IKEA Motion sensor (new type)
peterbos
Post by peterbos »
I have an IKEA motion sensor 704.299.13, the new and smaller type. I installed it in our hallway to test it with the idea to use it for switching off the lamps if there's no one in the hallway. I don't need it to switch the lamps on.
Without automation the sensor is pretty useless. Exactly a minute after the sensor switched on, it switches off - regardless if there's still (or again) any motion. It even takes tens of seconds after that before the sensor switches on again if there's still motion. The time between switching off and on again is not constant, unlike the time between switching on and off again. The only solution I see now is to create a virtual sensor, that gets on when the motion sensor goes on. The virtual sensor should ignore the motion sensor switching off, but should switch itself off after - say - two minutes after the last time it was switched on. If the motion sensor switches on again in these two minutes, the two minutes should start again. In dzVents I created this script. Does anyone already have a better implementation of the sensor?
		devices = {'Bewegingssensor (hal)'}, -- the motion sensor
	execute = function(dz, device)
	    local virtualDevice = dz.devices('Bewegingssensor (hal, virtueel)') -- the virtual motion sensor
	    local delay = 120
	    if (virtualDevice.active) then
	        virtualDevice.switchOff().afterSec(120)
            virtualDevice.switchOn().forSec(120)
Peter
Re: IKEA Motion sensor (new type)
How do you communicate with your zigbee environment as most plugins/controller ui like zigbee2mqtt and zigbee for Domoticz have options to set behavior of motion sensors.
peterbos
Post by peterbos »
Hi Walter,
I just connected it to Phoscon app (deConz, Conbee II).
Peter
Then please check the phoscon documentation how to change the parameters of this motion device.
