Dial shows wrong value Topic is solved
isis59
Post by isis59 »
I have a problem with a dial block.
The IDX is the right one. It modifies the value of my temp meter, but once updated, it goes back to a wrong value...
here's the script of the block :
blocks['tempSalon'] = {
        type: 'dial',
        idx: 445,
        title: 'Thermostat',
        temp: 595,
        width: 8,
        showunit: true,
        values: [
                idx: 595,
                value: 'Humidity',
                label: 'Hum.',
                unit: '(%)',
Thanks for your help.
I'm running the last 2022.2 domoticz version, and the last dashticz version.
HansieNL
Re: Dial shows wrong value
Post by HansieNL »
You can use the dial to set the temperature yourself (setpoint) or Domoticz can send new temperature value. Maybe Domoticz did just sent new temperature value when you tried to set the setpoint.
Can you try with config['enable_websocket'] = 0; to see if you still have the problem.
Blah blah blah
isis59
Post by isis59 »
Yes, if i modify the value in domoticz, it is sent to dashticz, but this value was bad interpreted.
Following your answer, I just checked and modified the definition of the dial. I don't know exactly why, but t seems to be good now.
