zigbee2mqtt - reconfigure
manjh
Post by manjh »
I use dconz and zigbee2mqtt for my growing zigbee landscape.
Works OK, except for when I have to restart my R-pi for some reason.
After a restart my Ikea lamps are not working. I found out that I can revive them by doing a "reconfigure" on the Zigbee2MQTT interface.
First question: what can I do to prevent this?
Second, if the answer to the first question is negative: is there a way to execute a reconfigure automatically, for instance from a LUA script?
Hans
manjh
Re: zigbee2mqtt - reconfigure
Post by manjh »
Any ideas, anyone? Am I the only person experiencing this phenomenon?
Hans
Thorgal789
Post by Thorgal789 »
You are using deconz or zigbee2mqtt, not possible to use both in same time, or you mean you are using the conbee ?
manjh
Post by manjh »
Thorgal789 wrote: Tuesday 27 September 2022 9:36 You are using deconz or zigbee2mqtt, not possible to use both in same time, or you mean you are using the conbee ?
You are right... :oops:
Hans
