P1 smart meter doesn't add up
Posted: Thursday 01 September 2022 17:46
by Rolandet
Usually the p1 smart meter data, show the power sent to the grid, minus the power used and that very moment.
Recently I saw that the widget on the Utility page shows both,
and the counter on the dashboard switches between the two, every now and then (can't quite count seconds/minutes of it switching but when if f5 the page it FIRST shows usage, and then switches to kwh sent)
stroom 2.JPG (18.08 KiB) Viewed 742 times
stroom 1.JPG (15.37 KiB) Viewed 742 times
Anyway: i was wondering if anybody has ever seen that behaviour, and what might be done about it.
Re: P1 smart meter doesn't add up
Posted: Thursday 01 September 2022 23:38
Did you update to the latest Domoticz version 2022.1? Your signature says you are using an old version 2021.1
Posted: Thursday 01 September 2022 23:43
by Rolandet
Ah yeah, need to adjust my sig
2022.1 indeed.
I got a 2nd installment (this one is at my mother's ) which is showing correct figures
Posted: Thursday 01 September 2022 23:46
Rolandet wrote: Thursday 01 September 2022 23:43 Ah yeah, need to adjust my sig
2022.1 indeed.
Perhaps check the Decimals setting for P1 meter as it introduces some issues:
https://www.domoticz.com/wiki/Applicati ... r_Dividers
Posted: Saturday 03 September 2022 16:08
by willemd
My P1 meter works still normal as before, no problem. Mine is updated with the HTTP poller from a Homewizard WIFI meter API page.
Posted: Saturday 03 September 2022 17:22
by Rolandet
willemd wrote: Saturday 03 September 2022 16:08
TNx
My p1 meter works fine, no issues
The issue is in the presentation layer of domoticz.
@waltervl: i've checked the settings. Fiddled around with it, but no change yet.
Posted: Saturday 03 September 2022 23:19
I can confirm that on latest beta I see the same behaviour, only one of the usage/return values are mentioned. In mobile layout I see both values....
Does your mother also has a recent version?
Posted: Sunday 04 September 2022 12:54
by Rolandet
waltervl wrote: Saturday 03 September 2022 23:19 I can confirm that on latest beta I see the same behaviour, only one of the usage/return values are mentioned. In mobile layout I see both values....
I must admit I haven't checked for an update for a while, but both Pi's have
Version: 2022.1
Build Hash: c9526851b
