[SOLVED]Wrong Temp FGMS001 with Auto discovery Z-Wave JS
ressof
Domoticz version: Latest
Post by ressof »
I switched from OpenZwave to ZWave JS UI and everything went fine except that two Fibaro FGMS001 devices shows wrong temperature in domoticz. It shows the correct temp in ZWave JS. Im using the new MQTT AutoDiscover in domoticz.
Is there a way to check the MQTT message if the temp is correct from Zwave JS or the problem is in domoticz?
Edit Seems to be some Celcius to Farenheit conversion. But all other temperatures are set to celcius
Seems to be solved in latest update
https://github.com/domoticz/domoticz/co ... 74c570405f
Re: [SOLVED]Wrong Temp FGMS001 with Auto discovery Z-Wave JS
So was it solved for you in Beta 14742? As this change is in that version.
