Negative temp value in Blockly
Posted: Tuesday 27 September 2022 16:39
by Treve
The thermostat of the freezer is defective, I thought to solve this temporarily with a simple blockly. It seems that no negative values are possible.
Can someone clarify and possibly offer me a solution.
- Blockly negative temp.jpg (20.03 KiB) Viewed 5634 times
Re: Negative temp value in Blockly
Posted: Tuesday 27 September 2022 16:43
by willemd
Switch to DzVents, it is so much more powerful, although a small learning curve .....
Posted: Wednesday 28 September 2022 11:31
by Treve
Since I need a working script in the short term and have no time to learn myself into DZVentz.
I found a script from the late 'Waaren',
on = { timer = { 'every minute' } },
execute = function(domoticz)
local Sensor = domoticz.devices('Omnik temperature')
if Sensor.temperature >= 25 then
domoticz.devices('Omnik Ventilator').switchOn()
and adapted it without any knowledge.
local Sensor = domoticz.devices('Vriezer')
if Sensor.temperature <= -16 then
domoticz.devices('Switch 7 Vriezer').switchOn()
elseif Sensor.temperature >= -18 then
domoticz.devices('Switch 7 Vriezer').switchOff()
Can this script work?
Posted: Wednesday 28 September 2022 12:52
by plugge
You have to change:
in: if Sensor.temperature >= -16 then
and
in: elseif Sensor.temperature <= -18 then
Remember these are negative values.
If the script iteself works for you? Try it!
Posted: Wednesday 28 September 2022 14:13
by Treve
local Sensor = domoticz.devices('testtemp')
if Sensor.temperature <= 22 then
domoticz.devices('Lidl On/Off plug 4').switchOn()
elseif Sensor.temperature >= 24 then
domoticz.devices('Lidl On/Off plug 4').switchOff()
I created a test environment with positive temperatures, the switch turns On below 22' and Off above 24'.
Conclusion is, the script works.
Now investigate whether it also works with negative (freezing) values, or can anybody tells me if it will?
Posted: Wednesday 28 September 2022 15:13
by Treve
elseif Sensor.temperature <= -19 then
This did the trick.
good find for someone who has never dealt with dzvents until this morning.
