sbfspot empty data path
Posted: Saturday 19 November 2022 18:43
by Gianni
Hello
everything run in docker envoirement.
No i just setup sbf spot in a new docker and setup the domoticz plugin.
But i got this error
2022-11-19 18:40:21.768 Error: sma: Data path empty!
MY path go the the correct config file and my DB is not Empty so sbf works
- sbf2.png (16.33 KiB) Viewed 666 times
- sbf1.png (13.03 KiB) Viewed 666 times
Any idee's
Re: sbfspot empty data path
Posted: Saturday 19 November 2022 23:22
by waltervl
As you are in a Docker you have to specify the location of the cfg file as you are in docker and not from the point of view outside the docker.
Posted: Sunday 20 November 2022 3:30
by Gianni
Hey WalterVL
Now i'm lost how can i point to the file inside the container from outside?
grts Gianni
Posted: Sunday 20 November 2022 15:47
by waltervl
I am not a Docker fan, just for this reason. Making everything a bit more complex. And as there are more docker versions of Domoticz each behaves different...
So the cfg file needs to be accessible from Domoticz in the docker. There are more docker users that can explain where it should be.
Posted: Sunday 05 March 2023 21:01
by skippy711
Following up on this post:
After a lot of testing I migrated the 'traditional' Domoticz to a Docker set up, managed to get everything up and running (Zwave2MQTT in Docker, Speedtest in Docker, plugins for Buienradar, Presence detection, Pi-hole and Kodi, scripts for backup and SNMP monitoring, P1 and OTGW) like a charm but I haven't figured out the way to point to the SBFspot.cfg. Who can help?
I appreciate waltervl's comment (I was not a Docker fan myself but gradually I managed).
Perhaps I can get SBFspot in Docker running MQTT and then do MQTT --> Domoticz, but for now I like SBFspot -> Domoticz Docker
Any help is appreciated!
