motion sensor
denismsd
motion sensor
Post by denismsd »
hello everyone, I need help with a blockly, if my motion sensor does not detect it for 20 minutes it turns off the living room light and kitchen light
Treve
Domoticz version: v4.11474
Re: motion sensor
Post by Treve »
denismsd wrote:hello everyone, I need help with a blockly, if my motion sensor does not detect it for 20 minutes it turns off the living room light and kitchen light
Can you give a better explanation of your problem?
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
denismsd
Re: motion sensor
Post by denismsd »
thanks for the feedback, I have 2 lamps in the room, and sometimes I forget the lamps are on, so I put an esp8266 wemos d1, inside a presence sensor I configured it with tasmota, now every time there is movement in the room it sends a signal to domoticz . I wanted to put a rule with blockly , if the presence sensor is not detected for 20 minutes it turns off the lamps .
Domoticz version: 2025.1
Re: motion sensor
Check this example viewtopic.php?t=27398
willemd
Domoticz version: 2024.1
Re: motion sensor
Post by willemd »
1) create a device that counts from 1 to 20 (or vice versa if you want a countdown)
2) trigger the device every minute and increase the value with 1
2) if 20 is reached then switch of the lights
3) if motion is detected then reset the counter
