Cannot add method in python script
kofec
Post by kofec »
For python script (time based) I would like to add method and this method didn't see DEVICE object e.g.:
import DomoticzEvents as DE
DE.Log("Python: Changed: " + DE.changed_device.Describe())
def DisplaySomething():
    DE.Log("Python: Test")
if DE.changed_device_name == "Test":
    if DE.Devices["Test_Target"].n_value_string == "On":
        DE.Command("Test_Target", "Off")
    if DE.Devices["Test_Target"].n_value_string == "Off":
        DE.Command("Test_Target", "On")
DE.Log("Python: Number of user_variables: " + str(len(DE.user_variables)))
# All user_variables are treated as strings, convert as necessary
for key, value in DE.user_variables.items():
    DE.Log("Python: User-variable '{0}' has value: {1}".format(key, value))
DisplaySomething()
# Description of Device_object should go here...
Error: name 'DE' is not define
If this error specific to my environment or generic ? It was working fine in previous versions
Domoticz version: 2024.7
Re: Cannot add method in python script
If I use the time based demo script as shown in the last paragraph of the wiki page https://www.domoticz.com/wiki/Python_Events
I get a notification every minute (as expected). I am on 2202.1 I also tried this on latest beta and there it is also running.
kofec
Post by kofec »
Thanks for quick replay. I made a misteke in the example. Can you add any method using "DE" object in the code e.g:
And call this method in the code
Indeed, just tested in latest beta 14498:
2022-09-19 20:27:00.432 Error: Traceback (most recent call last):
2022-09-19 20:27:00.432 Error: File "python1", line 11, in <module>
2022-09-19 20:27:00.432 Error: File "python1", line 9, in DisplaySomething
2022-09-19 20:27:00.432 Error: NameError: name 'DE' is not defined
In current stable 2022.1 it is no issue, the same script runs without problems.
There were a lot of changes in beta on Python framework due to incompatibility with newer Linux OS (eg bullseye).
I would advise you to make a github issue for this on the domoticz repository....
Ah, I see somebody already did something: https://github.com/domoticz/domoticz/issues/5339
