Netatmo authentication changes Oct 2022
Re: Netatmo authentication changes Oct 2022
For now a week, the Netatmo domoticz process reads correctly all of the data for the Meteo Station (temp, humidity, co2, rain, Wind,...) and the thermostats data but after few hours it stops reading only my Thermostats data.
If I regenerate the password of the Netatmo device on the hardware page as specified in https://wiki.domoticz.com/Netatmo, the thermostats data are read again for few hours. It can be 6 or 8 or 12 hours.
The meteo data continue to be updated.
That means the connection to the Netatmo server is still live.
Is anybody experiencing this behavior?
Does somebody has an idea why the thermostats data stop to be updated while the meteo data continue to be updated?
- Domoticz version: 2024.7
what is the version you are running ?jpcasta wrote: ↑Friday 20 December 2024 16:25 Hello,
Are you using the beta-channel ?
I am running Domoticz 2024.7 (latest stable)
I am not using the beta-channel.
I'm having exactly the same problem as you with my Netatmo thermostat.
My Domoticz v2024.7 (stable channel / Build Hash: b317cfab1 / Compile Date: 2024-07-13 16:59:31) runs on a Linux Lubuntu 20.04.
Connection to the server works for a few hours then error messages:
Thermostat Netatmo: No access granted, forcing login again...
Thermostat Netatmo: No access granted, check credentials...
Regards,
Franck
There where changes from Netamo API, they are adapted in the Beta channel not yet in the Latest Stable.
After updating my version of Domoticz with the latest version of the beta channel and after more than 24 hours of testing, I no longer get any “No access granted” errors.
Thanks for all homeJLB !
Regards,
Franck,
Same things than "zxdscp". After 24h, it is still returning all of the data using the latest beta version with the new Netatmo login.
Thanks to all!
What type hardware must be? If I chose "Netatmo" I don't see field clientID and client secret only Username: and Password:qqlapraline wrote: ↑Tuesday 05 November 2024 21:48
Under 16325 build, I have tried the following
- Enter <ClientID> in the clientID field and <Client Secret> in the client secret field.
- a popup appears to confirm access to the appropriate scope.
- the login seems successfull but when I click on « add » a popup tells me that I am not logged on.
Version: 2024.7
@wpsabek, I am using beta version Domoticz 2024.7 (build 16406)
There is the following change that has been implemented:
- Changed: Improved and automated login process for Netatmo devices (to obtain client ID and Password with user selectable scopes)
Adding Netatmo hardware you should get fields "Client ID" and "Client Secret".
In the "Scope" field you select the information you want to get from Netatmo.
For Netatmo you use the correct Hardware.wpsabek wrote: ↑Sunday 05 January 2025 13:41What type hardware must be? If I chose "Netatmo" I don't see field clientID and client secret only Username: and Password:qqlapraline wrote: ↑Tuesday 05 November 2024 21:48
Version: 2024.7
Your Version 2024.7 is the Last Stable and still use the old Netatmo API code, the changed code is now in the Beta-channel
With that version you have to use the Old way https://wiki.domoticz.com/index.php?tit ... ldid=18755
Kind Regards
