ThesslaGreen recuperator integration - plugin
Posted: Wednesday 16 November 2022 16:06
by voyo
I have developed domoticz plugin which helps me integrate my ThesslaGreen recuperator over RS485 modbus connectivity (available even as basic functionality of the device).
https://thesslagreen.com/product/airpack4h/
Plugin should work with all AirPack family models, however was tested only with AirPack4 500h
supported functionality -
reading temperature: outside, supply, exhaust , fpx, duct_supply, gwc, ambient
reading AirFlow: supply and exhaust
Possibility to turn on/off, read/set special flow mode.
Plugin is available to download from
https://github.com/voyo/ThesslaGreen-modbus
Re: ThesslaGreen recuperator integration - plugin
Posted: Wednesday 16 November 2022 17:09
Thanks for the plugin! I added it to the wiki https://www.domoticz.com/wiki/Plugins
Posted: Saturday 09 September 2023 14:17
by BartekKo
Hi, is there any chance that You will also share phisical connection in form od diagram or something?
Posted: Saturday 09 September 2023 14:28
by voyo
BartekKo wrote: Saturday 09 September 2023 14:17 Hi, is there any chance that You will also share phisical connection in form od diagram or something?
you mean like this ?
https://github.com/voyo/ThesslaGreen-mo ... C5%82y.pdf
Posted: Wednesday 29 October 2025 12:02
by Morek86
Hey,
Is there possibility to add Switch selector for setting up manuall airflow on 30% 60% 80% for example?
Posted: Tuesday 18 November 2025 2:17
by voyo
Morek86 wrote: Wednesday 29 October 2025 12:02 Hey,
Yes, it's possible to add a selector switch for manual airflow levels. 8-)
However, I'm not sure I'd use it myself, so my motivation to implement it is pretty low. In my setup, I keep the unit running at 10% constantly (off at night), and just hit the ventilation button manually when needed for a quick boost.
If you have a specific use case where scheduled airflow changes would be useful, let me know - might change my mind.
Posted: Wednesday 21 January 2026 1:53
by voyo
New version available on github -
Fixed negative temperature readings for outside_temp and fpx_temp sensors in pymodbus mode.
