switch LSC RGBWW lamp between different colors fails
Gravityz
Post by Gravityz »
i am trying to switch an LSC(Tuya) RGBWW lamp from 1 color(red) to the other(WW) and back.
the light is of type color switch RGBWW dimmer in domoticz
after a lot of trial and error i succeeded
the reason that it took such a long time is that i discovered that the brightness setting on the WW command directly affects the color on the red command
Command for RED
domoticz.devices('Douche').setColor(255,0,0,55,0,100,3,255)
Command for WW
domoticz.devices('Douche').setColor(0,0,0,55,0,100,2,255)
as long as i keep the brightness settings on both commands the same(50 in this case) it works and i can toggle between those 2 commands
if i either make the first brightness higher or the second one it fails and the light either blinks shortly which and turns to red again or the other way around.
what i want is very simple
switch the light to red with 80% brightness and back to WW with 55% brightness
can anybody see what is going wrong.
Re: switch LSC RGBWW lamp between different colors fails
Perhaps set the lamp in white mode first with .setWhiteMode()
Or find the rgb setting for warmwhite (eg 253, 244, 220) so no switching of mode.
