energy usage data from Tasmota Plugs to Domoticz
Stokie21
Post by Stokie21 »
Hi All,
I have some plugs that i flashed with Tasmota. when you goto the web interface of the plug via a local ip address it will show the energy usage of the plug. Is there a way to get this information into Domoticz?
I will have 16 of these plugs so if possible i would also like to keep it as tidy as possible
Domoticz version: 2024.7
Re: energy usage data from Tasmota Plugs to Domoticz
You should be able to do that with MQTT Autodiscover. You have to switch MQTT Autodiscover on in Tasmota and have a MQTT Broker running.
Further use instructions on wiki https://www.domoticz.com/wiki/MQTT#Add_ ... Gateway.22
Edit: See also https://tasmota.github.io/docs/Domoticz ... figuration
