TeleInfo STANDARD Mode Incorect Usage
gregory69
Domoticz version: 2022.1
Post by gregory69 »
Hello All ! I am a big fan of the Teleinfo hardware plugin which is really powerful !
I recently asked ENEDIS to switch from HISTORIQUE mode to STANDARD mode, they did it and I changed the frequency at 9600 bauds. I am now receiving more info such as the voltage, intensity and more to come ! So far everything was working great.
However I have noticed that the power usage in KWh displayed in the week & months graphs are completely wrong. According to the charts I'm consuming 40MWh per day...
Teleinfo 1 2022-11-06.png (89.86 KiB) Viewed 2703 times
This is so strange because the daily usage is correct and the overall index seems also correct !
Teleinfo 2 2022-11-06.png (17.68 KiB) Viewed 2703 times
It was working well before ENEDIS made the change, any thoughts ?
Thanks !
gregory69
Re: TeleInfo STANDARD Mode Incorect Usage
Post by gregory69 »
After 3 days of data, I actually noticed that the usage is correct but contains 40000KWh more...
For example yesterday measurement 40,015,14 ... The real value is 15,14... I don't understand what the issue is...
gregory69
Post by gregory69 »
I could not find the issue... Some incoherent values still go in even with the CRC activated. I am not filtering the data with a dummy sensor that takes into account value only if they are bigger than the last one;
