Database & Logs Export Scripts
elzorrovega
Domoticz version: 2025.2
Post by elzorrovega »
Hello All,
I have some issues with one of my FIBARO motion detectors connected to my Domoticz. It triggered some false alarms while away. Battery has been recently changed and all parameters settings are identical to similar devices. I wish to study it closely to determine if there is a valid reason for triggering movement or the device is just at the end of life. DzVents Log Level is set to Error+minimal execution info but since log lines are limited by the time that one might investigate them, they are gone!
While looking in the fora, I discovered interesting posts concerning exporting both logs and data from our sqlite Domoticz.
Beyond knowing the abbreviation SQL I claim ignorance concerning the subject. However I read enough in the web pages to get the following structure of our venerable Domoticz.
Here is a site that allowed me to get this far.
https://ourtechroom.com/tech/open-read-sqlite-file/
DOMOTICZ SQLITE Database Structure
  • BackupLog MobileDevices Scenes
    Cameras MultiMeter SetpointTimers
    CamerasActiveDevices MultiMeter_Calendar SharedDevices
    CustomImages MySensors Temperature
    DeviceStatus MySensorsChilds Temperature_Calendar
    DeviceToPlansMap MySensorsVars TimerPlans
    EnOceanNodes Notifications Timers
    EventMaster Percentage ToonDevices
    EventRules Percentage_Calendar UV
    Fan Plans UV_Calendar
    Fan_Calendar Preferences UserSessions
    Floorplans PushLink UserVariables
    Hardware Rain Users
    LightSubDevices Rain_Calendar WOLNodes
    LightingLog SceneDevices Wind
    Meter SceneLog Wind_Calendar
    Meter_Calendar SceneTimers ZwaveNodes
I added to the existing contributions from waaren, fzoet and others viewtopic.php?t=30725&hilit=export+data
To develop the following:
DzVents script defining data to be extracted from Domoticz database. I was interested in the Switch data but then again you may adapt it to whatever other information is needed.
This script will make a temporary copy of actual database; extract requested data and copy it to a csv file.
Script will also make a call to Bash script which makes json call to export log. AWK commands format output and remove unnecessary data.
SIGNAL_DEVICES in script allow data collection when devices are On. One can also juggle with triggers to get the needed effect.
Again my goal is to allow automatic data export to files which can be analysed at a one’s leisure. File names are time stamped to allow user to pinpoint the incident better.
Hope others find this useful!
ElZorroVega
P.S. Included MAWK commands directly to BASH script to avoid reading a separate MAWK file.
DzVents Script
--[[ -- sqliteDump.lua
        Dumps daily data as csv file
        requires sqlite3 in host machine
            install command on linux:    sudo apt install sqlite3
            install command on openwrt:  opkg install sqlite3-cli
            install command on synology: sudo /opt/bin/opkg install sqlite3-cli
            History:
            20191231 first public release
            20200102 Add sudo chmod to make csvfile readable for all
            20201023 Add option to use MultiMeter
            20201026 Added option to get daily data, and included yesterdays' date to csv filename
            20220816 Added option to get switch data and combined with log export Bash Script
local SIGNAL_DEVICES = {
        'Hall Siren',
        'Chamber 1 Siren',
        'Fibaro Wall Plug 1'
return
    active = true,
    on =
        timer =
            --'at 00:04',
            --'at 17:16',
        devices =
            'Fibaro Wall Plug 1',
            --'Hall Motion Sensor'
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all is OK
        marker = 'sqliteDump',
    execute = function(dz, item)
    -- =======================  enter you settings below this line ==================
        local path = "/home/pi/domoticz/" -- full qualified path to your domoticz directory
        local database = 'domoticz.db'    -- database filename + extension
        local sqlite = '/usr/bin/sqlite3' -- location of your sqlite3 tool; check with 'which sqlite3'
        local csvFile = "/home/pi/Documents/domoticz2excel" --full path to the csv filename for the dump, without the .csv extension (will be added by script, together with date)
        -- set to '' for the types you don't need
        --[[local allTemperatures = '152,148' -- comma separated list of Temperature sensors to export --
        local allMeters = '36,1168,2872' -- comma separated list of Solar +  Meters + Usage sensors
        local allMultiMeters = '17' -- comma separated list P1 energy sensor
        local allTemperatures = '12,16,38,62,78,83' -- comma separated list of Temperature sensors to export]]--
        local allSwitches = '9'
        -- =======================  No modification needed in this block ==================
        local csvFile = csvFile .. "_" .. os.date("%Y-%m-%d",os.time()) .. ".csv"
        local copy = 'safeCopy.db'
        local baseCommand = 'sudo ' .. sqlite .. ' -header -csv ' .. copy
        local closure     = ' >> '  .. csvFile
        local collects = {}
        -- =======================  Adjust the SQL Query(ies)  in acordance to your needs following attention database structure ==================
        --=======================  https://inloop.github.io/sqlite-viewer/ =======================
        --==Query for daily data==
         --[[collects.meters = 'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Counter Counter, b.Date Date FROM DeviceStatus a , Meter_Calendar b ' ..
                           ' WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ');'
        collects.Temperatures = 'SELECT a.ID Temperature, a.Name Name, b.Temp_Min min, b.Temp_Max max, b.Temp_Avg avg, b.Date Date ' ..
                                ' FROM DeviceStatus a , Temperature_Calendar b WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allTemperatures .. ') ORDER BY a.ID;'
        collects.MultiMeters = 'SELECT a.Name, b.* FROM DeviceStatus a , MultiMeter_Calendar b WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allMultiMeters .. ') ORDER BY b.DeviceRowID;']]--
        --==end query daily data
        --==Query for minute data
        --[[collects.meters =   'SELECT a.ID Meter, a.Name Name, b.Value Value, b.Usage Usage, b.Date Date '..
                            ' FROM DeviceStatus a , Meter b WHERE a.ID = b.DeviceRowID AND a.ID IN (' .. allMeters .. ')'
        collects.MultiMeters =  'SELECT a.Name, b.* FROM DeviceStatus a , MultiMeter b WHERE a.ID = b.DeviceRowID ' ..
                                ' AND a.ID IN (' .. allMultiMeters .. ') ORDER BY b.DeviceRowID'
        collects.Temperatures = 'SELECT a.ID ID, a.Name Name, b.Temperature Temperature, b.Date Date ' ..
                                ' FROM DeviceStatus a , Temperature b WHERE a.ID = b.DeviceRowID AND ' ..
                                ' a.ID IN ( '.. allTemperatures .. ') ORDER BY a.ID '
        --==end query minute data
        Hardware              Rain                  Users
        Meter_Calendar        SceneTimers           ZWaveNodes]]--
        --==Query for Switches
        collects.LightingLogs = 'SELECT b.Date Date, a.ID ID, a.Name Name, b.nValue nValue ' ..
                                ' FROM DeviceStatus a , LightingLog b WHERE a.ID = b.DeviceRowID AND ' ..
                                ' a.ID IN ( '.. allSwitches .. ') ORDER BY a.ID '
        local function osCommand(cmd)
            dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            if commandOutput:find '::ERROR::' then     -- something went wrong
            dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_DEBUG)
            else -- all is fine!!
                dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
        local function sqliteDump()
            local result, rc
            if dz.utils.fileExists(path .. database) then
                if dz.utils.fileExists(sqlite) then
                    result, rc  = osCommand('cp '  .. path .. database .. ' ' .. copy)
                    if rc ~= 0 then return rc, result end
                    result, rc  = osCommand('rm -f '  .. csvFile)
                    for _, sql in pairs (collects) do
                        result, rc  = osCommand(baseCommand .. ' "' .. sql .. '" ' .. closure)
                    result, rc  = osCommand('rm -f '  .. copy)
                    result, rc  = osCommand('sudo chmod 777 '  .. csvFile)
                    return -1,'sqlite3 not installed / not found'
                return -1,'wrong path to database'
            return commandOutput, 0
-- Collection Iterator using nested filter and reduce functions
	    local noise = dz.devices().filter(SIGNAL_DEVICES)
	        .reduce(
	        function (acc, device)
                dz.log('Device: ' .. device.name)
	            if device.state == 'On' or device.state == 'Open' then
	                acc = true
  	            return acc
       end, false)
--        local noises = dz.devices().filter(SIGNAL_DEVICES)
--        noises.forEach(function(noise)
--            dz.log('Device: ' .. noise.name)
--            if noise.state == 'On' or noise.state == 'Open' then
--                count = true
--            else
--                count = false
--            end
--        end)
        -- main program
        if noise == true then
            local result, rc = sqliteDump()
            if rc ~= 0 then dz.log(result,dz.LOG_ERROR) end
        --  call Bash Script using JSON calls to export logs to file
            local result, rc = osCommand('/home/pi/Scripts/getdzlog.sh log')
GetDZLog.sh Bash Script
#!/bin/bash
# Script is to get log files from Domoticz when security alarm is tripped
# El Zorro 30/07/22
# /json.htm?type=command&param=getlog&lastlogtime=LASTLOGTIME&loglevel=LOGLEVEL
# LOGLEVEL 1 = normal
#          2 = status
#          4 = error
#  268435455 = all
DHOST=192.168.1.30:8080
MESSAGE='Hello+DOMOTICZ'
lnormal=1
lstatus=2
lerror=4
lall=268435455
LASTLOGTIME=0
LEVEL=$lnormal
LOGLEVEL=$lall
IDX_Chamber_1_Siren=7
IDX_Hall_Siren=22
Chamber_1_Siren=$(curl -s 'http://'$DHOST'/json.htm?type=devices&rid='$IDX_Chamber_1_Siren'' | mawk '/Status/ { gsub (/^[ \t]+|[ \t]+$/, ""); gsub(/"Status" : /,""); gsub(/"/,""); gsub(/,/,"") ; print }')
Hall_Siren=$(curl -s 'http://'$DHOST'/json.htm?type=devices&rid='$IDX_Hall_Siren'' | mawk '/Status/ { gsub (/^[ \t]+|[ \t]+$/, ""); gsub(/"Status" : /,""); gsub(/"/,""); gsub(/,/,"") ; print }')
date_now=$(date +"%Y%m%d%H%M")
curl -s 'http://'$DHOST'/json.htm?type=command&param=addlogmessage&message='$MESSAGE'&level='$LEVEL''
if [ "$#" != "1" ]; then
	curl -s 'http://'$DHOST'/json.htm?type=command&param=getlog&lastlogtime='$LASTLOGTIME'&loglevel='$LOGLEVEL'' | mawk 'BEGIN {print ("DOMOTICZ LOG Information")} /message/ { gsub(/\{/, //) ; gsub(/\}/,//) ; gsub(/\[/,//); gsub(/\]/,//); gsub (/^[ \t]+|[ \t]+$/, ""); gsub(/"message" : /,""); gsub(/"/,"") ; print }'
	curl -s 'http://'$DHOST'/json.htm?type=command&param=getlog&lastlogtime='$LASTLOGTIME'&loglevel='$LOGLEVEL'' | mawk 'BEGIN {print ("DOMOTICZ LOG Information")} /message/ { gsub(/\{/, //) ; gsub(/\}/,//) ; gsub(/\[/,//); gsub(/\]/,//); gsub (/^[ \t]+|[ \t]+$/, ""); gsub(/"message" : /,""); gsub(/"/,"") ; print }' > "/home/pi/Documents/$1$date_now"
	sudo chmod 777 /home/pi/Documents/$1$date_now
	fi
exit
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
