Segmfault using OZW
nigels0
Domoticz version: 3.8153
Segmfault using OZW
Post by nigels0 »
I’m getting this error on OZW when a Z-Wave lock is triggered.
11-04 13:29:07.330 Error: Domoticz(pid:27184, tid:27225('OZW-driver')) received fatal signal 11 (Segmentation fault)
It actually crashes Domoticz.
It was on a new install of Domoticz, but copying over the old database. I’ve deleted the hardware, then added it again (I’m using the Aeotec stick)
Is there any way to re-install the OZW software so this doesn’t happen?
nigels0
Re: Segmfault using OZW
Post by nigels0 »
OK, no answers on this, so I re-installed Domoticz again and removed, then re-inserted the Aeotec stick.
Now I have a different problem; when opening or closing a door, I get the following error:
 2022-11-06 14:15:54.063 Error: Z-Wave : Value_Changed: Tried adding value, not succeeded!. Node: 24 (0x18), CommandClass: DOOR LOCK, Label: Locked (Advanced), Instance: 1, Index: 1
The lock indication on the device works OK when opening or closing.
kiddigital
Post by kiddigital »
If starting out with Zwave, please switch to Zwave2mqtt and Domoticz MQTT Auto Discovery as the build-in OZW will be removed soon.
(Domoticz OZW depends on an external not maintained anymore library)
meal
Domoticz version: 2025.2
Post by meal »
Hello
Please do not remove OZW from Domoticz distribution as the latest version is working perfectly.
Instead of that let Domoticz users choose to keep OZW (event at their own risks) or switch over to Zwave2mqtt.
Many thanks
Best regards
meal
meal
Post by meal »
Hi nigels0
I understand you succeeded in inserting the door sensor in you Zwave configuration and it operates correctly from a functional standpoint.
To tackle your message issue.
Have you tried to enable the creation of new devices in the Domoticz settings.
Sometimes the zwave sensor send messages which are captured by OZW and it creates new zwave devices.
BR
meal
nigels0
Post by nigels0 »
Hi meal,
I have new devices closed - but it seems on a bit of googling, there is an issue with the way Domoticz handles responses with (advanced) in them - I guess the error has been noted, but there doesn't seem to be a time to fix it as OZW isn't going to be supported. The general advice is just to ignore them!
I'm finding installation of the replacements for OZW problematic - otherwise I'd switch to that. I've tried installing with Snap, but it gets complicated quickly and the Wiki is (to say it politely) rather sparse.
I must admit, I need a simpler and more complete guide to install the replacement for OZW.
nigels0
Post by nigels0 »
One thing I’ve found out; to get past the seg fault, I woke up the door lock devices (by opening them) then starting up Domoticz. This seems to fix the issue and Domoticz keeps running.
mgugu
Post by mgugu »
meal wrote: Monday 07 November 2022 8:09 Hello
Many thanks
Best regards
+1 Same opinion
nigels0
Post by nigels0 »
I’ve given up on OZW - just couldn’t fix the seg faults, so moved to the new config. It wasn’t painless and had to reload some items like locks before I got to a workable state.
It really isn’t as integrated and pretty as OZW, but at least it has a development future.
