Timer only when device is on
Cyroq
Post by Cyroq »
Hi, is it possible to only run a timer script when a specific device is on? Of course I could run a timer script and put everything in an if-statement like
if (dz.devices('devicename') == 'On') then
but that floods my log file big time if the timer is run every minute 24/7. The script will in reality only be active 10 minutes a day, so it runs 10 times. It is triggered by a (dummy) device.
mgugu
Re: Timer only when device is on
Post by mgugu »
boum
Domoticz version: 4.10717
Post by boum »
You can also change your script to trigger only on your dummy device and when triggered to On, execute a buncho of dz.emitEvent('customname', {...}).afterMin(X).
You can have another script with customEvents trigger. Or do that in your device script too.
You can also execute a single custom event in the first script, and in the second one, trigger it again as long as some condition is met.
Neutrino
Domoticz version: 2021.1
Post by Neutrino »
I'm using this :
	active = function(domoticz)
		return (domoticz.devices('devicename').state == 'On')
	end,
	--active = true,
		timer = {'every minute'},
Cyroq
Post by Cyroq »
Thanks @Neutrino, that's a neat solution! Works perfectly.
@boum I'm hesitant using AfterMin() because it's complex to cancel the operation mid way, if I'd want that. But I didn't know about the customEvents trigger, might come in handy later 8-)
