticz.data.PreviousHrCumGasCosts + lastHrGasCosts,2)
    	            domoticz.log('CumGasCosts :' .. CumGasCosts,domoticz.LOG_INFO)
    	            domoticz.devices(idxDynamicGasCosts).updateCustomSensor(CumGasCosts)
    	            previousCounter=0
		            divider=100
		            previousCounter=domoticz.devices(idxDynamicGasCostsCntr).counter
		            --domoticz.devices(idxDynamicGasCostsCntr).updateCounter(lastHrGasCosts*divider + previousCounter*divider)
		            domoticz.devices(idxDynamicGasCostsCntr).updateCounter(CumGasCosts*divider)
		            domoticz.log('newcounter :' .. lastHrGasCosts + previousCounter,domoticz.LOG_INFO)
    	                domoticz.data.PreviousHrCumGasCosts=domoticz.utils.round(domoticz.variables(idxDayGasTransport).value+domoticz.variables(idxMonthGasFixed).value/31,2)
    	                domoticz.data.PreviousHrCumGasNett=0
    	                domoticz.data.PreviousHrCumGasCosts=CumGasCosts
    	                domoticz.data.PreviousHrCumGasNett=todayGasNett
        	        -- section to launch the EU electricity API get request
        	        -- depending on launch hour, get current or tomorrow's data
        	        local dayahead=0
        	        if tonumber(os.date("%H"))>=23 then                 -- day ahead available after 15:00, otherwise retrieve current day, depending on the time this script is launched
        	        domoticz.log("URL : " .. EUurl, domoticz.LOG_INFO)
        	        -- launch the URL
        			domoticz.openURL({
        				url = EUurl,
        				method = 'GET',
        			-- section to launch the EnergyZero gas prices API get request (UTC timing), run between 00:00 and 01:00
        	        local GASUrlStart='https://api.energyzero.nl/v1/energyprices?'  -- the API website
        	        local usageType=2  -- GAS
        	        -- always get current day data
        	        local GasPricePeriodStart=os.date("%Y-%m-%d",os.time()) .. "T00:00:00.000Z"  -- this first price is valid from 01:00 CET
        	        local GASPricePeriodEnd=os.date("%Y-%m-%d", os.time()) .. "T23:59:59.999Z"
        	        local EZurl=GASUrlStart .. 'fromDate=' .. GasPricePeriodStart .. '&tillDate=' .. GASPricePeriodEnd .. '&interval=4&usageType=' .. usageType .. '&inclBtw=false'
        	        domoticz.log("URL : " .. EZurl, domoticz.LOG_INFO)
        	        -- launch the URL
        			domoticz.openURL({
        				url = EZurl,
        				method = 'GET',
        				callback = 'EZGASprices', -- must match httpResponses above
		        if (item.trigger=="EUprices") then
    			    if (item.ok) then
    			            --domoticz.log('start dumptable', domoticz.LOG_INFO)
    			            --domoticz.utils.dumpTable(item.xml)  -- dumpTable can be used for debugging
    			            --domoticz.log('end dumptable', domoticz.LOG_INFO)
    			            for id = 1, 24 do
                                domoticz.log('adding EL price : ' .. item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'],domoticz.LOG_INFO)
	                -- trigger was not eu electricity prices but energyzero gas prices
                    domoticz.log('start gasprices', domoticz.LOG_INFO)
    	            if (item.ok) then
    	                domoticz.log('gasprices ok', domoticz.LOG_INFO)
    			        if (item.isJSON) then   -- should be JSON
    			            --domoticz.utils.dumpTable(item.json)  -- dumpTable can be used for debugging
    			            GasDayPrices.reset()  -- remove historic prices from previous run
    			            for gasid = 1, 24 do
    			                -- this adds prices from current day 01:00-02:00 to next day 00:00-01:00 intervals
                                domoticz.log('adding GAS price : ' .. item.json.Prices[gasid].price,domoticz.LOG_INFO)
                                GasDayPrices.add(item.json.Prices[gasid].price)
    				        domoticz.log('No JSON received', domoticz.LOG_INFO)
Posted: Thursday 22 December 2022 13:46
by willemd
Please note:
1) as highlighted on line 18 and 22 the use of counters was added for testing purposes. As it turns out, counters are not suitable for costs tracking if those costs can go down as well. See separate forum topic here:viewtopic.php?f=4&t=39476 so all lines related to those counters should be removed.
2) The script is initially designed for a Dutch situation and includes a daily transport cost and a monthly fixed costs. It is assumed that the user variables with those costs show the price including BTW(VAT).
3) The local energy tax per kWh or M3 is however not included, nor is the fixed daily tax reduction, tax ceiling or any other tax measure or compensation the government might come up with nowadays.
4) Also any additional charges from the provider, where applicable, are not included.
So please adapt the script to your own needs, taking the above into account.
Posted: Saturday 24 December 2022 8:25
by sietzehh
Just decided to switch over to a flexible energy contract, your script works like a charm for current prices, building a nice graph since last night howere is there a way to present the future today and day ahead prices? Browsing the forum it seems there is curently now solution within Domoticz?
Posted: Monday 26 December 2022 14:20
by willemd
sietzehh wrote: Saturday 24 December 2022 8:25 Just decided to switch over to a flexible energy contract, your script works like a charm for current prices, building a nice graph since last night howere is there a way to present the future today and day ahead prices? Browsing the forum it seems there is curently now solution within Domoticz?
I have so far not found a device that can be used to load the day-ahead prices and display them in a graph. All devices are designed to record the present and then show the history in the graphs.
But maybe, if you use a managed counter and then load the prices with updateHistory() in the shortlog it might work? I have not tried it but this is the only device where you can control the entries in the shortlog (and history log) yourself. Downside is that counters in general, and also managed counters, cannot handle negative values, so negative prices (last year 70 hours) cannot be stored and/or displayed. I am also not sure what happens if you load the entries with future datetime into the shortlog. Maybe you need to use fake datetimes, like loading future 24 hr prices into the shortlog every 5 minutes with current datetime ... just guessing. Maybe I will try it one of these days.
Posted: Tuesday 27 December 2022 22:33
by willemd
I have done a test, just to see whether it is possible to make those future prices visible in a domoticz graph. Result positive, except for negative prices (as expected). Tomorrow there are 2 hours with negative price, so a good test !!!
What I did:
1) create a managed counter device of type costs, with unit euro.
2) copied my script above and stripped it from all functionality except the part to import the ENTSOE day ahead prices.
3) added an updateHistory() statement to it in order to load every price *100 onto the managed counter with a timestamp into the future (this results in an entry in the meter table).
4) checked the meter table and checked the graph of the device.
Conclusion is that it is possible to load tomorrow's prices onto the device with a future timestamp. It does result in entries in the meter table with a future timestamp and it does result in a graph showing the prices for the day. The only limitation is that negative prices cannot be loaded and shown. Negative prices result in zero. This is a known limitation of managed counters. Also note if you run the script for a second time with the same timestamp then the existing values get replaced (which is nice).
Also note you need to exclude the managed counter from the domoticz daily closing by adding "DisableLogAutoUpdate:dHJ1ZQ==" into the options field of the devicestatus table, for example using sqlite3. (see https://www.domoticz.com/wiki/Domoticz_ ... n_counters)
Since this was just a quick test, my script is a bit dirty:
1) I hardcoaded the timestamp.
2) I multiplied the prices by 100 in order not to loose the decimals, so the unit is now EURO per 100 MWh.
but as a proof-of-principle it works.
Here is the graph:
Here is the script:
-- devices
local idxMgdCounter=112
-- user variables
		timer = {
		    'at 22:17',  -- Timer to get new electricity prices. Adapt timer to your needs. Normally new electricty prices are available after 15:00.
		httpResponses = {
			'EUDAYprices', -- must match with the callback passed to the openURL command in the code below
	data =  {
	logging = {
		marker = 'EU day ahead prices',
	        local dayahead=0
	        if tonumber(os.date("%H"))>=22 then                 -- day ahead available after 15:00, otherwise retrieve current day, depending on the time this script is launched
	        -- launch the URL
			domoticz.openURL({
				url = EUurl,
				method = 'GET',
				callback = 'EUDAYprices', -- must match httpResponses above
		        if (item.trigger=="EUDAYprices") then
    			    if (item.ok) then
    			            domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 00:00:00","0;0") -- add a zero start value
    			            for id = 1, 24 do
                                local currentDateTime=os.date("%Y-%m-%d %H:00:00",os.time()+2*60*60+id*60*60)
                                local changevalue=tonumber(item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount']) * 100
                                local historystring=changevalue .. ";" .. changevalue
                        		domoticz.log("domoticz.devices(idxMgdCounter).updateHistory(\"" .. currentDateTime .. "\",\"" .. historystring .. "\")", domoticz.LOG_INFO)
		                        domoticz.devices(idxMgdCounter).updateHistory(currentDateTime,historystring)
here is the script output
2022-12-27 22:17:01.136 Status: dzVents: Info: EU day ahead prices: ------ Start internal script: Script #4: HTTPResponse: "EUDAYprices"
2022-12-27 22:17:01.187 Status: dzVents: Info: EU day ahead prices: adding EL price : 40.28
2022-12-27 22:17:01.188 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 01:00:00","4028.0;4028.0")
2022-12-27 22:17:01.188 Status: dzVents: Info: EU day ahead prices: adding EL price : 33.13
2022-12-27 22:17:01.188 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 02:00:00","3313.0;3313.0")
2022-12-27 22:17:01.189 Status: dzVents: Info: EU day ahead prices: adding EL price : 9.83
2022-12-27 22:17:01.189 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 03:00:00","983.0;983.0")
2022-12-27 22:17:01.189 Status: dzVents: Info: EU day ahead prices: adding EL price : -1.35
2022-12-27 22:17:01.190 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 04:00:00","-135.0;-135.0")
2022-12-27 22:17:01.190 Status: dzVents: Info: EU day ahead prices: adding EL price : -0.65
2022-12-27 22:17:01.190 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 05:00:00","-65.0;-65.0")
2022-12-27 22:17:01.191 Status: dzVents: Info: EU day ahead prices: adding EL price : 0.78
2022-12-27 22:17:01.191 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 06:00:00","78.0;78.0")
2022-12-27 22:17:01.191 Status: dzVents: Info: EU day ahead prices: adding EL price : 17.29
2022-12-27 22:17:01.192 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 07:00:00","1729.0;1729.0")
2022-12-27 22:17:01.192 Status: dzVents: Info: EU day ahead prices: adding EL price : 69.85
2022-12-27 22:17:01.192 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 08:00:00","6985.0;6985.0")
2022-12-27 22:17:01.193 Status: dzVents: Info: EU day ahead prices: adding EL price : 110.00
2022-12-27 22:17:01.193 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 09:00:00","11000.0;11000.0")
2022-12-27 22:17:01.193 Status: dzVents: Info: EU day ahead prices: adding EL price : 120.00
2022-12-27 22:17:01.194 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 10:00:00","12000.0;12000.0")
2022-12-27 22:17:01.194 Status: dzVents: Info: EU day ahead prices: adding EL price : 118.00
2022-12-27 22:17:01.194 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 11:00:00","11800.0;11800.0")
2022-12-27 22:17:01.195 Status: dzVents: Info: EU day ahead prices: adding EL price : 120.00
2022-12-27 22:17:01.195 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 12:00:00","12000.0;12000.0")
2022-12-27 22:17:01.196 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 13:00:00","12000.0;12000.0")
2022-12-27 22:17:01.196 Status: dzVents: Info: EU day ahead prices: adding EL price : 100.00
2022-12-27 22:17:01.196 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 14:00:00","10000.0;10000.0")
2022-12-27 22:17:01.197 Status: dzVents: Info: EU day ahead prices: adding EL price : 74.90
2022-12-27 22:17:01.197 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 15:00:00","7490.0;7490.0")
2022-12-27 22:17:01.197 Status: dzVents: Info: EU day ahead prices: adding EL price : 100.00
2022-12-27 22:17:01.198 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 16:00:00","10000.0;10000.0")
2022-12-27 22:17:01.198 Status: dzVents: Info: EU day ahead prices: adding EL price : 114.26
2022-12-27 22:17:01.198 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 17:00:00","11426.0;11426.0")
2022-12-27 22:17:01.199 Status: dzVents: Info: EU day ahead prices: adding EL price : 121.26
2022-12-27 22:17:01.199 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 18:00:00","12126.0;12126.0")
2022-12-27 22:17:01.199 Status: dzVents: Info: EU day ahead prices: adding EL price : 119.90
2022-12-27 22:17:01.200 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 19:00:00","11990.0;11990.0")
2022-12-27 22:17:01.200 Status: dzVents: Info: EU day ahead prices: adding EL price : 95.14
2022-12-27 22:17:01.200 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 20:00:00","9514.0;9514.0")
2022-12-27 22:17:01.201 Status: dzVents: Info: EU day ahead prices: adding EL price : 91.35
2022-12-27 22:17:01.201 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 21:00:00","9135.0;9135.0")
2022-12-27 22:17:01.201 Status: dzVents: Info: EU day ahead prices: adding EL price : 68.18
2022-12-27 22:17:01.202 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 22:00:00","6818.0;6818.0")
2022-12-27 22:17:01.202 Status: dzVents: Info: EU day ahead prices: adding EL price : 42.54
2022-12-27 22:17:01.202 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-28 23:00:00","4254.0;4254.0")
2022-12-27 22:17:01.203 Status: dzVents: Info: EU day ahead prices: adding EL price : 21.48
2022-12-27 22:17:01.203 Status: dzVents: Info: EU day ahead prices: domoticz.devices(idxMgdCounter).updateHistory("2022-12-29 00:00:00","2148.0;2148.0")
2022-12-27 22:17:01.205 Status: dzVents: Info: EU day ahead prices: ------ Finished Script #4
and here are the entries from the meter table (created on the 27th):
112|0|0|2022-12-28 00:00:00
112|4028|4028|2022-12-28 01:00:00
112|3313|3313|2022-12-28 02:00:00
112|983|983|2022-12-28 03:00:00
112|0|0|2022-12-28 04:00:00
112|0|0|2022-12-28 05:00:00
112|78|78|2022-12-28 06:00:00
112|1729|1729|2022-12-28 07:00:00
112|6985|6985|2022-12-28 08:00:00
112|11000|11000|2022-12-28 09:00:00
112|12000|12000|2022-12-28 10:00:00
112|11800|11800|2022-12-28 11:00:00
112|12000|12000|2022-12-28 12:00:00
112|12000|12000|2022-12-28 13:00:00
112|10000|10000|2022-12-28 14:00:00
112|7490|7490|2022-12-28 15:00:00
112|10000|10000|2022-12-28 16:00:00
112|11426|11426|2022-12-28 17:00:00
112|12126|12126|2022-12-28 18:00:00
112|11990|11990|2022-12-28 19:00:00
112|9514|9514|2022-12-28 20:00:00
112|9135|9135|2022-12-28 21:00:00
112|6818|6818|2022-12-28 22:00:00
112|4254|4254|2022-12-28 23:00:00
112|2148|2148|2022-12-29 00:00:00
Posted: Tuesday 27 December 2022 23:13
by JanvdW
Nicely done. Personally, I don't find the future prices in a graph that interesting: you actually want to determine what favorable hours are to switch on and/or charge devices based on these future values. If you look at such a graph, it is quite logical which times are best suited for this, but it is still quite difficult to convert that into an algorithm. Does anyone already have experience with that?
Posted: Tuesday 27 December 2022 23:47
by willemd
JanvdW wrote: Tuesday 27 December 2022 23:13 Nicely done. Personally, I don't find the future prices in a graph that interesting: you actually want to determine what favorable hours are to switch on and/or charge devices based on these future values. If you look at such a graph, it is quite logical which times are best suited for this, but it is still quite difficult to convert that into an algorithm. Does anyone already have experience with that?
Yes, it is a nice challenge:
1) First you need to know some basic variables: the total charge/discharge capacity and the charge/discharge time needed, in case of batteries.
2) You want to take a minimum for charge and maximum for discharge, maybe with extra hours before or after, depending on the charge/discharge time (if it takes more than 1 hour)
3) You want to do that multiple times per day if possible.
4) You might want to take next days data into account as soon as that is published.
In the example graph above:
1) charge the battery when prices are negative between 03:00 and 05:00. You get paid to get electricity from the grid.
2) then discharge from 9:00 to 10:00
3) charge again from 10:00 to 11:00? is it worth it? and then discharge again between 11:00 and 13:00
4) charge again from 14:00 to 15:00
5) discharge again from 17:00 to 18:00
6) even if the value is low, you probably don't want to charge already at 23:00 since probably the price goes down further the next morning. Note next day's prices are published at 15:00.
Key to a good solution is to find the local minimum and maximum prices. I think probably by checking its neighbours. Neighbours should both be higher, in case of minimum, or lower, in case of maximum. In the example you would find 3 minimum values, a 3 maximum values.
This will provide you with the pairs for charging and discharging. So, if you can charge/discharge full capacity within 1 hour it is not too difficult.
But if it takes more than 1 hour...how to optimise ... need to think about it more. Feels like a recursive algorithm might do the trick here.
Posted: Wednesday 28 December 2022 23:33
by JanvdW
I was still thinking about this for a while and came to the conclusion that you have to deal with two sets of variables:
  • price driven. You need to select the optimum (1, 2, 3 hour) time slots for loading/ unloading in the next x hours. Based on the device characteristics the most appropriate time slots can be selected.
  • device driven. Depending on the device characteristics you have different needs to choose optimal hours. Some examples:
    • washing machine is busy for three hours; you do not want to interrupt when it's started. So in this case you need the lowest price for a three hour time slot.
    • The battery of an electric bike is charging for 2,5 hours; it's no problem to interrupt loading for some hours. So you need three time slots (not necessarily consecutive) with the lowest price. Any timeslot before you leave next morning is appropriate.
    • home battery charging/ discharging depends on the battery capacity, % filled, the percentage you want to fill/unfill the battery (85%/15%?) and the desired difference between min/max prices (because of efficiency loss, wear). Together this defines the maximum number of time slots (not necessarily consecutive). If no suitable time slots are available, there is no need to charge.
I think that the best solution is to run a script every x hours that selects the optimum timeslots for these scenarios (both for load and unload) and store them in (global user) data, e.g.:
  • 3 or 4 best slots for 1 hour
  • 1 or 2 best slots for 2 hours
  • 1 best slot for 3 hours
Other scripts can select the optimal available time slots to control the devices.
It's quite easy to select a time slot with the lowest price in a certain period, e.g. with code like this (note: it's important that the original script loads data from the next day short after 15:00; otherwise you there's not enough data in the data set)
lowPriceIndex = VarIndex 			-- Starting point current time
local NrAvailablePrices = 9					-- Timeslot to find lowest price
for id = 1, NrAvailablePrices do				-- Determine lowest values in the next hours
	VarIndexStroom = VarIndexStroom - 1
	domoticz.log('Price electricity (' .. tonumber(ElDayPrices.get(VarIndexStroom).data) .. ')',domoticz.LOG_INFO)
	if tonumber(ElDayPrices.get(lowPriceIndex).data) > tonumber(ElDayPrices.get(VarIndexStroom).data) then
domoticz.data.lowPriceIndex = lowPriceIndex
domoticz.log('Lowest price for electricity is at ' .. 24-lowPriceIndex .. ':00 uur (' ..tonumber(ElDayPrices.get(lowPriceIndex).data) .. ')',domoticz.LOG_INFO)
This can be extended for consecutive timeslots with the lowest price. The point is that there are quite a lot scenario's, which makes it complex.
Posted: Wednesday 28 December 2022 23:44
by JanvdW
Additionally, when the dataset for the next day is loaded between 15:00 and 16:00 the number of records in the dataset varies (24 resp. 48 records).
You can handle this bij creating a separate VarIndex for Electricity (because it's different from Gas) and define the number of records depending on time:
local NrRecordsEl  = 48
if (tonumber(os.date("%H")) * 60 + tonumber(os.date("%M"))) < 945 then
	NrRecordsEl    = 24
local VarIndexEl        = NrRecordsStroom-tonumber(os.date("%H"))
Posted: Thursday 29 December 2022 9:36
by willemd
Best to move further exchange about optimisation during the day to a separate thread, thanks.
Posted: Tuesday 03 January 2023 8:05
by tomipaci
good day,
I tried to run your script. It looks great, but I don't have a lot of experience, so I would like to ask for precise instructions on creating the device. I don't know what's wrong with me.
Posted: Wednesday 04 January 2023 9:34
by willemd
tomipaci wrote: Tuesday 03 January 2023 8:05 good day,
Menu: setup, hardware, choose type dummy and fill in the rest of the fields.
On the same page, on the hardware line, click on "create virtual sensor", choose type "custom sensor" and fill in the fields.
Then setup, more options, user variables.
Note down all idx numbers and replace them in the script.
Read the documentation in the script and in the wiki where needed .......
Posted: Saturday 07 January 2023 21:08
by JanvdW
Now and then (today amongst others) I see an error message every hour at *.45:
attempt to index a nil value (field '?')
This error is caused by the command that aims to write the gas prices to the Domoticz log (row 240 in the script).
The persistent data contain the gas prices that were stored yesterday evening. It turns out that the http request returns five values (instead of 24). I am not sure, but when I remember well, this was the same last weekend. Possibly no one manages this source during the weekends and public holidays?
Posted: Saturday 07 January 2023 22:09
by willemd
Yes, I have the same problem. Clearly an unreliable source for gas prices.
I think I also need to improve the script to handle the error better.
Posted: Friday 03 February 2023 8:51
by renerene
willemd wrote: Tuesday 27 December 2022 23:47 Key to a good solution is to find the local minimum and maximum prices.
ChatGpt to the rescue:
def find_subarray(A, X):
    n = len(A)
    min_sum = float('inf')
    j_index, k_index = 0, 0
    for i in range(n - X + 1):
        subarray_sum = sum(A[i:i+X])
        if subarray_sum < min_sum:
            min_sum = subarray_sum
            j_index = i
            k_index = i + X - 1
    return j_index, k_index
Posted: Friday 03 February 2023 10:15
by JanvdW
Great; ChatGPT for president :-). Asking for this function in dzVents code returns this:
		customEvents = {
			'CalculateJK'
		local array = item.array
		local x = item.x
		local j, k
		local min = math.huge
		for i = 1, #array - x + 1 do
			local currentSum = 0
			for j = i, i + x - 1 do
				currentSum = currentSum + array[j]
			if currentSum < min then
				min = currentSum
				j = i
				k = i + x - 1
		domoticz.log("J = " .. j .. ", K = " .. k)
Posted: Friday 03 February 2023 12:00
by willemd
Stop hyjacking and posting nonsense to this thread please. This thread was to share experience with the loading of the hourly electricity and daily gas prices for the day ahead for anyone to re-use.
Optimisation of usage of price variation is a total different story and those chatGPT programs posted here only form a beginning of a solution, a tiny fraction. Finding a minimum and maximum is easy but then ....
As posted in a separate thread, I have created a python program that plans for battery charging and discharging using those minimum and maximum values, but also taking into account battery capacity, charging and discharging speed, solar panel production etc. Until you try it for yourself you have no idea of the complexity.....
https://github.com/WillemD61/battery-planning
Posted: Saturday 15 April 2023 5:08
by Alain
JanvdW wrote: Wednesday 28 December 2022 23:33 I was still thinking about this for a while and came to the conclusion that you have to deal with two sets of variables:
I've tried adding this code to the code above to find the lowest price in the day ahead table, but I get an error saying that I am trying to do arithmetic on a nil value (global variable VarIndexStroom). I'm not completely understanding how to work with putting data in some sort of array (which I can't see) and then working with that. I have always just used user variables and am new to this approach. I hope someone can help me. I would like to identify both the lowest price and the highest price, but more importantly, at which time of day they occur.
Posted: Saturday 15 April 2023 11:02
by JanvdW
Alain wrote: Saturday 15 April 2023 5:08 I've tried adding this code to the code above to find the lowest price in the day ahead table, but I get an error saying that I am trying to do arithmetic on a nil value (global variable VarIndexStroom). I'm not completely understanding how to work with putting data in some sort of array (which I can't see) and then working with that. I have always just used user variables and am new to this approach. I hope someone can help me. I would like to identify both the lowest price and the highest price, but more importantly, at which time of day they occur.
This has nothing to do with the global variable. By the way, you can find the variables in the domoticz/scripts/dzVents/data folder.
Your problem has probably to do with the number of items that's available in the dataset. The loop goes outside the available range at some times.
I recognize the problem and have made quite a few changes to my script. Here's my current script for inspiration. Not completely finished yet, but hopefully this will help out.
-- Script to load day-ahead electricity and gas prices into Domoticz historic variables, as a base for further processing.
-- New electricity prices are available every day at 13:00 for the coming 24 hrs. These are base prices. Providers of dynamic electricity contracts will add their surcharges and government taxes to it.
--    1) Register for an account at https://transparency.entsoe.eu/dashboard/show and send an email with subject "Restful API access" and your account email address in the body to [email protected]
--    2) After receipt of their confirmation, go into your account and generate your token.
--    3) Update variables and idx's on the lines below (including EUtoken which you just generated!)
-- Device idx's
local idxStroomP1                   = <idx>
local idxGasP1                      = <idx>
local idxSolar                      = <idx>
local idxCurrentDynamicStroomPrice  = <idx>
local idxDynamicStroomCosts         = <idx>
local idxDynamicSolarRevenue        = <idx>
local idxCurrentDynamicGasPrice     = <idx>
local idxDynamicGasCosts            = <idx>
local idxEnergyCosts                = <idx>
local idxVirtualEnergyCosts         = <idx>
local idxlowPriceIndex1             = <idx>
local idxlowPriceIndex2             = <idx>
local idxlowPriceIndex3             = <idx>
local idxlowPriceIndex4             = <idx>
-- variables for EU market prices gas and electricity
local UrlStart                      = 'https://web-api.tp.entsoe.eu/api?'           -- EU electricity API - launch the EU electricity API get request
local DocType                       = 'A44'                                         -- EU electricity API - day ahead prices document type
local PriceRegion                   = '10YNL----------L'                            -- EU electricity API - region is set to The Netherlands (adapt to your need as per API documentation)
local EUtoken                       = 'f9eb2b55-708b-4464-ae62-6d1185435b44'        -- EU electricity API - API token
local GASUrlStart                   = 'https://api.energyzero.nl/v1/energyprices?'  -- Gas API website
local usageType                     = 2                                             -- Gas
	on = {  timer = {   'at *:45',                                                  -- Get new price arrays. Prices received are in UTC so 1 hour shift needed
        -- Prices are re-loaded every hour, to avoid using old prices when there is one error loading once per day.
		                'at *:55',                                                  -- Determine cheapest hour frames and calculate the costs of the past hour (missing last minutes, added to next hour, except end of day)
		                'at *:59' },                                                -- Store cost/revenue to corresponding devices, update current prices and set switches on/off
		    httpResponses = {   'EUprices',                                         -- must match with the callback passed to the openURL command in the code below
			                    'EZGASprices', } },
	data =  {   StroomHourPrices            = { history = true, maxItems = 48 },
                NrRecordsStroom             = { initial = 24},
                NrRecordsGas                = { initial = 24},
                PreviousHrCumStroomCosts    = { initial = 0},
                PreviousHrCumStroomNett     = { initial = 0},
                PreviousHrCumSolarRevenue   = { initial = 0},
                PreviousHrCumSolarNett      = { initial = 0},
                PreviousHrCumGasNett        = { initial = 0},
                lowPriceIndex1              = { initial = 0},
                lowPriceIndex2              = { initial = 0},
                lowPriceIndex3              = { initial = 0},
                lowPriceIndex4              = { initial = 0},
                SwitchOnTime1               = { initial = 0},
                SwitchOnTime2               = { initial = 0},
                SwitchOnTime3               = { initial = 0},
                SwitchOnTime4               = { initial = 0},
    logging = { level   = domoticz.LOG_INFO,
		        marker  = 'EU and EZ day ahead prices', },
        -- Variables
        local BTW                           = 21                                            -- BTW percentage
        local DayStroomFixed                = 0                                             -- Fixed daily costs electrcity (excl. BTW)
        local MonthStroomFixed              = -11.52892562                                  -- Fixed monthly costs electricity (excl. BTW)
        local kwhStroom                     = 0.128471074                                   -- Variable costs electricity (per KwH), on top of EU market price (excl. BTW) -> (0,128471074 + 0,003)/1,21
        local DayGasFixed                   = 0                                             -- Fixed daily costs gas (excl. BTW)
        local MonthGasFixed                 = 19.4214876                                    -- Fixed monthly costs gas (excl. BTW)
        local m3Gas                         = 0.531123967                                   -- Variable costs gas (per m3), on top of EU market price (excl. BTW)
        local Time                          = require('Time')
        local ContractEindDatum             = Time('2023-2-28 23:59:59')                    -- Einddatum huidige energiecontract
        if domoticz.time.compare(ContractEindDatum).compare < 0 then                        -- Tarieven na ContractEindDatum bij contractwijziging
	    local StroomHourPrices      = domoticz.data.StroomHourPrices
	    local todayStroom           = domoticz.devices(idxStroomP1).counterToday
	    local todayStroomreturn     = domoticz.devices(idxStroomP1).counterDeliveredToday
	    local todaySolar            = domoticz.devices(idxSolar).counterToday
        local NrRecordsStroom       = domoticz.data.NrRecordsStroom
        local VarIndexStroom        = NrRecordsStroom-tonumber(os.date("%H"))        -- last price of day is index 1
        local NrRecordsGas          = domoticz.data.NrRecordsGas
        local VarIndexGas           = NrRecordsGas-tonumber(os.date("%H"))
                if (tonumber(os.date("%H")) == 23) then
                    domoticz.devices(idxDynamicStroomCosts).updateCustomSensor(domoticz.data.PreviousHrCumStroomCosts)
                    domoticz.devices(idxDynamicSolarRevenue).updateCustomSensor(domoticz.data.PreviousHrCumSolarRevenue)
                    domoticz.devices(idxEnergyCosts).updateCustomSensor(domoticz.data.PreviousHrCumStroomCosts + domoticz.data.PreviousHrCumGasCosts)
                    domoticz.devices(idxVirtualEnergyCosts).updateCustomSensor(domoticz.data.PreviousHrCumStroomCosts + domoticz.data.PreviousHrCumGasCosts)
	            local CurrentStroomPrice=tonumber(StroomHourPrices.get(VarIndexStroom - 1).data)/1000 + kwhStroom                               -- from EURO/MWh to EURO/kWh + (supplier) price per KwH
                local CurrentStroomPriceBTW = CurrentStroomPrice * (100 + BTW)/100
                domoticz.log('Current Dynamic Stroom price Euro/kWh: ' .. CurrentStroomPriceBTW,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicStroomPrice).updateCustomSensor(CurrentStroomPriceBTW)
	            if VarIndexGas < 3  then
	                VarIndexGas = 1
	                VarIndexGas = VarIndexGas - 2        -- -1 (dataset starts at 23:00) -1 (script runs 1 minute before :00)
	            local CurrentGasPrice=tonumber(GasDayPrices.get(VarIndexGas).data) + m3Gas                                                      -- Euro per m3, last price is for 00:00 to 01:00 next day.
	            local CurrentGasPriceBTW = CurrentGasPrice * (100 + BTW)/100
	            domoticz.log('Current Dynamic Gas price Euro/m3: ' .. CurrentGasPriceBTW,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicGasPrice).updateCustomSensor(CurrentGasPriceBTW)
                --if tonumber(os.date("%H")) < 9 or tonumber(os.date("%H")) > 19 then
                    --domoticz.notify('VarIndexGas','VarIndexGas: ' .. VarIndexGas .. ' (' .. NrRecordsGas .. ' records)',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    --domoticz.notify('Dynamic Gas price','Gas price: ' .. CurrentGasPriceBTW,domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                --end
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex1 then                                               -- Set switches with 1 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 1 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex1 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (1 uur frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime1 = tonumber(os.date("%H"))
                    --domoticz.devices('Name or idx switch').switchOn().checkFirst()
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex2 then                                               -- Set switches with 2 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 2 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex2 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (2 uurs frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime2 = tonumber(os.date("%H"))
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex3 then                                               -- Set switches with 3 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 3 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex3 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (3 uurs frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime3 = tonumber(os.date("%H"))
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex4 then                                               -- Set switches with 4 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 4 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex4 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (4 uurs frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime4 = tonumber(os.date("%H"))
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime1 + 1 then                                                              -- Set switches with 1 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 1 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex1 + 1 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (1 uur frame)',domoticz.LOG_INFO)
                    --domoticz.devices('Name or idx switch').switchOff().checkFirst()
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime2 + 2 then                                                              -- Set switches with 2 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 2 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex2 + 2 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (2 uurs frame)',domoticz.LOG_INFO)
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime3 + 3 then                                                              -- Set switches with 3 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 3 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex3 + 3 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (3 uurs frame)',domoticz.LOG_INFO)
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime4 + 4 then                                                              -- Set switches with 4 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 4 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex4 + 4 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (4 uurs frame)',domoticz.LOG_INFO)
	            if (item.trigger == 'at *:55') then        -- first calculate cumulative daily total and last hour electricity usage
    	            local todayStroomNett=domoticz.devices(idxStroomP1).counterToday-domoticz.devices(idxStroomP1).counterDeliveredToday
    	            local lastHrStroomNett = todayStroomNett - domoticz.data.PreviousHrCumStroomNett
                    local lastHrStroomCosts = lastHrStroomNett * domoticz.devices(idxCurrentDynamicStroomPrice).sensorValue * (100 + BTW)/100   -- then calculate the costs and add to device
    	            local CumStroomCosts = domoticz.utils.round(domoticz.data.PreviousHrCumStroomCosts + lastHrStroomCosts,2)
    	            domoticz.devices(idxDynamicStroomCosts).updateCustomSensor(CumStroomCosts)
        domoticz.log('todayStroomNett: ' .. domoticz.devices(idxStroomP1).counterToday-domoticz.devices(idxStroomP1).counterDeliveredToday,domoticz.LOG_INFO)
        domoticz.log('counterToday: ' .. domoticz.devices(idxStroomP1).counterToday,domoticz.LOG_INFO)
        domoticz.log('counterDeliveredToday: ' .. domoticz.devices(idxStroomP1).counterDeliveredToday,domoticz.LOG_INFO)
        domoticz.log('lastHrStroomNett: ' .. lastHrStroomNett,domoticz.LOG_INFO)
        domoticz.log('lastHrStroomCosts: ' .. lastHrStroomCosts,domoticz.LOG_INFO)
        domoticz.log('CumStroomCosts: ' .. CumStroomCosts,domoticz.LOG_INFO)
    	            if (tonumber(os.date("%H"))==23) then        -- if end of day, reset the cumulative daily totals
    	                domoticz.data.PreviousHrCumStroomCosts = (DayStroomFixed+MonthStroomFixed/31) * (100 + BTW)/100
    	                domoticz.data.PreviousHrCumStroomNett = 0
    	                domoticz.data.PreviousHrCumStroomCosts = CumStroomCosts
    	                domoticz.data.PreviousHrCumStroomNett = todayStroomNett
    	            local todaySolarNett=domoticz.devices(idxSolar).counterToday
    	            local lastHrSolarNett = todaySolarNett - domoticz.data.PreviousHrCumSolarNett
                    local lastHrSolarRevenue = lastHrSolarNett * domoticz.devices(idxCurrentDynamicStroomPrice).sensorValue * (100 + BTW)/100   -- then calculate the costs and add to device
    	            local CumSolarRevenue = domoticz.utils.round(domoticz.data.PreviousHrCumSolarRevenue + lastHrSolarRevenue,2)
    	            domoticz.devices(idxDynamicSolarRevenue).updateCustomSensor(CumSolarRevenue)
        domoticz.log('counterToday Solar: ' .. domoticz.devices(idxSolar).counterToday,domoticz.LOG_INFO)
        domoticz.log('lastHrSolarNett: ' .. lastHrSolarNett,domoticz.LOG_INFO)
        domoticz.log('lastHrSolarRevenue: ' .. lastHrSolarRevenue,domoticz.LOG_INFO)
        domoticz.log('CumSolarRevenue: ' .. CumSolarRevenue,domoticz.LOG_INFO)
    	                domoticz.data.PreviousHrCumSolarRevenue = 0
    	                domoticz.data.PreviousHrCumSolarNett = 0
    	                domoticz.data.PreviousHrCumSolarRevenue = CumSolarRevenue
    	                domoticz.data.PreviousHrCumSolarNett = todaySolarNett
    	            local todayGasNett=domoticz.devices(idxGasP1).counterToday        -- calculate cumulative daily total and last hour gas usage
    	            local lastHrGasCosts = lastHrGasNett * domoticz.devices(idxCurrentDynamicGasPrice).sensorValue * (100 + BTW)/100            -- then calculate the costs and add to device
        domoticz.log('counterToday todayGasNett: ' .. domoticz.devices(idxGasP1).counterToday,domoticz.LOG_INFO)
        domoticz.log('lastHrGasNett: ' .. lastHrGasNett,domoticz.LOG_INFO)
        domoticz.log('lastHrGasCosts: ' .. lastHrGasCosts,domoticz.LOG_INFO)
        domoticz.log('CumGasCosts: ' .. CumGasCosts,domoticz.LOG_INFO)
    	                domoticz.data.PreviousHrCumGasCosts = (DayGasFixed+MonthGasFixed/31) * (100 + BTW)/100
    	                domoticz.data.PreviousHrCumGasNett = 0
    	                domoticz.data.PreviousHrCumGasCosts = CumGasCosts
    	                domoticz.data.PreviousHrCumGasNett = todayGasNett
	                local TotalCosts = tonumber(domoticz.utils.round((CumStroomCosts + CumGasCosts),2))
                    local TotalUse = tonumber(domoticz.utils.round((TotalCosts + CumSolarRevenue),2))
    	            domoticz.devices(idxEnergyCosts).updateCustomSensor(TotalCosts)
                    domoticz.devices(idxVirtualEnergyCosts).updateCustomSensor(TotalUse)
        domoticz.log('TotalCosts: ' .. TotalCosts,domoticz.LOG_INFO)
        domoticz.log('TotalUse: ' .. TotalUse,domoticz.LOG_INFO)
        -- Determine cheapest time frames in the next period
            	    local IndexStart, TimeStart, IndexEnd, TimeEnd, min, TimeFrame, currentSum
            	    local NrAvailablePrices = 8        -- # available records: max 10. Or # available records - records in the past - max Timeframe (4)
            	    if NrRecordsStroom - tonumber(os.date("%H")) - 4 - 1 < 10 then
            	        NrAvailablePrices = NrRecordsStroom - tonumber(os.date("%H")) - 4
            	    for TimeFrame = 1, 4 do
            	        min = math.huge        -- starting point for minimum value (infinity)
            	        IndexStart = 0        -- index values for start timeframe with lowest price
            	        IndexEnd = 0        -- index values for end timeframe with lowest price
                		for i = VarIndexStroom - NrAvailablePrices -1, VarIndexStroom - TimeFrame do
                		    currentSum = 0        -- temporary value for calculation lowest prices in time frames
                		    for IndexEnd = i, i + TimeFrame - 1 do
                			    currentSum = currentSum + tonumber(StroomHourPrices.get(IndexEnd).data)
                			if currentSum <= min then
                				min = currentSum
                				IndexEnd = i
                				IndexStart = i + TimeFrame - 1
                        if 24-IndexStart < 0 then
                            TimeStart = 48-IndexStart
                            TimeStart = 24-IndexStart
                        if 24-IndexEnd < 0 then
                            TimeEnd = 48-IndexEnd
                            TimeEnd = 24-IndexEnd
                        domoticz.log('Cheapest ' .. TimeFrame .. ' hour frame ' .. TimeStart .. ':00 uur (' ..tonumber(StroomHourPrices.get(IndexStart).data) .. ') tot  ' .. TimeEnd .. ':59 uur (' ..tonumber(StroomHourPrices.get(IndexEnd).data) .. ')',domoticz.LOG_INFO)
                        if TimeFrame == 1 then
                            domoticz.data.lowPriceIndex1 = IndexStart
                            domoticz.devices(idxlowPriceIndex1).updateCustomSensor(TimeStart)
                        elseif TimeFrame == 2 then
                            domoticz.data.lowPriceIndex2 = IndexStart
                            domoticz.devices(idxlowPriceIndex2).updateCustomSensor(TimeStart)
                        elseif TimeFrame == 3 then
                            domoticz.data.lowPriceIndex3 = IndexStart
                            domoticz.devices(idxlowPriceIndex3).updateCustomSensor(TimeStart)
                        elseif TimeFrame == 4 then
                            domoticz.data.lowPriceIndex4 = IndexStart
                            domoticz.devices(idxlowPriceIndex4).updateCustomSensor(TimeStart)
	            else        -- at *:45: depending on launch hour, get current or tomorrow's data
        	        local PricePeriodStart=os.date("%Y%m%d",os.time()) .. "0000"        -- range 00:00 to 23:00, this will return full day anyway
        	        local PricePeriodEnd=os.date("%Y%m%d", os.time() + 24*60*60) .. "2300"                                                      -- depending on time the script is launched, get current day and/or tomorrow's data
        	        local EUurl=UrlStart .. 'securityToken=' .. EUtoken .. '&documentType=' .. DocType .. '&in_Domain=' .. PriceRegion .. '&out_Domain=' .. PriceRegion .. '&periodStart=' .. PricePeriodStart .. '&periodEnd=' .. PricePeriodEnd
        			domoticz.openURL({  url         = EUurl,        -- launch url
        				                method      = 'GET',
        				                callback    = 'EUprices', })        -- must match httpResponses above
        	        local GasPricePeriodStart=os.date("%Y-%m-%d",os.time()) .. "T00:00:00.000Z"                                                 -- always get current day data. This first price is valid from 01:00 CET
        			domoticz.openURL({  url         = EZurl,        -- launch url
        				                method      = 'GET',
        				                callback    = 'EZGASprices', })        -- must match httpResponses above
		    if (item.isHTTPResponse) then        -- response to openURL (HTTP GET) request was received
    			    if (item.ok) then
                            StroomHourPrices.reset()        -- remove historic prices from previous run
                            if #item.xml.Publication_MarketDocument.TimeSeries == 2 then
                                domoticz.data.NrRecordsStroom = 48
                                for TS = 1, 2 do
                                    for id = 1, 24 do
                                        if TS == 1 then
                                            domoticz.log('Stroom marktprijs vandaag vanaf ' .. id-1 .. ':00 uur: ' .. item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000 .. " (" .. domoticz.utils.round((item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000 + kwhStroom) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
                                            domoticz.log('Stroom marktprijs morgen vanaf ' .. id-1 .. ':00 uur: ' .. item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000  .. " (" .. domoticz.utils.round((item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000 + kwhStroom) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
                                        StroomHourPrices.add(item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount'])
                                domoticz.data.NrRecordsStroom = 24
                                for id = 1, 24 do
                                    domoticz.log('Stroom marktprijs vanaf ' .. id-1 .. ':00 uur: ' .. item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount']/1000  .. " (" .. domoticz.utils.round((item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount']/1000 + kwhStroom) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
                                    StroomHourPrices.add(item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'])
    				    if item.statusCode == 503 then
    				        domoticz.log('Electriciteitsprijzen tijdelijk niet beschikbaar ivm onderhoud. HTTP statuscode: ' .. item.statusCode .. ' - ' .. item.statusText, domoticz.LOG_INFO)
    				        domoticz.log('Foutsituatie. HTTP statuscode: ' .. item.statusCode .. ' - ' .. item.statusText, domoticz.LOG_INFO)
	            else        -- trigger was not EU electricity prices but energyzero gas prices
    	            if (item.ok) then
                            domoticz.data.NrRecordsGas = #item.json.Prices
    			            for gasid = 1, domoticz.data.NrRecordsGas do        -- add prices from current day 01:00-02:00 to next day 00:00-01:00 intervals
                                domoticz.log('Gas marktprijs vandaag vanaf: ' .. gasid .. ':00 uur: ' .. item.json.Prices[gasid].price .. " (" .. domoticz.utils.round((item.json.Prices[gasid].price + m3Gas) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
    				    domoticz.log('There was a problem handling the request. Returned XML item is not ok.', domoticz.LOG_INFO)
    				        domoticz.log('Gasprijzen tijdelijk niet beschikbaar ivm onderhoud. HTTP statuscode: ' .. item.statusCode .. ' - ' .. item.statusText, domoticz.LOG_INFO)
