Netatmo Public data
Toulon7559
Domoticz version: <2025
Netatmo Public data
Post by Toulon7559 »
Not having a Netatmo-weatherstation myself, but interested to compare online.
Was able to get an extraction via Netatmo's Public API towards a JSON-file, but now next stage is extracting the data of a specific station out of that file.
Example json-file
"land": "DE",
"stad": "Borkum",
"straat": null,
"id": "70:ee:50:16:11:34",
"lat": 53.586141,
"lon": 6.662984,
"tijdzone": "Europe\/Berlin",
"tijd": "2022-11-20 17:47:54",
"measures": {
"temperature": 3.6,
"humidity": 88,
"pressure": 1004.4
"land": "DE",
"stad": "Borkum",
"straat": null,
"id": "70:ee:50:36:f3:40",
"lat": 53.5905,
"lon": 6.6623173,
"tijd": "2022-11-20 17:46:05",
"measures": {
"temperature": 3.8,
"humidity": 75,
"pressure": 1021.4,
"rain_60min": 0,
"rain_24h": 0.30300000000000005,
"rain_live": 0,
"rain_timeutc": "2022-11-20 17:45:51",
"wind_strength": 5,
"wind_angle": 51,
"gust_strength": 9,
"gust_angle": 66,
"wind_timeutc": "2022-11-20 17:46:04"
"land": "DE",
"stad": "Borkum",
"straat": null,
"id": "70:ee:50:1d:f4:a6",
"lat": 53.5821430898812,
"lon": 6.66388392448425,
"tijd": "2022-11-20 17:46:16",
"measures": {
"temperature": 3.2,
"humidity": 78,
"pressure": 1004.6,
"rain_60min": 0,
"rain_24h": 0.202,
"rain_live": 0,
"rain_timeutc": "2022-11-20 17:46:07"
"land": "DE",
"stad": "Greetsiel",
"straat": null,
"id": "70:ee:50:01:c5:fc",
"lat": 53.500934,
"lon": 7.095159,
"tijd": "2022-11-20 17:50:17",
"measures": {
"temperature": 2.5,
"humidity": 80,
"pressure": 1009,
"rain_60min": 0,
"rain_24h": 0.6060000000000001,
"rain_live": 0,
"rain_timeutc": "2022-11-20 17:50:08",
"wind_strength": 1,
"wind_angle": 236,
"gust_strength": 3,
"gust_angle": -1,
"wind_timeutc": "2022-11-20 17:50:15"
"land": "DE",
"stad": "Krummh\u00f6rn",
"straat": null,
"id": "70:ee:50:1b:29:92",
"lat": 53.4990946,
"lon": 7.10417989999996,
"tijd": "2022-11-20 17:50:38",
"measures": {
"temperature": 3.2,
"humidity": 81,
"pressure": 1007.8
"land": "DE",
"stad": "Landkreis Aurich",
"straat": null,
"id": "70:ee:50:00:51:08",
"lat": 53.6007662523399,
"lon": 7.17545628547668,
"tijd": "2022-11-20 17:49:21",
"measures": {
"temperature": 2.9,
"humidity": 78,
"pressure": 1010.5,
"rain_60min": 0,
"rain_live": 0,
"rain_timeutc": "2022-11-20 17:49:19"
The difficulty is that the various segments/station have no numbering in the sequence within the file, but are virtually stand-alone.
Have tried with a Python3.x's find-function to determine location with a specific 'ïd"as identifier (which as MAC-address is unique per station), but without success.
Anybody a hint/example for an alternative approach?
Last edited by Toulon7559 on Thursday 01 December 2022 21:15, edited 2 times in total.
Re: Netatmo Public data
Put the JSON in a table , perform a length of the array with #table
Then you can run through them until you reach a specific field that matches your station eg stad = xxxx Then you can get the results for that station.
For an example see stookalert script on wiki that searches for a provincie https://www.domoticz.com/wiki/StookAlert
Toulon7559
Walter,
;-) Biased to using Python instead of dzVents.
But triggered by your hint, I changed the searchkey and found this description:
the example-input for it's solution5 has almost same layout as the json-file which is input for my application.
Fiddled with the various entries of the demonstration-script for solution5, and with the selected 'ïd" the related segment now is extracted!
That cleanly reduces the future effort to dissecting of the selected segment of the json-file.
Last edited by Toulon7559 on Tuesday 22 November 2022 0:16, edited 2 times in total.
No problem :-) How is your memory doing while running python scripts within Domoticz 2022.2 Stable?
Toulon7559
Aspect = CPU Capacity
All RPIs run mixture of scripts: Domoticz, Lua, Python and dzVents.
1*RPI_B (with many scripts) running at average 70~76% CPU_Usage, without problems.
1*RPI_3A+ (with many scripts) at this moment running at 20% CPU_Usage, but occasionally flipping out and very slow with webrefresh, apparently with overload [although with 'original' power supply]. Sometimes restart_after_flipping is very slow. Probably need to reduce the 'occupation' of that machine.
Several RPI3Bs running at CPU_Usage of 20% or less.
RPI_Zeroes (as 'satellites') have very low load in scripts and seldomly have problems.
Have impression that load-peaks only occur at 'favourite times' when refreshes are done:
around midnight e.g. now the RPI_B hitting 97% CPU_Usage.
On purpose working with timing-offsets in the scripts and with scheduled execution of scripts.
Last edited by Toulon7559 on Thursday 24 November 2022 14:51, edited 2 times in total.
You are talking about CPU, I wanted to know your memory usage experience. As there seemed to be some memory leakage with python scripts within Domoticz due to the new python framework.
Toulon7559
Aspect = MemoryUsage
Present MemoryUsage as reported by Domoticz for 'Motherboard'
RPI_B at 60% ~ 80%
RPI3A+ at approx. 40%
RPI3Bs at <20%
RPI_Zeroes at 15% ~ 35%
No idea whether of influence, but my running Python-scripts still mostly Python2.x, although transition planned to Python3.x related to shift to Raspian_Bullseye. Functionally no reason to change for most scripts, therefore no push to change for the older software still running on the Buster-RPIs.
Last edited by Toulon7559 on Friday 25 November 2022 15:42, edited 2 times in total.
Toulon7559
Making some progress with extraction of specific station-data from the NetatmoPublic-output, but ;-) next hurdle present as shown in the spoiler below, which shows debugging-output from the Python3-script.
The string-search-result shown as Country = 4 etc. comes from the script-lines shown further down this message.
Step1 = Check presence of Netatmo_ID
string exists in the file
Step2_basic = find location of ID using specific file-name and specific id-name
[{'land': 'DE', 'stad': 'Borkum', 'straat': None, 'id': '70:ee:50:36:f3:40', 'lat': 53.5905, 'lon': 6.6623173, 'tijdzone': 'Europe/Berlin', 'tijd': '2022-11-23 10:42:49', 'measures': {'temperature': 8.4, 'humidity': 96, 'pressure': 1011.2, 'rain_60min': 0, 'rain_24h': 0.202, 'rain_live': 0, 'rain_timeutc': '2022-11-23 10:30:11', 'wind_strength': 3, 'wind_angle': 359, 'gust_strength': 10, 'gust_angle': 12, 'wind_timeutc': '2022-11-23 10:42:47'}}]
Step2_improved, by using parameters from setup-info
Step2_improved, with string_output
Step3 = Find startposition of strings
Country = 4
Place = 18
Street = 18
ID = 52
Lat = 4
Lon = 4
TimeZone = 19
Time = 19
Measures = 31
Temperature = 2
Humidity = 206
Barometer = 129
Rain01Hr = 28
Rain24Hr = 28
RainLive = 28
RainTime = 28
Wind_speed = 333
Wind_angle = 333
Gust_speed = 343
Gust_angle = 343
WindTime = 333
Raw values, actual
DE
Borkum
None
70:ee:50:36:f3:40
53.5905
6.6623173
Europe/Berlin
2022-11-23 10:42:49
8.4
96
1011.2
0
0.20
'2022-11-23 10:30:1
To extract data from a textstring, it is required to determine the start and the end of de data-field.
In this case the standard find()-function of Python does not always produce correct info.
As alternative now using the following function in the script.
# Line 201 = Find location of strings
print
print('Find startposition of strings')
def find_str(s, char):
    index = 0
    if char in s:
        char = char[0]
        for ch in s:
            if ch in s:
                index += 1
            if ch == char:
                return index
    else:
        return -1
# Line 220 = Find presence and locations
print('Country = ',(find_str(Station_segment, "land")))
IMHO nothing exotic in the text-string.
Result of the string-search is OK for the 1st field, but becomes erratic for all searches further away,
even duplicate reporting for some different string-locations.
Have tried several other string-search-scripts on the strings shown in the spoiler, but not much different.
Also translated back the string into JSON-file and then extract, but no better result.
Pragmatic, simple way out for the erroneuous sections is to manually count positions in the string,
and start with use of a read-out with script-code like below.
For the subsequent field-positons xxStart and xxEnd no string-search as basis, but just application of found offsets.
# Line xxx = Find actual data for this station
# Readout_command is <string_name>[a,b] with a = startposition and b = endposition within the string
# Ideal is to have a and b filled-in by values from string-search + offset-algorithm
# Values in the next, 1st segment have fixed length within station-messages, but variable per station
# xxStart = 1st character of value, xxEnd = last character of value
LandPos = find_str(Station_segment, "land")
LandStart = LandPos + 7
LandEnd = LandStart + 2 # Fixed NC for Country-value
Land = Station_segment[LandStart:LandEnd]
As shown in the lines below line 'Raw values, actual', that is stable for static information, but plays havoc for fields with dynamically variable length of the values. From the read-outs it almost looks that the spacing between the strings is variable (which should not be).
Looking for a better function to get correct positions of start and end of dynamic value-fields within a string.
Or alternative search-setup directly operating on the big JSON-file, mentioned/shown in this previous message.
Last edited by Toulon7559 on Friday 25 November 2022 15:46, edited 2 times in total.
Not exactly sure what your problem is.
But by converting the json into a python dict it will autmatically link entry with value eg
# JSON string
employee ='{"id":"09", "name": "Nitin", "department":"Finance"}'
# Convert string to Python dict
employee_dict = json.loads(employee)
print(employee_dict['name'])
Will print:
Nitin
https://www.geeksforgeeks.org/read-writ ... ng-python/
Toulon7559
Walter,
In general get the impression, that the erratic results may come from missing some subtleties when setting the found scripts and functions in relation to Python3.x.
Have to better study/understand the information.
The route via the dictionary could be extended to make a a json-file which may be queried the usual way:
surely quickest option, therefore primary target for my effort, but (for me) yet with least success.
Although a clumsier approach, quicker results expected with string-search and related value-extraction.
Have now more studied the find()-function and it's brethern
=> have to retry string-search with other layout.
If reason, will adapt my previous message to reflect any findings, or in this message, or in a next message.
Addition 23rd of November, 2022:
Have further tested with string-search using Python's find()-function.
Enclosed as demonstration why looking for other solutions.
The 1st spoiler shows the script-segment doing the work on the Datablock:
- the find()-function looks for start-position of designated text
- the boundary-settings for reading require manual counting positions for the offsets (should be stable and once only for the max. layout of messages)
- the read-function is simple/straightforward working on the Datablock with the parameterized boundary-settings.
# Result of string-find on purpose integer to suppress any possible jitter due to estimation.
# Ideal is to have a and b filled-in by values from section above
# Formulas for string-search from previous section.
# Line xxx = Values in the next, 1st segment have fixed length within station-messages, but variable per station
# xxStart = position of 1st character of value, xxEnd = position of last character of value
# Offset between the value-fields should be fixed Number of Characters
# Line xxx = Extract positions for start and end of values and extract values
IDStart = int(Datablock.find("id")) + 6
IDEnd = IDStart + 17 # Fixed NC for MAC-address
ID = Datablock[IDStart:IDEnd]
LatStart = int(Datablock.find("lat")) + 5
LatEnd = int(Datablock.find("lon")) - 3
Latitude = Datablock[LatStart:LatEnd]
LonStart = int(Datablock.find("lon")) + 5
LonEnd = int(Datablock.find("tijdzone")) - 3
Longitude = Datablock[LonStart:LonEnd]
TZStart = int(Datablock.find("tijdzone")) + 13
TZEnd = int(Datablock.find("tijd")) - 5
Time_Zone = Datablock[TZStart:TZEnd]
TLStart = int(Datablock.find("tijd")) + 7
TLEnd = TLStart + 19 # Fixed NC for Date&Time
DateTime_Local = Datablock[TLStart:TLEnd]
DateStart = TLStart
DateEnd = DateStart + 10 # Fixed NC for Date
Date = Datablock[DateStart:DateEnd]
TimeStart = DateEnd + 2
TimeEnd = TimeStart + 5 # Fixed NC for Time
Time = Datablock[TimeStart:TimeEnd]
TempStart = int(Datablock.find("temperature")) + 15
TempEnd = int(Datablock.find("humidity")) - 5
TempC = Datablock[TempStart:TempEnd]
RHStart = int(Datablock.find("humidity")) + 13
RHEnd = int(Datablock.find("pressure")) - 13
RelHum = Datablock[RHStart:RHEnd]
PStart = int(Datablock.find("pressure")) + 12
PEnd = PStart + 6 # No dependency on Rain-info, but fixed NC
Baro = Datablock[PStart:PEnd]
# Line xxx = Variable presence of Rain Data
if Raingauge_status > 0:
R1Start = int(Datablock.find("rain_60min")) + 13
R1End = int(Datablock.find("rain_24h")) - 4
Rain01Hr = Datablock[R1Start:R1End]
R2Start = int(Datablock.find("rain_24h")) + 11
R2End = int(Datablock.find("rain_live")) - 4
Rain24Hr = Datablock[R2Start:R2End]
R3Start = int(Datablock.find("rain_live")) + 12
R3End = int(Datablock.find("rain_timeutc")) - 4
RainLive = Datablock[R3Start:R3End]
R4Start = int(Datablock.find("rain_timeutc")) + 15
R4End = R4Start + 19 # Fixed NC for Date and Time
RainTime = Datablock[R4Start:R4End]
else:
Rain01Hr = Invalid
Rain24Hr = Invalid
RainLive = Invalid
RainTime = Invalid
# Line xxx = Variable presence of Wind Data
if Anemometer_status > 0:
W1Start = Datablock.find("wind_strength") + 15
W1End = Datablock.find("wind_angle") - 3
WindS = Datablock[W1Start:W1End]
W2Start = Datablock.find("wind_angle") + 13
W2End = Datablock.find("gust_strength") - 3
WindD = Datablock[W2Start:W2End]
W3Start = Datablock.find("gust_strength") + 15
W3End = Datablock.find("gust_angle") - 3
WindG = Datablock[W3Start:W3End]
W4Start = Datablock.find("gust_angle") + 13
W4End = Datablock.find("wind_timeutc") - 3
WindGD = Datablock[W4Start:W4End]
W5Start = Datablock.find("wind_timeutc") + 16
W5End = W5Start + 19 # Fixed NC for Date and Time
WindTime = Datablock[W5Start:W5End]
else:
WindS = Invalid
WindD = Invalid
WindG = Invalid
WindGD = Invalid
WindTime = Invalid
# Line 0xxx = Check by print
if DEBUG == 1:
print
print('Raw values, actual; from Datablock')
# print(Land)
# print(Stad)
# print(Straat)
print(ID)
print(Latitude)
print(Longitude)
print(Time_Zone)
print(DateTime_Local)
print(Date)
print(Time)
print(TempC)
print(RelHum)
print(Baro)
print(Rain01Hr)
print(Rain24Hr)
print(RainLive)
print(RainTime)
print(WindS)
print(WindD)
print(WindG)
print(WindGD)
print(WindTime)
The 2nd spoiler shows 'print' of the text/layout of the Datablock containing the text on which the script operates,
the position-reports by the related print-statements and
the prints from read-out using the position-reports translated to boundary-settings for reading.
Length of Datablock = 404 characters
Datablock:
'id': '70:ee:50:36:f3:40', 'lat': 53.5905, 'lon': 6.6623173, 'tijdzone': 'Europe/Berlin', 'tijd': '2022-11-23 19:56:49', 'measures': {'temperature': 7.6, 'humidity': 95, 'pressure': 1011.8, 'rain_60min': 0.505, 'rain_24h': 0.808, 'rain_live': 0.101, 'rain_timeutc': '2022-11-23 19:56:37', 'wind_strength': 5, 'wind_angle': -1, 'gust_strength': 15, 'gust_angle': 359, 'wind_timeutc': '2022-11-23 19:56:44'
ID = 1
Lat = 28
Lon = 44
TimeZone = 62
Time = 62
Measures = 122
Temperature = 133
Humidity = 155
Barometer = 171
Rain01Hr = 191
Rain24Hr = 212
RainLive = 231
RainTime = 251
Wind_speed = 290
Wind_angle = 310
Gust_speed = 328
Gust_angle = 349
WindTime = 368
70:ee:50:36:f3:40
53.5905
6.6623173
e': 'Europe/Berlin'
e': 'Europ
Berli
011.8,
0.50
0.80
0.10
'2022-11-23 19:56:3
5
-1
15
359
2022-11-23 19:56:44
Observations:
- the text in the Datablock looks OK
- the position read-outs with the find()-function also look OK
- the information from reading in some cases seems usable, but for most other fields the reading bracket is shifting without reason.
Last edited by Toulon7559 on Friday 25 November 2022 15:48, edited 10 times in total.
This seems to work to find the temperature of station with id "70:ee:50:36:f3:40"
import json
test_list = '[ { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:16:11:34", "lat": 53.586141, "lon": 6.662984, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:47:54", "measures": { "temperature": 3.6, "humidity": 88, "pressure": 1004.4 } }, { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:36:f3:40", "lat": 53.5905, "lon": 6.6623173, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:46:05", "measures": { "temperature": 3.8, "humidity": 75, "pressure": 1021.4, "rain_60min": 0, "rain_24h": 0.30300000000000005, "rain_live": 0, "rain_timeutc": "2022-11-20 17:45:51", "wind_strength": 5, "wind_angle": 51, "gust_strength": 9, "gust_angle": 66, "wind_timeutc": "2022-11-20 17:46:04" } }, { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:1d:f4:a6", "lat": 53.5821430898812, "lon": 6.66388392448425, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:46:16", "measures": { "temperature": 3.2, "humidity": 78, "pressure": 1004.6, "rain_60min": 0, "rain_24h": 0.202, "rain_live": 0, "rain_timeutc": "2022-11-20 17:46:07" } }, { "land": "DE", "stad": "Greetsiel", "straat": null, "id": "70:ee:50:01:c5:fc", "lat": 53.500934, "lon": 7.095159, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:50:17", "measures": { "temperature": 2.5, "humidity": 80, "pressure": 1009, "rain_60min": 0, "rain_24h": 0.6060000000000001, "rain_live": 0, "rain_timeutc": "2022-11-20 17:50:08", "wind_strength": 1, "wind_angle": 236, "gust_strength": 3, "gust_angle": -1, "wind_timeutc": "2022-11-20 17:50:15" } }, { "land": "DE", "stad": "Krummh\u00f6rn", "straat": null, "id": "70:ee:50:1b:29:92", "lat": 53.4990946, "lon": 7.10417989999996, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:50:38", "measures": { "temperature": 3.2, "humidity": 81, "pressure": 1007.8 } }, { "land": "DE", "stad": "Landkreis Aurich", "straat": null, "id": "70:ee:50:00:51:08", "lat": 53.6007662523399, "lon": 7.17545628547668, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:49:21", "measures": { "temperature": 2.9, "humidity": 78, "pressure": 1010.5, "rain_60min": 0, "rain_24h": 0.30300000000000005, "rain_live": 0, "rain_timeutc": "2022-11-20 17:49:19" } } ]'
test_list_dict = json.loads(test_list)
# Find dictionary matching value in list
res = None
for sub in test_list_dict:
    if sub['id'] == "70:ee:50:36:f3:40":
        res = sub
        break
# printing result
print("The filtered station data is : " + str(res))
print("The temperature : " + str(res['measures']['temperature']))
Result:
The filtered station data is : {'land': 'DE', 'stad': 'Borkum', 'straat': None, 'id': '70:ee:50:36:f3:40', 'lat': 53.5905, 'lon': 6.6623173, 'tijdzone': 'Europe/Berlin', 'tijd': '2022-11-20 17:46:05', 'measures': {'temperature': 3.8, 'humidity': 75, 'pressure': 1021.4, 'rain_60min': 0, 'rain_24h': 0.30300000000000005, 'rain_live': 0, 'rain_timeutc': '2022-11-20 17:45:51', 'wind_strength': 5, 'wind_angle': 51, 'gust_strength': 9, 'gust_angle': 66, 'wind_timeutc': '2022-11-20 17:46:04'}}
The temperature : 3.8
Toulon7559
Walter,
Work for later this week to implement & try your setup in 'my environment'.
Anton
Toulon7559
Walter,
The data of a selected station is extracted from a big JSON-file containing all Netatmo-stations found within the search-window.
The big JSON-file is called /home/pi/netatmo.json
The extract is an outputstring called Station_segment.
The Python-scriptsegment for the extraction is at scriptline 172 till 202 in the 1st spoiler, with results shown in the 1st part of spoiler2.
Have inserted your test-script in my script at script-line 205 and the original runs without problems.
When switching the input from your test_list to outputstring Station_segment,
then the error reports appear as shown at the end of spoiler2.
Apparently a type-missmatch to be solved .......
# Line 172 = Step2, Find location of Identifier
print
print('Step2_basic = find location of ID using specific file-name and specific id-name')
# Open the existing JSON file for loading into a variable
with open('/home/pi/netatmo.json') as jsondata:
data = json.load(jsondata)
# Search data based on specific key and specific value using filter and list method
print(list(filter(lambda x:x["id"]=="70:ee:50:36:f3:40",data)))
# Line 182 = Step2a, Find location of Identifier
print
print('Step2_improved, using parameters from setup-info')
with open(Netatmo_file) as jsondata:
# Search data based on specific key and parameterized value using filter and list method
print(list(filter(lambda x:x["id"]==Netatmo_ID,data)))
# Line 192 = Step2b, Find location of Identifier & extract related segment of JSON-file
print
print('Step2_improved, with segment_extract and string_output')
Station_segment = str(list(filter(lambda x:x["id"]==Netatmo_ID,data)))
print('Station_segment_string = ')
print(Station_segment)
# Line 205 = Read String + Make Dictionary + Extract Data
import json
# test_list = '[ { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:16:11:34", "lat": 53.586141, "lon": 6.662984, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:47:54", "measures": { "temperature": 3.6, "humidity": 88, "pressure": 1004.4 } }, { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:36:f3:40", "lat": 53.5905, "lon": 6.6623173, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:46:05", "measures": { "temperature": 3.8, "humidity": 75, "pressure": 1021.4, "rain_60min": 0, "rain_24h": 0.30300000000000005, "rain_live": 0, "rain_timeutc": "2022-11-20 17:45:51", "wind_strength": 5, "wind_angle": 51, "gust_strength": 9, "gust_angle": 66, "wind_timeutc": "2022-11-20 17:46:04" } }, { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:1d:f4:a6", "lat": 53.5821430898812, "lon": 6.66388392448425, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:46:16", "measures": { "temperature": 3.2, "humidity": 78, "pressure": 1004.6, "rain_60min": 0, "rain_24h": 0.202, "rain_live": 0, "rain_timeutc": "2022-11-20 17:46:07" } }, { "land": "DE", "stad": "Greetsiel", "straat": null, "id": "70:ee:50:01:c5:fc", "lat": 53.500934, "lon": 7.095159, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:50:17", "measures": { "temperature": 2.5, "humidity": 80, "pressure": 1009, "rain_60min": 0, "rain_24h": 0.6060000000000001, "rain_live": 0, "rain_timeutc": "2022-11-20 17:50:08", "wind_strength": 1, "wind_angle": 236, "gust_strength": 3, "gust_angle": -1, "wind_timeutc": "2022-11-20 17:50:15" } }, { "land": "DE", "stad": "Krummh\u00f6rn", "straat": null, "id": "70:ee:50:1b:29:92", "lat": 53.4990946, "lon": 7.10417989999996, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:50:38", "measures": { "temperature": 3.2, "humidity": 81, "pressure": 1007.8 } }, { "land": "DE", "stad": "Landkreis Aurich", "straat": null, "id": "70:ee:50:00:51:08", "lat": 53.6007662523399, "lon": 7.17545628547668, "tijdzone": "Europe\/Berlin", "tijd": "2022-11-20 17:49:21", "measures": { "temperature": 2.9, "humidity": 78, "pressure": 1010.5, "rain_60min": 0, "rain_24h": 0.30300000000000005, "rain_live": 0, "rain_timeutc": "2022-11-20 17:49:19" } } ]'
test_list = Station_segment
print('Dictionary =')
print(test_list_dict)
res = None
res = sub
break
# printing result
print
End of reading datafile
[{'land': 'DE', 'stad': 'Borkum', 'straat': None, 'id': '70:ee:50:36:f3:40', 'lat': 53.5905, 'lon': 6.6623173, 'tijdzone': 'Europe/Berlin', 'tijd': '2022-11-24 15:18:21', 'measures': {'temperature': 12.5, 'humidity': 79, 'pressure': 1023.4, 'rain_60min': 0, 'rain_24h': 0.30300000000000005, 'rain_live': 0, 'rain_timeutc': '2022-11-24 15:18:18', 'wind_strength': 1, 'wind_angle': 359, 'gust_strength': 5, 'gust_angle': 193, 'wind_timeutc': '2022-11-24 15:18:18'}}]
File "/home/pi/Python_scripts/JSON_NetatmoPublic_to_HWA03_xxxx_0198.py", line 212, in <module>
File "/usr/lib/python3.9/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.9/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.9/json/decoder.py", line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 1 column 3 (char 2)
Last edited by Toulon7559 on Thursday 24 November 2022 19:55, edited 2 times in total.
Try to change line
into
test_list_dict = json.load(jsondata)
Toulon7559
Easily tested, but unfortunately without progress:
IMHO some further study needed on the type-missmatch between the extracted text-string Station_segment and the required input-file to make the dictionary.
[{'land': 'DE', 'stad': 'Borkum', 'straat': None, 'id': '70:ee:50:36:f3:40', 'lat': 53.5905, 'lon': 6.6623173, 'tijdzone': 'Europe/Berlin', 'tijd': '2022-11-24 20:00:54', 'measures': {'temperature': 7.6, 'humidity': 96, 'pressure': 1024.3, 'rain_60min': 0, 'rain_24h': 0.30300000000000005, 'rain_live': 0, 'rain_timeutc': '2022-11-24 20:00:31', 'wind_strength': 3, 'wind_angle': -1, 'gust_strength': 6, 'gust_angle': 270, 'wind_timeutc': '2022-11-24 20:00:50'}}]
File "/usr/lib/python3.9/json/__init__.py", line 293, in load
return loads(fp.read(),
ValueError: I/O operation on closed file.
Some quick&easy experiments.
Looking at visual resemblance with your test_list tried the trick to add ' at head and tail by instruction
Station_segment = "'" + Station_segment + "'"
Produces textstring Station_segment_string2, but no luck for processing: just another error report.
[{'land': 'DE', 'stad': 'Borkum', 'straat': None, 'id': '70:ee:50:36:f3:40', 'lat': 53.5905, 'lon': 6.6623173, 'tijdzone': 'Europe/Berlin', 'tijd': '2022-11-24 20:10:59', 'measures': {'temperature': 7.6, 'humidity': 96, 'pressure': 1024.3, 'rain_60min': 0, 'rain_24h': 0.30300000000000005, 'rain_live': 0, 'rain_timeutc': '2022-11-24 20:10:59', 'wind_strength': 3, 'wind_angle': 359, 'gust_strength': 10, 'gust_angle': -1, 'wind_timeutc': '2022-11-24 20:10:59'}}]
Station_segment_string2 =
'[{'land': 'DE', 'stad': 'Borkum', 'straat': None, 'id': '70:ee:50:36:f3:40', 'lat': 53.5905, 'lon': 6.6623173, 'tijdzone': 'Europe/Berlin', 'tijd': '2022-11-24 20:10:59', 'measures': {'temperature': 7.6, 'humidity': 96, 'pressure': 1024.3, 'rain_60min': 0, 'rain_24h': 0.30300000000000005, 'rain_live': 0, 'rain_timeutc': '2022-11-24 20:10:59', 'wind_strength': 3, 'wind_angle': 359, 'gust_strength': 10, 'gust_angle': -1, 'wind_timeutc': '2022-11-24 20:10:59'}}]'
File "/home/pi/Python_scripts/JSON_NetatmoPublic_to_HWA03_xxxx_0198.py", line 213, in <module>
File "/usr/lib/python3.9/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
For more visual resemblance bluntly added the spaces at head and tail of the string around [ and { , respectively around } and ]
and replaced None by null, using 3 extra scriptlines
string0 = Station_segment.replace("'[{", "'[ { ")
string1 = string0.replace("None", "null")
Station_segment = string1.replace("}]'", " } ]'")
but that makes no difference.
Must be some required subtlety in the translation from text-string into JSON-file.
Last edited by Toulon7559 on Thursday 24 November 2022 21:26, edited 4 times in total.
The test list string is just a copy from the JSON in your first post. I only removed the new lines so it will become 1 string as the original JSON probably also is. How do you get the JSON from Netatmo? Can't you just download it within the python script?
Toulon7559
The big JSON-file giving the collection of Netatmo-station data is output of a PHP-script,
using original Netatmo API-call to get Public data available from the stations within a designated, geo-oriented search-window.
The idea is to have that big JSON-file as data-source for extraction for several selected stations, with separate extracting-script per selected station to extract the detailled data aimed/tuned at an application.
The single PHP-script periodically 'pulls' data from a remote server at internet, while the extracting-scripts as satellites locally perform their functions at 'convenient times', not loading the external interfaces.
Because of this 'demarcation', those extracting-scripts may be in any other language than PHP.
Myself not well-versed in PHP, but having the subsequent user-applications in Python,
is one reason to try Python for the interfacing software.
Meanwhile have pensively been triggered for another aspect of your test_list in which all textual elements enclosed in " ",
because of a statement found at W3Schools
In JSON, string values must be written with double quotes:
JSON
{"name":"John"}
That is applicable in the original JSON-file, but not in the extracted text-file Station_segment:
Is easy to remedy by scriptline
Station_segment = Station_segment.replace("'", '"')
Although the resulting stringprint looks very similar to your test_list, still the same error report
Station_segment_string3 =
'[ { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:36:f3:40", "lat": 53.5905, "lon": 6.6623173, "tijdzone": "Europe/Berlin", "tijd": "2022-11-24 23:42:49", "measures": {"temperature": 7.1, "humidity": 96, "pressure": 1023.8, "rain_60min": 0, "rain_24h": 0.404, "rain_live": 0, "rain_timeutc": "2022-11-24 23:42:28", "wind_strength": 3, "wind_angle": -1, "gust_strength": 12, "gust_angle": 261, "wind_timeutc": "2022-11-24 23:42:47"} } ]'
File "/home/pi/Python_scripts/JSON_NetatmoPublic_to_HWA03_xxxx_0198.py", line 220, in <module>
Mimick for subsitute of your test_file has been done, and strange thing is that your testscriptlines completely work if Station_segment_string3 is manually copied from Putty's CLI as substitute for the string in test_list in your proposed testscriptlines.
Next experiments are very rude try&error
It partlially works when I insert a scriptline with json.dumps() to catch the text-string Station_segment as input for making test_list
test_list = json.dumps(Station_segment)
res = None
    if sub["id"] == "70:ee:50:36:f3:40":
        res = sub
        break
# printing result
print
=> getting a dictionary, but stuck at subsequent finding of sub["id"]
Station_segment_string3 = change of head & tail
'[ { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:36:f3:40", "lat": 53.5905, "lon": 6.6623173, "tijdzone": "Europe/Berlin", "tijd": "2022-11-25 08:53:15", "measures": {"temperature": 8.1, "humidity": 97, "pressure": 1024.8, "rain_60min": 0.101, "rain_24h": 2.121, "rain_live": 0, "rain_timeutc": "2022-11-25 08:53:12", "wind_strength": 3, "wind_angle": -1, "gust_strength": 5, "gust_angle": 359, "wind_timeutc": "2022-11-25 08:53:12"} } ]'
Dictionary =
File "/home/pi/Python_scripts/JSON_NetatmoPublic_to_HWA03_xxxx_0198.py", line 230, in <module>
TypeError: string indices must be integers
Trying direct reading from that dictionary with scriptline
test_extract = test_list_dict["land"]
=> no luck, with same kind of error report
Dictionary =
'[ { "land": "DE", "stad": "Borkum", "straat": null, "id": "70:ee:50:36:f3:40", "lat": 53.5905, "lon": 6.6623173, "tijdzone": "Europe/Berlin", "tijd": "2022-11-25 09:23:30", "measures": {"temperature": 8.1, "humidity": 97, "pressure": 1025.2, "rain_60min": 0, "rain_24h": 2.121, "rain_live": 0, "rain_timeutc": "2022-11-25 09:23:20", "wind_strength": 3, "wind_angle": 11, "gust_strength": 5, "gust_angle": 216, "wind_timeutc": "2022-11-25 09:23:26"} } ]'
File "/home/pi/Python_scripts/JSON_NetatmoPublic_to_HWA03_xxxx_0198.py", line 228, in <module>
We seem to be missing something subtle in filehandling in Python3.x & JSON .......
Last edited by Toulon7559 on Thursday 01 December 2022 21:22, edited 1 time in total.
There is Python json.load() and json.loads() that behave different.
https://docs.python.org/3/library/json.html#basic-usage
Toulon7559
The PHP-script as mentioned in this thread has been changed to additionally provide a json-file per station:
should be easier to read by a recipient-application.
netatmo_70-ee-50-90-ca-8c.txt
Example json_file_per_station
(613 Bytes) Downloaded 97 times
Obviously the original issue with extension .json, but changed to extension .txt to suit inclusion in the forum-message.
Also found very pragmatic way to get a readable json-file:
- upload/write the json-file coming from the PHP-script to webserver
- download/read that json-file from this webserver.
Do not ask 'Why', but then all 'usual' functions for read-out of data are without problem.
:? Just 'questionmark', why failing if trying to directly read the json-file 'inside' a Raspberry .......
