switch LSC RGBWW lamp between different colors fails
Posted: Friday 28 October 2022 16:13
by Gravityz
i am trying to switch an LSC(Tuya) RGBWW lamp from 1 color(red) to the other(WW) and back.
the light is of type color switch RGBWW dimmer in domoticz
after a lot of trial and error i succeeded
the reason that it took such a long time is that i discovered that the brightness setting on the WW command directly affects the color on the red command
Command for RED
domoticz.devices('Douche').setColor(255,0,0,55,0,100,3,255)
Command for WW
domoticz.devices('Douche').setColor(0,0,0,55,0,100,2,255)
as long as i keep the brightness settings on both commands the same(50 in this case) it works and i can toggle between those 2 commands
if i either make the first brightness higher or the second one it fails and the light either blinks shortly which and turns to red again or the other way around.
what i want is very simple
switch the light to red with 80% brightness and back to WW with 55% brightness
can anybody see what is going wrong.
Re: switch LSC RGBWW lamp between different colors fails
Posted: Monday 31 October 2022 13:45
Perhaps set the lamp in white mode first with .setWhiteMode()
Or find the rgb setting for warmwhite (eg 253, 244, 220) so no switching of mode.
