Netatmo authentication changes Oct 2022
jpcasta
Re: Netatmo authentication changes Oct 2022
Post by jpcasta »
For now a week, the Netatmo domoticz process reads correctly all of the data for the Meteo Station (temp, humidity, co2, rain, Wind,...) and the thermostats data but after few hours it stops reading only my Thermostats data.
If I regenerate the password of the Netatmo device on the hardware page as specified in https://wiki.domoticz.com/Netatmo, the thermostats data are read again for few hours. It can be 6 or 8 or 12 hours.
The meteo data continue to be updated.
That means the connection to the Netatmo server is still live.
Is anybody experiencing this behavior?
Does somebody has an idea why the thermostats data stop to be updated while the meteo data continue to be updated?
homeJLB
Domoticz version: 2024.7
Post by homeJLB »
jpcasta wrote: Friday 20 December 2024 16:25 Hello,
what is the version you are running ?
Are you using the beta-channel ?
jpcasta
Post by jpcasta »
I am running Domoticz 2024.7 (latest stable)
I am not using the beta-channel.
zxdscp
Post by zxdscp »
jpcasta wrote: Monday 30 December 2024 18:00 I am running Domoticz 2024.7 (latest stable)
I'm having exactly the same problem as you with my Netatmo thermostat.
My Domoticz v2024.7 (stable channel / Build Hash: b317cfab1 / Compile Date: 2024-07-13 16:59:31) runs on a Linux Lubuntu 20.04.
Connection to the server works for a few hours then error messages:
Thermostat Netatmo: No access granted, forcing login again...
Thermostat Netatmo: No access granted, check credentials...
Regards,
Franck
homeJLB
Post by homeJLB »
There where changes from Netamo API, they are adapted in the Beta channel not yet in the Latest Stable.
zxdscp
Post by zxdscp »
homeJLB wrote: Tuesday 31 December 2024 18:30 There where changes from Netamo API, they are adapted in the Beta channel not yet in the Latest Stable.
Thanks for your reply !
I will try the Domoticz version of the beta channel to solve this issue.
Regards,
jpcasta
Post by jpcasta »
OK Thanks, I will try it as well.
zxdscp
Post by zxdscp »
zxdscp wrote: Thursday 02 January 2025 18:54
Regards,
After updating my version of Domoticz with the latest version of the beta channel and after more than 24 hours of testing, I no longer get any “No access granted” errors.
Thanks for all homeJLB !
Regards,
Franck,
jpcasta
Post by jpcasta »
jpcasta wrote: Thursday 02 January 2025 22:37
Same things than "zxdscp". After 24h, it is still returning all of the data using the latest beta version with the new Netatmo login.
Thanks to all!
wpsabek
Post by wpsabek »
qqlapraline wrote: Tuesday 05 November 2024 21:48
Under 16325 build, I have tried the following
- Enter <ClientID> in the clientID field and <Client Secret> in the client secret field.
- a popup appears to confirm access to the appropriate scope.
- the login seems successfull but when I click on « add » a popup tells me that I am not logged on.
What type hardware must be? If I chose "Netatmo" I don't see field clientID and client secret only Username: and Password:
Version: 2024.7
jpcasta
Post by jpcasta »
@wpsabek, I am using beta version Domoticz 2024.7 (build 16406)
There is the following change that has been implemented:
- Changed: Improved and automated login process for Netatmo devices (to obtain client ID and Password with user selectable scopes)
Adding Netatmo hardware you should get fields "Client ID" and "Client Secret".
In the "Scope" field you select the information you want to get from Netatmo.
homeJLB
Post by homeJLB »
wpsabek wrote: Sunday 05 January 2025 13:41
Version: 2024.7
For Netatmo you use the correct Hardware.
Your Version 2024.7 is the Last Stable and still use the old Netatmo API code, the changed code is now in the Beta-channel
With that version you have to use the Old way https://wiki.domoticz.com/index.php?tit ... ldid=18755
Kind Regards
jpaul
Post by jpaul »
I do not understand why it's not already in the stable version. The current stable behavior is definitely a blocker issue.
Do you know when the fix will be published in the stable version ?
Thanks.
phil35
Domoticz version: 2023.1
Post by phil35 »
I am interesting by the answer to the question from @jpaul.
I'm using 2024.7 version latest stable.
after a reboot, netatmo no longer logins. I need to follow the process again. That's crazy. really.
I implemented a on/off button -> zigbee -> domoicz to swith on / off a netatmo lightflood.
My script manages the access_token and the refresh_token , it works like a charm even after a reboot.
(interesting have a look here : https://github.com/Phil353556/netatmo-manage-tokens and https://github.com/Phil353556/netatmo-floodlight)
Why this is not implemented in the stable version?
Thanks to the team who make domoticz happens!
Phil
Production platform uses domoticz v2023.1
Production platform (for Netatmo and Zigbee) uses domoticz v2024.7
homeJLB
Post by homeJLB »
With the latest Beta The Floodlight selector switch is working,
Not only the authorization login did change but also Netatmo's API changed, so this took some time to fully implement this in the Beta.
It is now also possible to have Multiple Homes in 1 account.
For the Stable Version I suspect it will be coming soon.
Kind Regards
dgilbert2
Post by dgilbert2 »
Has Netatmo stopped working for anyone else (using stable 2024.7)?
All I get now in the error log is "Error: Netatmo: Invalid/no data received..."?
DomoFlits
Domoticz version: Bld16583
Post by DomoFlits »
dgilbert2 wrote: Thursday 13 March 2025 14:30 Has Netatmo stopped working for anyone else (using stable 2024.7)?
same here:
since this morning my netatmo weatherstation measurements are not updated anymore in Domoticz (2024.7 version).
- In the Netatmo app, the measurements are fine
- The log says every 30 seconds: "Error: Netatmo: Invalid/no data received"
- I did the post 2024.1 re-authentication, but that didn't solve the problem.
someone any clue?
jpcasta
Post by jpcasta »
Same issue with my Domoticz 2024.7 (build 16406)
Matmar
Post by Matmar »
I also have the stable version from July 2024.
The thing is, I would also like to try the new authentication mode provided by the latest Domoticz beta, but I’d like to know—from those already using the beta—if the issue is resolved with the new beta plugin or if the lack of data reception from Netatmo is still present even in the beta version, meaning it’s a general problem with Netatmo itself.
Can anyone answer me?
Tank you
Alberto
dgilbert2
Post by dgilbert2 »
On the Netatmo Status page is says this:
"3rd parties - sync api
maintenance
Mar 12, 2025, 8:30 AM - Mar 12, 2025, 1:30 PM GMT | Duration: 5 hours
Impacted Business Services
3rd party APIs
scheduled
We will migrate all the sync api routes for the 3rd parties to a new component which will help us to enforce the declared quotas.
This will impact only the 3rd parties API declared via dev.netatmo.com. Netatmo/Legrand applications and voice assistants are not impacted by the change."
However, this was dated yesterday so not sure if the issue is temporary or not!?
