zigbee2MQTT
rolandtwilt
zigbee2MQTT
Post by rolandtwilt »
Good afternoon, I have the following LED strip controller https://www.zigbee2mqtt.io/devices/TS05 ... 3e5fy1YGmy there is quite a lot of information but not how to pair this device, does anyone know? thanks in advance
Domoticz version: 2025.1
Re: zigbee2MQTT
Perhaps this helps: https://support.tuya.com/en/help/_detail/K9mch3ca38pvz
How to reset the Zigbee device to the state to be configured?
Last Updated on:
2022-05-17 08:15:32
Dear user, we are sorry for your inconvenience. You can follow the steps below (this is a general method, please refer to the product manual for specific methods):
Devices with a reset button: Firstly, make sure the device is powered off for more than 10 seconds before powering on the device. Then long press the reset button on the device for about 5 seconds (for switch devices, the reset button is mostly the switch Button itself). Wait a few moments until the indicator light starts blinking rapidly. The device enters the pairing mode. You can add it now.
Lighting equipment: Firstly, make sure the device is powered off for more than 10 seconds before powering on the device. Then turn on and off three times (on-off-on-off-on) power of the device (2 to 4 seconds between each on and off). Wait a few moments until the lighting starts blinking rapidly. The device enters the pairing mode.You can add it now.
rolandtwilt
Re: zigbee2MQTT
5 times power off and on is the right combination. The LED strip blinks, it is in pairing mode. I get the following warning:
Warning Received message from unsupported device with Zigbee model 'TS0503B' and manufacturer name '_TZ3210_95txyzbx'
Warning Please see: https://www.zigbee2mqtt.io/advanced/sup ... vices.html
And that's weird what the log says about a Zigbee model 'TS0503B' and it's a Zigbee model 'TS0503A'
Re: zigbee2MQTT
The logs shows what the device sends.....
