Re: Dashticz is not working after install on rbp or synology nas
Posted: Monday 01 August 2022 11:11
by HansieNL
Can you try the following settings for Local Networks (no username/password):
Posted: Wednesday 31 August 2022 16:33
by Jeroentje76
I've got same error and don't understand the mentioned solution.
Domoticz on a Raspberry and Dashticz on Synology NAS.
Please help
Posted: Wednesday 31 August 2022 18:06
by HansieNL
The mentioned solution is a Domoticz setting.
Settings - System Setup - Local Networks
Posted: Friday 02 September 2022 15:22
by Jeroentje76
Added the IP's in the settings of Domoticz, but didn't work.
Any suggestions?
Posted: Monday 05 September 2022 19:56
by Jeroentje76
I've tried today to install Dashticz on a other Raspberry and got the same error.
Does somebody have a clue?
Posted: Monday 05 September 2022 23:21
by HansieNL
Which installation did you try? Manual or Automatic.
Automatic install will help you with the correct setting. Installed it last weekend on a raspberry pi without any problem.
Posted: Tuesday 06 September 2022 16:12
by Jeroentje76
Both times Manual installation.
I'll try the coming day the Automatic installation on a new Raspberry/Debian.
Posted: Wednesday 07 September 2022 9:53
by Jeroentje76
@HansieNL I did the automatic installation and it is working, Thanks.
Still the question, why does the manual setup not work?
Has it to do with the Docker part because I don't see that in the manual installation.
Regards,
Jeroen
Posted: Wednesday 07 September 2022 18:06
by HansieNL
Good to hear it is working now.
Hard to say where it goes wrong at your side.
If you manual install you have to be sure that the webserver and all additional packages are correctly installed and configured.
Now you have a working version you can configure and play with your Dashticz.
You can always copy your Dashticz configuration files later to a manual version if you solved the problem.
Docker is not needed for a manual installation.
