Sunricher ZG2858
Posted: Tuesday 13 September 2022 22:42
by julienb
I'm trying to make the sunricher ZG2858A remote work correctly. It is correctly paired using zigate plugin, the three dimmer devices are created in domoticz, but i'm not receiving any event in domoticz log.
This is a bit surprising, as this device is supposedly in the certified list. So i must be doing something wrong. A few hypothesis:
* i need domoticz beta to make it work (i'm currently with 2022.01 stable)
* i need the zigate plugin beta (i'm currently with stable6 + a few backported patches)
* i did not pair the device correctly (ie, it must be paired in a special mode)
* something else must be configured somewhere, and i did not do that step.
Any help / hints would be greatly appreciated.
Re: Sunricher ZG2858
Posted: Tuesday 13 September 2022 23:55
by pipiche
So I understood that you are using the Zigate for Domoticz plugin.
Could you kindly provide the plugin logs when doing the pairing ( you can eventually add debugPairing from teh Webui > Tools > Debug
Could you kindly provide the export.json from the "Plugin Raw Devices (json)" menu ?
This would really help to get a natureof the problem
Plugins logs are available under Domoticz-Zgibee/Logs/PluginLop-xx.log
Posted: Wednesday 14 September 2022 6:35
by julienb
This is the log of the plugin during a new pairing:
2022-09-14 06:25:15,858 INFO    : [ZiGateForwarder_2] Accepting new Hardware: Enable (On)
2022-09-14 06:25:25,568 DEBUG   : [ZiGateForwarder_2] Decode004d - Looks like it is a new device sent by Zigate
2022-09-14 06:25:25,571 INFO    : [ZiGateForwarder_2] --> Adding device 1794 in self.DevicesInPairingMode
2022-09-14 06:25:25,572 INFO    : [ZiGateForwarder_2] --> ['1794']
2022-09-14 06:25:25,573 DEBUG   : [ZiGateForwarder_2] interview_state_004d - NWKID: 1794, Status: None, RIA: None,
2022-09-14 06:25:25,574 INFO    : [ZiGateForwarder_2] [None] NEW OBJECT: 1794 None
2022-09-14 06:25:26,605 DEBUG   : [ZiGateForwarder_2] Decode8045 - Reception Active endpoint response: SQN: 17, Status [00] Success, short Addr 1794, List 03, Ep list 010203
2022-09-14 06:25:26,611 INFO    : [ZiGateForwarder_2] [-] NEW OBJECT: 1794 Active Endpoint Response Ep: 01 LQI: 62
2022-09-14 06:25:26,612 INFO    : [ZiGateForwarder_2] [-] NEW OBJECT: 1794 Active Endpoint Response Ep: 02 LQI: 62
2022-09-14 06:25:26,613 INFO    : [ZiGateForwarder_2] [-] NEW OBJECT: 1794 Active Endpoint Response Ep: 03 LQI: 62
2022-09-14 06:25:26,614 DEBUG   : [ZiGateForwarder_2] interview_state_8045 - NWKID: 1794, Status: None, RIA: None,
2022-09-14 06:25:26,615 DEBUG   : [ZiGateForwarder_2] [None] NEW OBJECT: 1794 Request Model Name
2022-09-14 06:25:26,617 INFO    : [ZiGateForwarder_2] Request Basic  Manufacturer via Read Attribute request: 0004
2022-09-14 06:25:26,618 INFO    : [ZiGateForwarder_2] EP: {'01': {}, '02': {}, '03': {}}
2022-09-14 06:25:26,623 INFO    : [ZiGateForwarder_2] [-] NEW OBJECT: 1794 Request Simple Descriptor for Ep: 01
2022-09-14 06:25:26,626 DEBUG   : [ZiGateForwarder_2] Decode8045 - Device: 1794 updated ListofDevices with {'01': {}, '02': {}, '03': {}}
2022-09-14 06:25:30,109 DEBUG   : [       MainThread] processNotinDBDevices - NWKID: 1794, Status: 0043, RIA: 0, HB_: 1
2022-09-14 06:25:30,111 INFO    : [       MainThread] [0] NEW OBJECT: 1794 Model Name: ZG2858A
2022-09-14 06:25:30,122 INFO    : [       MainThread] [0] NEW OBJECT: 1794 Manufacturer Name: Sunricher
2022-09-14 06:25:30,129 DEBUG   : [       MainThread] [0] NEW OBJECT: 1794 Model Name: ZG2858A knownModel: True status: CreateDB
2022-09-14 06:25:30,136 INFO    : [       MainThread] [None] NEW OBJECT: 1794 Request Node Descriptor
2022-09-14 06:25:30,142 DEBUG   : [       MainThread] interview_state_createDB - NWKID: 1794, Status: CreateDB, RIA: 0,
2022-09-14 06:25:30,148 DEBUG   : [       MainThread] [0] NEW OBJECT: 1794 Trying to create Domoticz device(s)
2022-09-14 06:25:30,154 DEBUG   : [       MainThread] processNotinDBDevices - ready for creation: {'Version': '3', 'ZDeviceName': '', 'Status': '0043', 'SQN': '5f', 'Heartbeat': '1', 'RIA': '0', 'LQI': 61, 'Battery': 125.0, 'Model': 'ZG2858A', 'ForceAckCommands': [], 'MacCapa': '80', 'IEEE': '84ba20fffec4d327', 'Type': '', 'ProfileID': {}, 'ZDeviceID': {}, 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [(248, '02', '1794', '0100', '01010000000000000200040005'), (249, '02', '1794', '0100', '01020000000000000200040005'), (250, '02', '1794', '0100', '01030000000000000200040005')], 'LogicalType': 'End Device', 'Manufacturer': '', 'Manufacturer Name': 'Sunricher', 'NbEp': '3', 'PowerSource': '', 'ReadAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 1663129527, 'iSQN': {'0004': 248, '0005': 248}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 1663129528, 'iSQN': {}, 'Attributes': {'0021': '00'}, 'ZigateRequest': {}}}, '02': {'0000': {'TimeStamp': 1663129528, 'iSQN': {'0004': 249, '0005': 249}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}}, '03': {'0000': {'TimeStamp': 1663129529, 'iSQN': {'0004': 250, '0005': 250}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1663129529.658862, 'Time': '2022-09-14 06:25:29', 'MsgType': '8011', 'LastSeen': 1663129529}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'RollingLQI': [62, 60, 60, 36, 36, 59, 59, 61, 61], 'Epv2': {'01': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, '02': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, '03': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'WriteAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0003': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0004': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0005': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0006': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0008': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0300': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0b05': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}, '02': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0003': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0004': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0005': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0006': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0008': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0300': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0b05': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}, '03': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0003': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0004': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0005': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0006': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0008': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0300': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0b05': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'ConfigSource': 'DeviceConf', 'Ep': {'01': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {'0021': 125}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull'}, '02': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull'}, '03': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull'}}, 'BatteryUpdateTime': 1663129528, 'PairingInProgress': True} , Model: ZG2858A
2022-09-14 06:25:30,179 DEBUG   : [       MainThread] Device: 1794 - Config Source: DeviceConf Ep Details: {'01': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {'0021': 125}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull', 'ClusterType': {'38': 'ColorControlFull'}}, '02': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull', 'ClusterType': {'39': 'ColorControlFull'}}, '03': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull', 'ClusterType': {'40': 'ColorControlFull'}}}
2022-09-14 06:25:30,187 DEBUG   : [       MainThread] binding_needed_clusters_with_zigate 1794 based on Device Configuration
2022-09-14 06:25:30,193 DEBUG   : [       MainThread] 1794 Binding cluster based on Conf: ['0001', '0003']
2022-09-14 06:25:30,199 DEBUG   : [       MainThread] Request a Bind for 1794/01 on Cluster 0001
2022-09-14 06:25:30,205 DEBUG   : [       MainThread] Request a Bind for 1794/01 on Cluster 0003
2022-09-14 06:25:30,212 DEBUG   : [       MainThread] Request a Bind for 1794/02 on Cluster 0001
2022-09-14 06:25:30,219 DEBUG   : [       MainThread] Request a Bind for 1794/02 on Cluster 0003
2022-09-14 06:25:30,227 DEBUG   : [       MainThread] Request a Bind for 1794/03 on Cluster 0001
2022-09-14 06:25:30,230 DEBUG   : [       MainThread] Request a Bind for 1794/03 on Cluster 0003
2022-09-14 06:25:30,237 DEBUG   : [       MainThread] Request Configure Reporting for 1794
2022-09-14 06:25:30,243 DEBUG   : [       MainThread] device_interview 1794
2022-09-14 06:25:30,249 DEBUG   : [       MainThread] device_interview 1794 Read Attribute for cluster: 0001
2022-09-14 06:25:30,261 DEBUG   : [       MainThread] device_interview 1794 Read Attribute for cluster: 0019
2022-09-14 06:25:30,263 INFO    : [       MainThread] WARNING - send_zigatecmd : [268] 0100 0217940101001900000000010001 1794 ZigateQueue: 16
2022-09-14 06:25:30,265 INFO    : [       MainThread] WARNING - send_zigatecmd : [269] 0100 0217940101001900000000010002 1794 ZigateQueue: 17
2022-09-14 06:25:30,266 INFO    : [       MainThread] WARNING - send_zigatecmd : [270] 0100 0217940101001900000000010003 1794 ZigateQueue: 18
2022-09-14 06:25:30,268 INFO    : [       MainThread] WARNING - send_zigatecmd : [271] 0100 0217940101001900000000010004 1794 ZigateQueue: 19
2022-09-14 06:25:30,269 INFO    : [       MainThread] WARNING - send_zigatecmd : [272] 0100 0217940101001900000000010005 1794 ZigateQueue: 20
2022-09-14 06:25:30,270 INFO    : [       MainThread] WARNING - send_zigatecmd : [273] 0100 0217940101001900000000010006 1794 ZigateQueue: 21
2022-09-14 06:25:30,272 INFO    : [       MainThread] WARNING - send_zigatecmd : [274] 0100 0217940101001900000000010007 1794 ZigateQueue: 22
2022-09-14 06:25:30,290 INFO    : [       MainThread] WARNING - send_zigatecmd : [275] 0100 0217940101001900000000010008 1794 ZigateQueue: 23
2022-09-14 06:25:30,292 INFO    : [       MainThread] WARNING - send_zigatecmd : [276] 0100 0217940101001900000000010009 1794 ZigateQueue: 24
2022-09-14 06:25:30,296 INFO    : [       MainThread] WARNING - send_zigatecmd : [277] 0100 021794010100190000000001000a 1794 ZigateQueue: 25
2022-09-14 06:25:30,299 INFO    : [       MainThread] WARNING - send_zigatecmd : [278] 0100 0217940102001900000000010001 1794 ZigateQueue: 26
2022-09-14 06:25:30,302 INFO    : [       MainThread] WARNING - send_zigatecmd : [279] 0100 0217940102001900000000010002 1794 ZigateQueue: 27
2022-09-14 06:25:30,306 INFO    : [       MainThread] WARNING - send_zigatecmd : [280] 0100 0217940102001900000000010003 1794 ZigateQueue: 28
2022-09-14 06:25:30,309 INFO    : [       MainThread] WARNING - send_zigatecmd : [281] 0100 0217940102001900000000010004 1794 ZigateQueue: 29
2022-09-14 06:25:30,312 INFO    : [       MainThread] WARNING - send_zigatecmd : [282] 0100 0217940102001900000000010005 1794 ZigateQueue: 30
2022-09-14 06:25:30,314 INFO    : [       MainThread] WARNING - send_zigatecmd : [283] 0100 0217940102001900000000010006 1794 ZigateQueue: 31
2022-09-14 06:25:30,317 INFO    : [       MainThread] WARNING - send_zigatecmd : [284] 0100 0217940102001900000000010007 1794 ZigateQueue: 32
2022-09-14 06:25:30,319 INFO    : [       MainThread] WARNING - send_zigatecmd : [285] 0100 0217940102001900000000010008 1794 ZigateQueue: 33
2022-09-14 06:25:30,325 INFO    : [       MainThread] WARNING - send_zigatecmd : [286] 0100 0217940102001900000000010009 1794 ZigateQueue: 34
2022-09-14 06:25:30,330 INFO    : [       MainThread] WARNING - send_zigatecmd : [287] 0100 021794010200190000000001000a 1794 ZigateQueue: 35
2022-09-14 06:25:30,332 INFO    : [       MainThread] WARNING - send_zigatecmd : [288] 0100 0217940103001900000000010001 1794 ZigateQueue: 36
2022-09-14 06:25:30,333 INFO    : [       MainThread] WARNING - send_zigatecmd : [289] 0100 0217940103001900000000010002 1794 ZigateQueue: 37
2022-09-14 06:25:30,335 INFO    : [       MainThread] WARNING - send_zigatecmd : [290] 0100 0217940103001900000000010003 1794 ZigateQueue: 38
2022-09-14 06:25:30,336 INFO    : [       MainThread] WARNING - send_zigatecmd : [291] 0100 0217940103001900000000010004 1794 ZigateQueue: 39
2022-09-14 06:25:30,339 INFO    : [       MainThread] WARNING - send_zigatecmd : [292] 0100 0217940103001900000000010005 1794 ZigateQueue: 40
2022-09-14 06:25:30,340 INFO    : [       MainThread] WARNING - send_zigatecmd : [293] 0100 0217940103001900000000010006 1794 ZigateQueue: 41
2022-09-14 06:25:30,342 INFO    : [       MainThread] WARNING - send_zigatecmd : [294] 0100 0217940103001900000000010007 1794 ZigateQueue: 42
2022-09-14 06:25:30,344 INFO    : [       MainThread] WARNING - send_zigatecmd : [295] 0100 0217940103001900000000010008 1794 ZigateQueue: 43
2022-09-14 06:25:30,350 INFO    : [       MainThread] WARNING - send_zigatecmd : [296] 0100 0217940103001900000000010009 1794 ZigateQueue: 44
2022-09-14 06:25:30,352 INFO    : [       MainThread] WARNING - send_zigatecmd : [297] 0100 021794010300190000000001000a 1794 ZigateQueue: 45
2022-09-14 06:25:30,352 DEBUG   : [       MainThread] device_interview 1794 Read Attribute for cluster: 0006
2022-09-14 06:25:30,353 DEBUG   : [       MainThread] device_interview 1794 Read Attribute for cluster: 0008
2022-09-14 06:25:30,354 DEBUG   : [       MainThread] device_interview 1794 Read Attribute for cluster: 0300
2022-09-14 06:25:30,354 DEBUG   : [       MainThread] device_interview 1794 Read Attribute for cluster: 0000
2022-09-14 06:25:30,356 INFO    : [       MainThread] WARNING - send_zigatecmd : [298] 0100 0217940101000000000000010000 1794 ZigateQueue: 46
2022-09-14 06:25:30,357 INFO    : [       MainThread] WARNING - send_zigatecmd : [299] 0100 0217940101000000000000010001 1794 ZigateQueue: 47
2022-09-14 06:25:30,358 INFO    : [       MainThread] WARNING - send_zigatecmd : [300] 0100 0217940101000000000000010002 1794 ZigateQueue: 48
2022-09-14 06:25:30,359 INFO    : [       MainThread] WARNING - send_zigatecmd : [301] 0100 0217940101000000000000010003 1794 ZigateQueue: 49
2022-09-14 06:25:30,360 INFO    : [       MainThread] WARNING - send_zigatecmd : [302] 0100 0217940101000000000000010004 1794 ZigateQueue: 50
2022-09-14 06:25:30,362 INFO    : [       MainThread] WARNING - send_zigatecmd : [303] 0100 0217940101000000000000010005 1794 ZigateQueue: 51
2022-09-14 06:25:30,363 INFO    : [       MainThread] WARNING - send_zigatecmd : [304] 0100 0217940101000000000000010007 1794 ZigateQueue: 52
2022-09-14 06:25:30,364 INFO    : [       MainThread] WARNING - send_zigatecmd : [305] 0100 021794010100000000000001000a 1794 ZigateQueue: 53
2022-09-14 06:25:30,366 INFO    : [       MainThread] WARNING - send_zigatecmd : [306] 0100 0217940101000000000000014000 1794 ZigateQueue: 54
2022-09-14 06:25:30,367 INFO    : [       MainThread] WARNING - send_zigatecmd : [307] 0100 0217940102000000000000010000 1794 ZigateQueue: 55
2022-09-14 06:25:30,368 INFO    : [       MainThread] WARNING - send_zigatecmd : [308] 0100 0217940102000000000000010001 1794 ZigateQueue: 56
2022-09-14 06:25:30,370 INFO    : [       MainThread] WARNING - send_zigatecmd : [309] 0100 0217940102000000000000010002 1794 ZigateQueue: 57
2022-09-14 06:25:30,371 INFO    : [       MainThread] WARNING - send_zigatecmd : [310] 0100 0217940102000000000000010003 1794 ZigateQueue: 58
2022-09-14 06:25:30,372 INFO    : [       MainThread] WARNING - send_zigatecmd : [311] 0100 0217940102000000000000010004 1794 ZigateQueue: 59
2022-09-14 06:25:30,373 INFO    : [       MainThread] WARNING - send_zigatecmd : [312] 0100 0217940102000000000000010005 1794 ZigateQueue: 60
2022-09-14 06:25:30,374 INFO    : [       MainThread] WARNING - send_zigatecmd : [313] 0100 0217940102000000000000010007 1794 ZigateQueue: 61
2022-09-14 06:25:30,375 INFO    : [       MainThread] WARNING - send_zigatecmd : [314] 0100 021794010200000000000001000a 1794 ZigateQueue: 62
2022-09-14 06:25:30,377 INFO    : [       MainThread] WARNING - send_zigatecmd : [315] 0100 0217940102000000000000014000 1794 ZigateQueue: 63
2022-09-14 06:25:30,378 INFO    : [       MainThread] WARNING - send_zigatecmd : [316] 0100 0217940103000000000000010000 1794 ZigateQueue: 64
2022-09-14 06:25:30,379 INFO    : [       MainThread] WARNING - send_zigatecmd : [317] 0100 0217940103000000000000010001 1794 ZigateQueue: 65
2022-09-14 06:25:30,380 INFO    : [       MainThread] WARNING - send_zigatecmd : [318] 0100 0217940103000000000000010002 1794 ZigateQueue: 66
2022-09-14 06:25:30,382 INFO    : [       MainThread] WARNING - send_zigatecmd : [319] 0100 0217940103000000000000010003 1794 ZigateQueue: 67
2022-09-14 06:25:30,390 INFO    : [       MainThread] WARNING - send_zigatecmd : [320] 0100 0217940103000000000000010004 1794 ZigateQueue: 68
2022-09-14 06:25:30,392 INFO    : [       MainThread] WARNING - send_zigatecmd : [321] 0100 0217940103000000000000010005 1794 ZigateQueue: 69
2022-09-14 06:25:30,394 INFO    : [       MainThread] WARNING - send_zigatecmd : [322] 0100 0217940103000000000000010007 1794 ZigateQueue: 70
2022-09-14 06:25:30,395 INFO    : [       MainThread] WARNING - send_zigatecmd : [323] 0100 021794010300000000000001000a 1794 ZigateQueue: 71
2022-09-14 06:25:30,396 INFO    : [       MainThread] WARNING - send_zigatecmd : [324] 0100 0217940103000000000000014000 1794 ZigateQueue: 72
2022-09-14 06:25:30,399 INFO    : [       MainThread] WARNING - send_zigatecmd : [325] 00E0     07179401010000 1794 ZigateQueue: 73
2022-09-14 06:25:30,400 DEBUG   : [       MainThread] looking for List of Attributes ep: 01
2022-09-14 06:25:30,401 DEBUG   : [       MainThread] looking for List of Attributes ep: 02
2022-09-14 06:25:30,402 DEBUG   : [       MainThread] looking for List of Attributes ep: 03
2022-09-14 06:25:30,403 INFO    : [       MainThread] WARNING - send_zigatecmd : [326] 0530 0217940000003300000200020000 None ZigateQueue: 74
2022-09-14 06:25:30,610 INFO    : [ZiGateForwarder_2] [-] NEW OBJECT: 1794 Simple Descriptor Response EP: 0x01 LQI: 62
2022-09-14 06:25:30,612 INFO    : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 ProfileID 0104
2022-09-14 06:25:30,613 INFO    : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 ZDeviceID 0105
2022-09-14 06:25:30,615 INFO    : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 Application Version 0001
2022-09-14 06:25:30,615 INFO    : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 Cluster IN Count: 05
2022-09-14 06:25:30,616 DEBUG   : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 we keep DeviceConf info
2022-09-14 06:25:30,616 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster In 1: 0000 (Basic)
2022-09-14 06:25:30,617 DEBUG   : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 we keep DeviceConf info
2022-09-14 06:25:30,617 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster In 2: 0001 (Power Configuration)
2022-09-14 06:25:30,618 DEBUG   : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 we keep DeviceConf info
2022-09-14 06:25:30,618 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster In 3: 0003 (Identify)
2022-09-14 06:25:30,619 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster In 4: 0b05 (Diagnostics)
2022-09-14 06:25:30,619 DEBUG   : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 we keep DeviceConf info
2022-09-14 06:25:30,620 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster In 5: 1000 (Touchlink)
2022-09-14 06:25:30,620 INFO    : [ZiGateForwarder_2] [-]    NEW OBJECT: 1794 Cluster OUT Count: 08
2022-09-14 06:25:30,621 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 1: 0003 (Identify)
2022-09-14 06:25:30,621 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 2: 0004 (Groups)
2022-09-14 06:25:30,622 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 3: 0005 (Scenes)
2022-09-14 06:25:30,622 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 4: 0006 (On/Off)
2022-09-14 06:25:30,623 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 5: 0008 (Level Control)
2022-09-14 06:25:30,624 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 6: 0019 (Over-the-Air Upgrade)
2022-09-14 06:25:30,624 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 7: 0300 (Colour Control)
2022-09-14 06:25:30,625 INFO    : [ZiGateForwarder_2] [-]       NEW OBJECT: 1794 Cluster Out 8: 1000 (Touchlink)
2022-09-14 06:25:30,625 DEBUG   : [ZiGateForwarder_2] Decode8043 - Processed 1794 end results is: {'Version': '3', 'ZDeviceName': '', 'Status': 'inDB', 'SQN': '18', 'Heartbeat': 0, 'RIA': '0', 'LQI': 62, 'Battery': 125.0, 'Model': 'ZG2858A', 'ForceAckCommands': [], 'MacCapa': '80', 'IEEE': '84ba20fffec4d327', 'Type': 'ColorControlFull', 'ProfileID': '0104', 'ZDeviceID': '0105', 'App Version': '', 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [(316, '02', '1794', '0100', '0103000000000000010000'), (317, '02', '1794', '0100', '0103000000000000010001'), (318, '02', '1794', '0100', '0103000000000000010002'), (319, '02', '1794', '0100', '0103000000000000010003'), (320, '02', '1794', '0100', '0103000000000000010004'), (321, '02', '1794', '0100', '0103000000000000010005'), (322, '02', '1794', '0100', '0103000000000000010007'), (323, '02', '1794', '0100', '010300000000000001000a'), (324, '02', '1794', '0100', '0103000000000000014000'), (325, '07', '1794', '00E0', '01010000')], 'LogicalType': 'End Device', 'Manufacturer': '', 'Manufacturer Name': 'Sunricher', 'NbEp': '3', 'PowerSource': '', 'ReadAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 1663129530, 'iSQN': {'0000': 298, '0001': 299, '0002': 300, '0003': 301, '0004': 302, '0005': 303, '0007': 304, '000a': 305, '4000': 306}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 1663129530, 'iSQN': {'0020': 259, '0021': 260, '0033': 261}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 1663129530, 'iSQN': {'0001': 268, '0002': 269, '0003': 270, '0004': 271, '0005': 272, '0006': 273, '0007': 274, '0008': 275, '0009': 276, '000a': 277}, 'Attributes': {}, 'ZigateRequest': {}}}, '02': {'0000': {'TimeStamp': 1663129530, 'iSQN': {'0000': 307, '0001': 308, '0002': 309, '0003': 310, '0004': 311, '0005': 312, '0007': 313, '000a': 314, '4000': 315}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 1663129530, 'iSQN': {'0020': 262, '0021': 263, '0033': 264}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 1663129530, 'iSQN': {'0001': 278, '0002': 279, '0003': 280, '0004': 281, '0005': 282, '0006': 283, '0007': 284, '0008': 285, '0009': 286, '000a': 287}, 'Attributes': {}, 'ZigateRequest': {}}}, '03': {'0000': {'TimeStamp': 1663129530, 'iSQN': {'0000': 316, '0001': 317, '0002': 318, '0003': 319, '0004': 320, '0005': 321, '0007': 322, '000a': 323, '4000': 324}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 1663129530, 'iSQN': {'0020': 265, '0021': 266, '0033': 267}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 1663129530, 'iSQN': {'0001': 288, '0002': 289, '0003': 290, '0004': 291, '0005': 292, '0006': 293, '0007': 294, '0008': 295, '0009': 296, '000a': 297}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': '', 'Stack Version': '', 'Stamp': {'time': 1663129530.5509877, 'Time': '2022-09-14 06:25:30', 'MsgType': '8011', 'LastSeen': 1663129530}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'RollingLQI': [62, 60, 60, 36, 36, 59, 59, 61, 61, 62], 'Epv2': {'01': {'ClusterIn': {'0000': {}, '0001': {}, '0003': {}, '0b05': {}, '1000': {}}, 'ClusterOut': {'0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '1000': {}}, 'ProfileID': '0104', 'ZDeviceID': '0105'}, '02': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}, '03': {'ClusterIn': {}, 'ClusterOut': {}, 'ProfileID': {}, 'ZDeviceID': {}}}, 'WriteAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0003': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0004': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0005': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0006': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0008': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0300': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0b05': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}, '02': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0003': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0004': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0005': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0006': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0008': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0300': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0b05': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}, '03': {'0000': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0001': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0003': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0004': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0005': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0006': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0008': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0019': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0300': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}, '0b05': {'TimeStamp': 0, 'iSQN': {}, 'Attributes': {}, 'ZigateRequest': {}}}}}, 'ConfigSource': 'DeviceConf', 'Ep': {'01': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {'0021': 125}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull', 'ClusterType': {'38': 'ColorControlFull'}}, '02': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull', 'ClusterType': {'39': 'ColorControlFull'}}, '03': {'0000': {'0004': 'Sunricher', '0005': 'ZG2858A'}, '0001': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0019': {}, '0300': {}, '0b05': {}, 'Type': 'ColorControlFull', 'ClusterType': {'40': 'ColorControlFull'}}}, 'BatteryUpdateTime': 1663129528, 'PairingInProgress': False, 'PairingTime': 1663129530.1305754, 'Bind': {'01': {'0001': {'Target': '0000', 'Stamp': 1663129530, 'Phase': 'requested', 'Status': '', 'i_sqn': 253}, '0003': {'Target': '0000', 'Stamp': 1663129530, 'Phase': 'requested', 'Status': '', 'i_sqn': 254}}, '02': {'0001': {'Target': '0000', 'Stamp': 1663129530, 'Phase': 'requested', 'Status': '', 'i_sqn': 255}, '0003': {'Target': '0000', 'Stamp': 1663129530, 'Phase': 'requested', 'Status': '', 'i_sqn': 256}}, '03': {'0001': {'Target': '0000', 'Stamp': 1663129530, 'Phase': 'requested', 'Status': '', 'i_sqn': 257}, '0003': {'Target': '0000', 'Stamp': 1663129530, 'Phase': 'requested', 'Status': '', 'i_sqn': 258}}}, 'BindingTable': {'Devices': [], 'SQN': 0, 'TimeStamp': 1663129530.2735417}, 'ZDPSQN': '01', 'ZDeviceVersion': '0001'}
2022-09-14 06:25:36,238 INFO    : [ZiGateForwarder_2] MajDomoDevice NwkId: d5bd status: provREQ not inDB
2022-09-14 06:25:40,380 INFO    : [       MainThread] Request Disabling Accepting new Hardware
2022-09-14 06:25:40,381 INFO    : [       MainThread] WARNING - send_zigatecmd : [327] 0049           FFFC0000 None ZigateQueue: 65
2022-09-14 06:25:40,383 INFO    : [       MainThread] WARNING - send_zigatecmd : [328] 0014                    None ZigateQueue: 66
2022-09-14 06:26:45,135 INFO    : [ZiGateForwarder_2] Accepting new Hardware: Disable (Off)
Posted: Wednesday 14 September 2022 6:44
by julienb
This is the json raw export, stripped from other devices:
    "Status": "",
    "RIA": "10",
    "ZDeviceName": "Zigbee Coordinator",
    "LogicalType": "Coordinator",
    "IEEE": "00158d0006a3fd28",
    "PowerSource": "Main",
    "Ep": {
      "15": {
        "1000": {},
        "0000": {},
        "0003": {},
        "0204": {},
        "0b03": {},
        "0300": {},
        "0004": {},
        "0008": {},
        "0006": {},
        "0005": {},
        "0101": {},
        "0702": {},
        "0500": {},
        "0019": {},
        "0201": {},
        "0401": {},
        "0400": {},
        "0406": {},
        "0403": {},
        "0405": {},
        "0402": {},
        "0001": {},
        "0b05": {}
      "26": {
        "1000": {},
        "0000": {},
        "0003": {},
        "0204": {},
        "0b03": {},
        "0300": {},
        "0004": {},
        "0008": {},
        "0006": {},
        "0005": {},
        "0101": {},
        "0702": {},
        "0500": {},
        "0019": {},
        "0201": {},
        "0401": {},
        "0400": {},
        "0406": {},
        "0403": {},
        "0405": {},
        "0402": {},
        "0001": {},
        "0b05": {}
      "01": {
        "1000": {},
        "0000": {},
        "0003": {},
        "0019": {},
        "000f": {},
        "0b03": {},
        "0300": {},
        "0004": {},
        "0008": {},
        "0006": {},
        "0005": {},
        "0702": {},
        "0500": {},
        "0201": {},
        "0401": {},
        "0400": {},
        "0406": {},
        "0403": {},
        "0405": {},
        "0402": {},
        "0204": {},
        "0001": {},
        "0b05": {}
      "0a": {
        "1000": {},
        "0000": {},
        "0003": {},
        "0204": {},
        "0b03": {},
        "0300": {},
        "0004": {},
        "0008": {},
        "0006": {},
        "0005": {},
        "0101": {},
        "0702": {},
        "0500": {},
        "0019": {},
        "0201": {},
        "0401": {},
        "0400": {},
        "0406": {},
        "0403": {},
        "0405": {},
        "0402": {},
        "0001": {},
        "0b05": {}
      "03": {
        "0000": {},
        "0019": {}
      "0b": {
        "0000": {},
        "0019": {}
      "6e": {
        "1000": {},
        "0000": {},
        "0003": {},
        "0204": {},
        "0b03": {},
        "0300": {},
        "0004": {},
        "0008": {},
        "0006": {},
        "0005": {},
        "0101": {},
        "0702": {},
        "0500": {},
        "0019": {},
        "0201": {},
        "0401": {},
        "0400": {},
        "0406": {},
        "0403": {},
        "0405": {},
        "0402": {},
        "0001": {},
        "0b05": {}
      "08": {
        "0001": {}
      "f2": {
        "0021": {}
    "Version": "3",
    "Neighbours": [
        "Time": "2022-05-05 16:52:24",
        "Devices": [
            "030b": {
              "_relationshp": "Child",
              "_devicetype": "Router",
              "_depth": 1,
              "_lnkqty": 154,
              "_rxonwhenidl": "Rx-On",
              "_IEEE": "50325ffffe587186",
              "_permitjnt": "??"
            "2778": {
              "_devicetype": "End Device",
              "_depth": 1,
              "_lnkqty": 84,
              "_rxonwhenidl": "Rx-Off",
              "_IEEE": "847127fffef4f1b7",
              "_permitjnt": "??"
            "76bf": {
              "_relationshp": "Sibling",
              "_depth": 0,
              "_lnkqty": 21,
              "_IEEE": "cc86ecfffead0e05",
              "_permitjnt": "??"
            "d5bd": {
              "_depth": 0,
              "_lnkqty": 28,
              "_IEEE": "cc86ecfffebfa0ee",
              "_permitjnt": "??"
        "Time": "2022-05-06 06:19:18",
        "Devices": [
            "030b": {
              "_depth": 1,
              "_lnkqty": 152,
              "_permitjnt": "??"
            "2778": {
              "_depth": 1,
              "_lnkqty": 88,
              "_permitjnt": "??"
            "55d8": {
              "_depth": 0,
              "_lnkqty": 68,
              "_IEEE": "b4e3f9fffe780035",
              "_permitjnt": "??"
        "Time": "2022-05-12 13:11:38",
        "Devices": [
            "030b": {
              "_depth": 1,
              "_lnkqty": 155,
              "_permitjnt": "??"
            "2778": {
              "_depth": 1,
              "_lnkqty": 84,
              "_permitjnt": "??"
            "316c": {
              "_depth": 0,
              "_lnkqty": 33,
              "_IEEE": "50325ffffe304535",
              "_permitjnt": "??"
            "d5bd": {
              "_depth": 0,
              "_lnkqty": 41,
              "_permitjnt": "??"
            "76bf": {
              "_depth": 0,
              "_lnkqty": 26,
              "_permitjnt": "??"
        "Time": "2022-09-11 09:38:29",
        "Devices": [
            "030b": {
              "_depth": 0,
              "_lnkqty": 151,
              "_permitjnt": "??"
            "d5bd": {
              "_depth": 0,
              "_lnkqty": 39,
              "_permitjnt": "??"
            "316c": {
              "_depth": 0,
              "_lnkqty": 56,
              "_permitjnt": "??"
            "76bf": {
              "_depth": 0,
              "_lnkqty": 28,
              "_permitjnt": "??"
            "d7cc": {
              "_depth": 0,
              "_lnkqty": 21,
              "_IEEE": "50325ffffe241faf",
              "_permitjnt": "??"
    "Health": "",
    "ConsistencyCheck": "",
    "Model": "ZiGate+ (V2)",
    "NwkID": "0000"
    "Version": "3",
    "ZDeviceName": "",
    "Status": "inDB",
    "SQN": "a1",
    "Heartbeat": "106",
    "RIA": "0",
    "LQI": 61,
    "Battery": 125,
    "Model": "ZG2858A",
    "ForceAckCommands": [],
    "MacCapa": "80",
    "IEEE": "84ba20fffec4d327",
    "Type": "ColorControlFull",
    "ProfileID": "0104",
    "ZDeviceID": "0105",
    "App Version": "0",
    "Attributes List": {},
    "DeviceType": "RFD",
    "HW Version": "0",
    "Last Cmds": [
        316,
        "02",
        "1794",
        "0100",
        "0103000000000000010000"
        317,
        "02",
        "1794",
        "0100",
        "0103000000000000010001"
        318,
        "02",
        "1794",
        "0100",
        "0103000000000000010002"
        319,
        "02",
        "1794",
        "0100",
        "0103000000000000010003"
        320,
        "02",
        "1794",
        "0100",
        "0103000000000000010004"
        321,
        "02",
        "1794",
        "0100",
        "0103000000000000010005"
        322,
        "02",
        "1794",
        "0100",
        "0103000000000000010007"
        323,
        "02",
        "1794",
        "0100",
        "010300000000000001000a"
        324,
        "02",
        "1794",
        "0100",
        "0103000000000000014000"
        325,
        "07",
        "1794",
        "00E0",
        "01010000"
    "LogicalType": "End Device",
    "Manufacturer": "1224",
    "Manufacturer Name": "Sunricher",
    "NbEp": "3",
    "PowerSource": "Battery",
    "ReadAttributes": {
      "Ep": {
        "01": {
          "0000": {
            "TimeStamp": "14/09/2022 06:26:25",
            "iSQN": {
              "4000": 306,
              "0000": 298,
              "0001": 299,
              "0002": 300,
              "0003": 301,
              "0004": 302,
              "0005": 303,
              "0007": 304,
              "000a": 305
            "Attributes": {
              "4000": "00",
              "0000": "00",
              "0001": "00",
              "0002": "00",
              "0003": "00",
              "0004": "00",
              "0005": "00",
              "0007": "00",
              "000a": "00"
            "ZigateRequest": {}
          "0001": {
            "TimeStamp": "14/09/2022 06:25:40",
            "iSQN": {
              "0020": 259,
              "0021": 260,
              "0033": 261
            "Attributes": {
              "0020": "00",
              "0021": "00",
              "0033": "00"
            "ZigateRequest": {}
          "0019": {
            "TimeStamp": "14/09/2022 06:25:56",
            "iSQN": {
              "0001": 268,
              "0002": 269,
              "0003": 270,
              "0004": 271,
              "0005": 272,
              "0006": 273,
              "0007": 274,
              "0008": 275,
              "0009": 276,
              "000a": 277
            "Attributes": {
              "0001": "86",
              "0002": "86",
              "0003": "86",
              "0004": "86",
              "0005": "86",
              "0006": "86",
              "0007": "86",
              "0008": "86",
              "0009": "86",
              "000a": "86"
            "ZigateRequest": {}
        "02": {
          "0000": {
            "TimeStamp": "14/09/2022 06:26:34",
            "iSQN": {
              "4000": 315,
              "0000": 307,
              "0001": 308,
              "0002": 309,
              "0003": 310,
              "0004": 311,
              "0005": 312,
              "0007": 313,
              "000a": 314
            "Attributes": {
              "4000": "00",
              "0000": "00",
              "0001": "00",
              "0002": "00",
              "0003": "00",
              "0004": "00",
              "0005": "00",
              "0007": "00",
              "000a": "00"
            "ZigateRequest": {}
          "0001": {
            "TimeStamp": "14/09/2022 06:25:43",
            "iSQN": {
              "0020": 262,
              "0021": 263,
              "0033": 264
            "Attributes": {
              "0020": "00",
              "0021": "00",
              "0033": "00"
            "ZigateRequest": {}
          "0019": {
            "TimeStamp": "14/09/2022 06:26:06",
            "iSQN": {
              "0001": 278,
              "0002": 279,
              "0003": 280,
              "0004": 281,
              "0005": 282,
              "0006": 283,
              "0007": 284,
              "0008": 285,
              "0009": 286,
              "000a": 287
            "Attributes": {
              "0001": "86",
              "0002": "86",
              "0003": "86",
              "0004": "86",
              "0005": "86",
              "0006": "86",
              "0007": "86",
              "0008": "86",
              "0009": "86",
              "000a": "86"
            "ZigateRequest": {}
        "03": {
          "0000": {
            "TimeStamp": "14/09/2022 06:26:43",
            "iSQN": {
              "4000": 324,
              "0000": 316,
              "0001": 317,
              "0002": 318,
              "0003": 319,
              "0004": 320,
              "0005": 321,
              "0007": 322,
              "000a": 323
            "Attributes": {
              "4000": "00",
              "0000": "00",
              "0001": "00",
              "0002": "00",
              "0003": "00",
              "0004": "00",
              "0005": "00",
              "0007": "00",
              "000a": "00"
            "ZigateRequest": {}
          "0001": {
            "TimeStamp": "14/09/2022 06:25:46",
            "iSQN": {
              "0020": 265,
              "0021": 266,
              "0033": 267
            "Attributes": {
              "0020": "00",
              "0021": "00",
              "0033": "00"
            "ZigateRequest": {}
          "0019": {
            "TimeStamp": "14/09/2022 06:26:16",
            "iSQN": {
              "0001": 288,
              "0002": 289,
              "0003": 290,
              "0004": 291,
              "0005": 292,
              "0006": 293,
              "0007": 294,
              "0008": 295,
              "0009": 296,
              "000a": 297
            "Attributes": {
              "0001": "86",
              "0002": "86",
              "0003": "86",
              "0004": "86",
              "0005": "86",
              "0006": "86",
              "0007": "86",
              "0008": "86",
              "0009": "86",
              "000a": "86"
            "ZigateRequest": {}
    "ReceiveOnIdle": "",
    "Stack Version": "0",
    "Stamp": {
      "time": 1663129606.7959769,
      "Time": "2022-09-14 06:26:46",
      "MsgType": "8011",
      "LastSeen": "14/09/2022 06:26:46"
    "ZCL Version": "3",
    "Health": "Live",
    "Capability": [
      "Reduced-Function Device",
      "Standard security",
      "NwkAddr should be allocated"
    "RollingLQI": [
      62,
      59,
      60,
      59,
      61,
      60,
      61,
      60,
      59,
      60,
      61
    "Epv2": {
      "01": {
        "ClusterIn": {
          "1000": {},
          "0000": {},
          "0001": {},
          "0003": {},
          "0b05": {}
        "ClusterOut": {
          "1000": {},
          "0003": {},
          "0004": {},
          "0005": {},
          "0006": {},
          "0008": {},
          "0019": {},
          "0300": {}
        "ZDeviceID": "0105"
      "02": {
        "ClusterIn": {},
        "ClusterOut": {},
        "ProfileID": {},
        "ZDeviceID": {}
      "03": {
        "ClusterIn": {},
        "ClusterOut": {},
        "ProfileID": {},
        "ZDeviceID": {}
    "WriteAttributes": {
      "Ep": {
        "01": {
          "0000": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0001": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0003": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0004": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0005": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0006": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0008": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0019": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0300": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0b05": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
        "02": {
          "0000": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0001": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0003": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0004": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0005": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0006": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0008": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0019": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0300": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0b05": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
        "03": {
          "0000": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0001": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0003": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0004": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0005": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0006": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0008": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0019": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0300": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
          "0b05": {
            "TimeStamp": 0,
            "iSQN": {},
            "Attributes": {},
            "ZigateRequest": {}
    "ConfigSource": "DeviceConf",
    "Ep": {
      "01": {
        "0000": {
          "4000": "2.7.6_r22",
          "0004": "Sunricher",
          "0005": "ZG2858A",
          "0000": "3",
          "0001": "0",
          "0002": "0",
          "0003": "0",
          "0007": "3",
          "000a": "3030"
        "0001": {
          "0021": 125,
          "0020": 27,
          "0033": 0
        "0003": {},
        "0004": {},
        "0005": {},
        "0006": {},
        "0008": {},
        "0019": {},
        "0300": {},
        "0b05": {},
        "ClusterType": {
          "38": "ColorControlFull"
      "02": {
        "0000": {
          "0005": "ZG2858A",
          "0000": "3",
          "0001": "0",
          "0002": "0",
          "0003": "0",
          "0007": "3",
          "000a": "3030"
        "0001": {
          "0020": 27,
          "0021": 125,
          "0033": 0
        "0003": {},
        "0004": {},
        "0005": {},
        "0006": {},
        "0008": {},
        "0019": {},
        "0300": {},
        "0b05": {},
        "ClusterType": {
          "39": "ColorControlFull"
      "03": {
        "0000": {
          "0005": "ZG2858A",
          "0000": "3",
          "0001": "0",
          "0002": "0",
          "0003": "0",
          "0007": "3",
          "000a": "3030"
        "0001": {
          "0020": 27,
          "0021": 125,
          "0033": 0
        "0003": {},
        "0004": {},
        "0005": {},
        "0006": {},
        "0008": {},
        "0019": {},
        "0300": {},
        "0b05": {},
        "ClusterType": {
          "40": "ColorControlFull"
    "BatteryUpdateTime": "14/09/2022 06:25:46",
    "PairingInProgress": false,
    "PairingTime": 1663129530.1305754,
    "Bind": {
      "01": {
        "0001": {
          "Target": "0000",
          "Stamp": "14/09/2022 06:25:32",
          "Phase": "binded",
          "Status": "00",
          "i_sqn": 253
        "0003": {
          "Target": "0000",
          "Stamp": "14/09/2022 06:25:33",
          "Phase": "binded",
          "Status": "00",
          "i_sqn": 254
      "02": {
        "0001": {
          "Target": "0000",
          "Stamp": "14/09/2022 06:25:34",
          "Phase": "binded",
          "Status": "00",
          "i_sqn": 255
        "0003": {
          "Target": "0000",
          "Stamp": "14/09/2022 06:25:35",
          "Phase": "binded",
          "Status": "00",
          "i_sqn": 256
      "03": {
        "0001": {
          "Target": "0000",
          "Stamp": "14/09/2022 06:25:36",
          "Phase": "binded",
          "Status": "00",
          "i_sqn": 257
        "0003": {
          "Target": "0000",
          "Stamp": "14/09/2022 06:25:37",
          "Phase": "binded",
          "Status": "00",
          "i_sqn": 258
    "BindingTable": {
      "Devices": [
          "84ba20fffec4d327": {
            "sourceEp": "01",
            "Cluster": "0001",
            "targetIEEE": "00158d0006a3fd28",
            "targetNickName": "Zigbee Coordinator",
            "targetEp": "01"
            "sourceEp": "01",
            "Cluster": "0003",
            "targetEp": "01"
            "sourceEp": "02",
            "Cluster": "0001",
            "targetEp": "01"
            "sourceEp": "02",
            "Cluster": "0003",
            "targetEp": "01"
            "sourceEp": "03",
            "Cluster": "0001",
            "targetEp": "01"
            "sourceEp": "03",
            "Cluster": "0003",
            "targetEp": "01"
      "SQN": 0,
      "TimeStamp": "14/09/2022 06:26:45",
      "BindingTableTableSize": 6,
      "Status": "Success"
    "ZDPSQN": "03",
    "ZDeviceVersion": "0001",
    "Max Buffer Size": "52",
    "Max Rx": "0052",
    "Max Tx": "0052",
    "macapa": "80",
    "bitfield": "4002",
    "server_mask": "2c00",
    "descriptor_capability": "00",
    "SWBUILD_3": "2.7.6_r22",
    "NwkID": "1794"
Posted: Wednesday 14 September 2022 10:36
by pipiche
Thanks for all those information. Indeed I did the test some times ago and that should work. UNfortunatly I don't have the device with me at that time to test it.
I wonder if the Group 0000 should nbot be created.
Can you try that ?
Screenshot 2022-09-14 at 10.35.13.png (102.26 KiB) Viewed 942 times
Posted: Wednesday 14 September 2022 13:08
by julienb
Thanks for your support.
I tried that (enabled groups, they were not, checked the create group 0000, rebooted domoticz), and repaired the device. I still get the same behaviour. Group 0000 shows up correctly in group management page. No device in this group, i put one, and could see it created in domoticz (one of the lights i want to control), but i can't put the remote in the group (only routers).
Any ideas or logs i should enable ?
Posted: Wednesday 14 September 2022 13:16
by pipiche
Honestly I have no clue. This remote was added in November 2021.
I should get access to the device next week, I'll investigate if there is any regression ether on the plugin or at the firmware.
To investigate the best would be to sniff the zigbee traffic. If you have a sniffer that would really help
You can eventually try to add debugInput, this most-likely log all incoming messages.
Which ZIgate firmware are you running ?
Posted: Thursday 15 September 2022 7:51
by julienb
I just checked, and i'm using firmware v321. I don't have a sniffer, but given the low price of it i'm considering buying one (i have some experience with industrial buses (CAN), from what i have seen zigbee shares a lot of concepts). Enabling debug input did not yield any result, i don't see anything matching my device id.
I'll make more tests, but won't have time till next week. Thanks !
Posted: Thursday 15 September 2022 10:21
by pipiche
Ok, good I’ll keep you posted as soon as I can test also
Posted: Tuesday 08 November 2022 7:57
by julienb
Did you by chance had the time to test with the device ? I updated with 6.3.005, repaired the device, without any luck.Devices pairs successfully, but no events are received in domoticz. Even the plugin log is not helpful. I just get this which may be relevant:
sudo grep ERROR PluginZigbee_02.log
2022-11-08 07:50:01,030 ERROR   : [ZiGateForwarder_2] Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: db Status: [06]
2022-11-08 07:53:45,391 ERROR   : [   ZiGateSerial_2] NXP_Extended_Error_Code - Extended Error Code: [8b] No Broadcast transaction table entries free
For the zigbee sniffer, i've seen lots of tutorials, but all of them seems to involve windows. Do you know of any that could be done from a linux machine ?
Thanks,
Posted: Tuesday 08 November 2022 8:09
by julienb
Just an addition: direct coupling works fine, i can control a light that is directly coupled with the device. But i can't retrieve the state of the device in domoticz.
Posted: Tuesday 14 March 2023 19:56
by RezaRose
Did you fix this problem?
I get allmost the same errors with aqara bulbs
2023-03-13 20:29:54.920 Error: Zigate: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: 7a Status: [06]
2023-03-13 20:32:00.550 Error: Zigate: Decode8000 - PacketType: 00e0 TypeSqn: 01 sqn_app: 00 sqn_aps: ba Status: [06]
I get a widget in Domoticz, but the light does not respond to anything.
Posted: Tuesday 14 March 2023 21:47
by pipiche
I read in some of the forum that the error 06 could be related to the fact that the Zigate belongs to too many groups.
