I spent this am so far upgrading my Domoticz to the new version (Thank you!), and coding a new, simpler thermostat for my heaters. I figure I should share this. It is very simple, but someone might find it useful.
You need to create a virtual thermostat for this script. This will allow you to set the temperatures very easily via the main GUI, including on a timer, for overnight, etc. I have a 'Status' variable in my setup, so my home knows when I am 'Away', 'Home', etc. The script will reduce heating when I am away, but you can simply comment those sections out if you do not have this. The script uses a 'hysteresis' for 'wiggle' room in the temperature. This prevents excessive cycling of the heating.
Additional heaters can be added be duplicating the initial section (I added this in the comments so you get the idea). Would be nicer to do this in an array, and I might do that in future if I can learn a little more lua!
Anyway - I hope someone might find this useful.
-- print ("*************** Thermostat script ************")
--print ("Device based event fired on '"..deviceName.."', value '"..tostring(deviceValue).."'")
--for key, value in pairs(devicechanged) do
-- print ('Changed devices: ==>> key: ' .. tostring(key) .. '; value: ==>> ' .. tostring(value))
--end
local hysteresis = 0.5 -- Wiggle room for temprature, esle relays/switch gets used too much
local sensor = 'Study' -- Temp sensor name
local switch = 'Study Heater' -- heater switch name
local stat = 'Study thermostat' -- thermostat name
local temprature = otherdevices_temperature[sensor] -- gets the temprature sensor value
local sp = otherdevices[stat] -- gets the setpoint from the termostat
-- we will temporarily overide the thermostat value with a modest value
-- when we are 'Away', to prevent excessively heating an empty house
-- this whole section could be commented out if you do not have a 'Home' status
if (otherdevices['Status'] == "Away") then
sp = sp - 3
elseif (otherdevices['Status'] == "Holiday") then
sp = 10
elseif (otherdevices['Status'] == "Night") then
sp = sp - 5
-- force a min value
if (tonumber(sp) < 10) then
sp = 10
print("Thermostat:'"..sensor.."' temp is " .. tostring(temprature)..", SetPoint is "..tostring(sp)..", switch status is "..otherdevices[switch]..", home status is '"..otherdevices['Status'].."'") -- for debugging - can comment out
if (temprature < (sp - hysteresis)) then
print("temprature is less than setpoint-hysteresis of "..tostring((sp - hysteresis))) -- for debugging - can comment out
if (otherdevices[switch] == 'Off') then
commandArray[switch] = 'On'
elseif (temprature > (sp + hysteresis)) then
print("temprature is more than setpoint+hysteresis of "..tostring((sp + hysteresis))) -- for debugging - can comment out
if (otherdevices[switch] == 'On') then
commandArray[switch] = 'Off'
-- next heater/room
sp = sp - 3
sp = 10
sp = sp - 5
sp = 10
just in case anyone wants to know how I did the status variable, it's just a generic selector switch with these selector levels
0 Off
10 Home
20 Away
30 Night
40 Holiday
