Smartwares CIP-37210 WiFi
metsys
Domoticz version: 2022.1
Post by metsys »
I bought a Smartwares CIP-37210 WiFi camera and now looking for an opportunity to gain access to the operating system.
Consists of:
SoC HiSilicon 3518EV200
WiFi Realtek 8188FTV
Flash Winbond 25Q128JVSQ
SD-card reader
microphone
speaker
Pictures:
Upd:
Just connected to UART and got boot log:
System startup
U-Boot 2010.06 (Apr 06 2019 - 12:17:47)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xef 0x40 0x18
spi_general_qe_enable(294): Error: Disable Quad failed! reg: 0x2
Block:64KB Chip:16MB Name:"W25Q128(B/F)V"
SPI Nor total size: 16MB
MMC:
EMMC/MMC/SD controller initialization.
Card did not respond to voltage select!
No EMMC/MMC/SD device found !
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
16384 KiB hi_fmc at 0:0 is now current device
wrong tag
wrong tag
Hit any key to stop autoboot:  0
1st input Passwd,U_PHY_ADDR=1:
2st input Passwd,U_PHY_ADDR=1:
3st input Passwd,U_PHY_ADDR=1:
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-3.4.35
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1602256 Bytes = 1.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.4.35 ([email protected]) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v300) ) #43 Wed Jun 28 10:11:22 CST 2017
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: hi3518ev200
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 10414
Kernel command line: mem=41M console=ttyAMA0,115200 root=/dev/mtdblock1 rootfstype=jffs2 mtdparts=hi_sfc:1856K(boot),14016K(rootfs)
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 41MB = 41MB total
Memory: 37240k/37240k available, 4744k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc3000000 - 0xff000000   ( 960 MB)
    lowmem  : 0xc0000000 - 0xc2900000   (  41 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc03c2000   (3816 kB)
      .init : 0xc03c2000 - 0xc03db144   ( 101 kB)
      .data : 0xc03dc000 - 0xc03fec80   ( 140 kB)
       .bss : 0xc03feca4 - 0xc0431774   ( 203 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:32
VIC @fe0d0000: id 0x00641190, vendor 0x41
sched_clock: 32 bits at 49MHz, resolution 20ns, wraps every 86767ms
Calibrating delay loop... 269.10 BogoMIPS (lpj=1345536)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x802f5f60 - 0x802f5fb8
NET: Registered protocol family 16
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 5) is a PL011 rev2
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 30) is a PL011 rev2
uart:2: ttyAMA2 at MMIO 0x200a0000 (irq = 25) is a PL011 rev2
bio: create slab <bio-0> at 0
SCSI subsystem initialized
hi-spi-master hi-spi-master.0: with 1 chip select slaves attached
hi-spi-master hi-spi-master.1: with 2 chip select slaves attached
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timer0
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 72
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
Check Flash Memory Controller v100 ...  Found.
2 cmdlinepart partitions found on MTD device hi_sfc
Creating 2 MTD partitions on "hi_sfc":
0x000000000000-0x0000001d0000 : "boot"
0x0000001d0000-0x000000f80000 : "rootfs"
0x0000001d0000-0x000000f80000 : "user"
0x000000000000-0x000001000000 : "all"
0x000000f80000-0x000001000000 : "config"
himii: probed
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
hiusb-ehci hiusb-ehci.0: HIUSB EHCI
hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1
hiusb-ehci hiusb-ehci.0: irq 15, io mem 0x100b0000
hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
hiusb-ohci hiusb-ohci.0: HIUSB OHCI
hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2
hiusb-ohci hiusb-ohci.0: irq 16, io mem 0x100a0000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
i2c /dev entries driver
hisi_i2c hisi_i2c.0: Hisilicon [i2c-0] probed!
hisi_i2c hisi_i2c.1: Hisilicon [i2c-1] probed!
hisi_i2c hisi_i2c.2: Hisilicon [i2c-2] probed!
TCP: cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
usb 1-1: new high-speed USB device number 2 using hiusb-ehci
VFS: Mounted root (jffs2 filesystem) on device 31:1.
Freeing init memory: 100K
            _ _ _ _ _ _ _ _ _ _ _ _
            \  _  _   _  _ _ ___
            / /__/ \ |_/
           / __   /  -  _ ___
  _ _ _ _/ /  /  \_/  \_ ______
___________\___\__________________
[RCS]: /etc/init.d/S00devs
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S80network
Not recognise ACTION:change
[RCS]: /etc/init.d/S90hibernate
/etc/init.d/S90hibernate: line 3: can't create /proc/sys/kernel/pm_notifier: nonexistent directory
modules/
modules/hi3518e_isp.ko.bak
modules/mmz.ko
modules/hi3518e_tde.ko
modules/hn_config.sh
modules/hi3518e_vgs.ko
modules/hi3518e_ao.ko
modules/hi3518e_viu.ko
modules/hiuser.ko
modules/hi3518e_ai.ko
modules/rtl8188fu.ko
modules/pinmux_hi3518e.sh
modules/hi3518e_venc.ko
modules/hi3518e_aio.ko
modules/hi_mipi.ko
modules/hi3518e_region.ko
modules/hi3518e_jpege.ko
modules/acodec.ko
modules/hi3518e_sys.ko
modules/demo_config.sh
modules/hi3518e_chnl.ko
modules/hi3518e_rc.ko
modules/3.4.35/
modules/hi_media.ko
modules/hi3518e_ive.ko
modules/hi3518e_aenc.ko
modules/wdt.ko
modules/hi3518e_base.ko
modules/extdrv/
modules/extdrv/pwm.ko
modules/extdrv/sensor_i2c.ko
modules/sysctl_hi3518e.sh
modules/clkcfg_hi3518e.sh
modules/hi3518e_h264e.ko
modules/lowpower.sh
modules/higpio.ko
modules/hi3518e_vpss.ko
cputype is HI3518EV200
SENSORTYPE is OV9732
mmz_start: 0x82900000, mmz_size: 23M
remove audio
Hisilicon Media Memory Zone Manager
Module himedia: init ok
hi3518e_base: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
load sys.ko for Hi3518EV200...OK!
load tde.ko ...OK!
load region.ko ....OK!
load vgs.ko for Hi3518EV200...OK!
ISP Mod init!
load viu.ko for Hi3518EV200...OK!
load vpss.ko ....OK!
load rc.ko for Hi3518EV200...OK!
load venc.ko for Hi3518EV200...OK!
load chnl.ko for Hi3518EV200...OK!
load h264e.ko for Hi3518EV200...OK!
load jpege.ko for Hi3518EV200...OK!
load ive.ko for Hi3518EV200...OK!
==== Your input Sensor type is ov9732 ====
acodec inited!
insert audio
mipi_init
init phy power successful!
load hi_mipi driver successful!
Hisilicon Watchdog Timer: 0.01 initialized. default_margin=60 sec (nowayout= 0, nodeamon= 0)
insmod: can't read '/tmp/modules/mtprealloc.ko': No such file or directory
usbcore: registered new interface driver rtl8188fu
Auto login as root ...
         update version time [Jun 28 2017] [11:29:14]
[Hi_Msg_Init]: create hi msg id: 0
[Hi_Msg_Init]: hi msg id: 0
[apx_start_msg]: start module UPDATE
(none) login: [main]: avcapture version is 100, time is [Sep 20 2018] [15:47:04]
[apx_start_msg]: start module AV
[show_version_time]: \*************************************************************\
[show_version_time]:    version time [Jun 11 2019] [15:51:13]
[getvar_from_file]: path:/mnt/mtd/machine_conf Can't find:VERSION_FEATURE get_value_n:128 offset:-1
[get_machine_type]: no version feature
[get_machine_type]: cpu type is 5
[get_machine_type]: machine type is 4115
[get_machine_type]: customer is UNABTO2
[get_machine_type]: wifi module is 8188
[get_machine_type]: g_stMachine.customer=42
[check_packet_wifi_mode]: ret=0,wifi_mode=sta
[get_machine_type]: VERSION_TYPE is RELEASE
[get_machine_type]: smart_home is 0
[get_machine_type]: sensor type is 2
[get_machine_type]: packet name is 4115.UNABTO2.8188.sta.UNABTO.OV9732.FV0154.1906111551
[init_product_funclist]: *********init_product_funclist 0x[01602243] [00000000]
[init_gpio]:
[init_sd]:
[factory_reserved]: NO SD CARD
[getvar_from_file]: /mnt/mtd/reboot_conf open failed
[getvar_from_file]: get_name=times
[getvar_from_file]: default /mnt/mtd/reboot_conf, times
[defaults_setting]: /mnt/mtd/reboot_conf
[reboot_set_times]: reboot times is 0
[InitSysTime]: *************************InitSysTime...
[InitSysTime]: realtime_conf open failed...
[defaults_all]:
[setvar_to_file]: opened /mnt/mtd/product.conf err
[defaults_setting]: /mnt/mtd/product.conf
default timeout 60 sec.
We reset timeout as 15 sec.
Please notice if system reboot after 15 sec.
[FStreamer_config]:
[getvar_from_file]: /mnt/mtd/nvtserver_conf open failed
[getvar_from_file]: get_name=nvt_switch
[getvar_from_file]: default /mnt/mtd/nvtserver_conf, nvt_switch
[defaults_setting]: /mnt/mtd/nvtserver_conf
[getvar_from_file]: /mnt/mtd/rtmp_conf open failed
[getvar_from_file]: get_name=rtmp_server
[getvar_from_file]: default /mnt/mtd/rtmp_conf, rtmp_server
[defaults_setting]: /mnt/mtd/rtmp_conf
[getvar_from_file]: /mnt/mtd/rtsp_conf open failed
[getvar_from_file]: get_name=rtsp_push_addr
[getvar_from_file]: default /mnt/mtd/rtsp_conf, rtsp_push_addr
[defaults_setting]: /mnt/mtd/rtsp_conf
[FStreamer_config]: g_ApKey is 0123456789
[getvar_from_file]: /mnt/mtd/video_conf open failed
[getvar_from_file]: get_name=m_enc_type
[getvar_from_file]: default /mnt/mtd/video_conf, m_enc_type
[defaults_setting]: /mnt/mtd/video_conf
[getvar_from_file]: /mnt/mtd/pushserver_conf open failed
[getvar_from_file]: get_name=SERVERADDR
[getvar_from_file]: default /mnt/mtd/pushserver_conf, SERVERADDR
[defaults_setting]: /mnt/mtd/pushserver_conf
[getvar_from_file]: /mnt/mtd/equinfo_conf open failed
[getvar_from_file]: get_name=softwareFVersion
[getvar_from_file]: default /mnt/mtd/equinfo_conf, softwareFVersion
[defaults_setting]: /mnt/mtd/equinfo_conf
[FStreamer_config]: machine type is 4115, fw ver is 154
[FStreamer_config]: ::get Pre version=[1.0.0.1] get pro version=[41.1.5.0154]
[FStreamer_config]: AVC_VERSION_BUILT is 54
[getvar_from_file]: /mnt/mtd/net_conf open failed
[getvar_from_file]: get_name=conn_mod
[getvar_from_file]: default /mnt/mtd/net_conf, conn_mod
[defaults_setting]: /mnt/mtd/net_conf
[getvar_from_file]: /mnt/mtd/alarm_conf open failed
[getvar_from_file]: get_name=sen_alarm_onoff
[getvar_from_file]: default /mnt/mtd/alarm_conf, sen_alarm_onoff
[defaults_setting]: /mnt/mtd/alarm_conf
[getvar_from_file]: /mnt/mtd/ntp_conf open failed
[getvar_from_file]: get_name=Server
[getvar_from_file]: default /mnt/mtd/ntp_conf, Server
[defaults_setting]: /mnt/mtd/ntp_conf
[getvar_from_file]: /mnt/mtd/smtp_conf open failed
[getvar_from_file]: get_name=enable_email
[getvar_from_file]: default /mnt/mtd/smtp_conf, enable_email
[defaults_setting]: /mnt/mtd/smtp_conf
[getvar_from_file]: /mnt/mtd/ftp_conf open failed
[getvar_from_file]: get_name=enable_ftp
[getvar_from_file]: default /mnt/mtd/ftp_conf, enable_ftp
[defaults_setting]: /mnt/mtd/ftp_conf
[getvar_from_file]: /mnt/mtd/sdc_conf open failed
[getvar_from_file]: get_name=cover_enable
[getvar_from_file]: default /mnt/mtd/sdc_conf, cover_enable
[defaults_setting]: /mnt/mtd/sdc_conf
[getvar_from_file]: /mnt/mtd/multi_conf open failed
[getvar_from_file]: get_name=wnd_enable0
[getvar_from_file]: default /mnt/mtd/multi_conf, wnd_enable0
[defaults_setting]: /mnt/mtd/multi_conf
[getvar_from_file]: /mnt/mtd/audio_conf open failed
[getvar_from_file]: get_name=ChanNum
[getvar_from_file]: default /mnt/mtd/audio_conf, ChanNum
[defaults_setting]: /mnt/mtd/audio_conf
[FStreamer_config]: get speech_enable,ret=0
[getvar_from_file]: /mnt/mtd/ptz_conf open failed
[getvar_from_file]: get_name=baudrate
[getvar_from_file]: default /mnt/mtd/ptz_conf, baudrate
[defaults_setting]: /mnt/mtd/ptz_conf
[getvar_from_file]: /mnt/mtd/lamp_conf open failed
[getvar_from_file]: get_name=lamp_ctrl
[getvar_from_file]: default /mnt/mtd/lamp_conf, lamp_ctrl
[defaults_setting]: /mnt/mtd/lamp_conf
[list_all_account]: /mnt/mtd/admin_conf open failed...
[set_default_sysop]: Restoring admin_conf...
[list_all_account]: get user0:admin:admin:0
[list_all_account]: user0:name:admin,passed:admin,leave:0
[list_all_account]: get user1:::3
[list_all_account]: get user1:setuserflag
[list_all_account]: get user1:0
[list_all_account]: count=1
[getvar_from_file]: /mnt/mtd/ircut_conf open failed
[getvar_from_file]: get_name=mode
[getvar_from_file]: default /mnt/mtd/ircut_conf, mode
[defaults_setting]: /mnt/mtd/ircut_conf
[getvar_from_file]: /mnt/mtd/schedule_conf open failed
[getvar_from_file]: get_name=alarm_schedule_enable
[getvar_from_file]: default /mnt/mtd/schedule_conf, alarm_schedule_enable
[defaults_setting]: /mnt/mtd/schedule_conf
[getvar_from_file]: /mnt/mtd/day_temp_conf open failed
[getvar_from_file]: get_name=temp_time0
[getvar_from_file]: default /mnt/mtd/day_temp_conf, temp_time0
[defaults_setting]: /mnt/mtd/day_temp_conf
[getvar_from_file]: /mnt/mtd/sd_schedule open failed
[getvar_from_file]: get_name=begin_t
[getvar_from_file]: default /mnt/mtd/sd_schedule, begin_t
[defaults_setting]: /mnt/mtd/sd_schedule
[getvar_from_file]: /mnt/mtd/door_magnet_schedule open failed
[getvar_from_file]: get_name=schedule_enable
[getvar_from_file]: default /mnt/mtd/door_magnet_schedule, schedule_enable
[defaults_setting]: /mnt/mtd/door_magnet_schedule
[getvar_from_file]: /mnt/mtd/all_alarm_schedule open failed
[getvar_from_file]: default /mnt/mtd/all_alarm_schedule, schedule_enable
[defaults_setting]: /mnt/mtd/all_alarm_schedule
[getvar_from_file]: /mnt/mtd/cloud_conf open failed
[getvar_from_file]: get_name=dropbox_accessToken
[getvar_from_file]: default /mnt/mtd/cloud_conf, dropbox_accessToken
[defaults_setting]: /mnt/mtd/cloud_conf
[get_ircut_switch_val]: DayToNight=246,NightToDay=236
[getvar_from_file]: /mnt/mtd/pic_repeat_conf open failed
[getvar_from_file]: get_name=pic_repeat_enable
[getvar_from_file]: default /mnt/mtd/pic_repeat_conf, pic_repeat_enable
[defaults_setting]: /mnt/mtd/pic_repeat_conf
[getvar_from_file]: /mnt/mtd/ota_conf open failed
[getvar_from_file]: get_name=ota_mode
[getvar_from_file]: default /mnt/mtd/ota_conf, ota_mode
[defaults_setting]: /mnt/mtd/ota_conf
[getvar_from_file]: /mnt/mtd/systemgain.conf open failed
[getvar_from_file]: get_name=gain
[getvar_from_file]: default /mnt/mtd/systemgain.conf, gain
[defaults_setting]: /mnt/mtd/systemgain.conf
[getvar_from_file]: /mnt/mtd/server_print.conf open failed
[getvar_from_file]: get_name=print_enable
[getvar_from_file]: default /mnt/mtd/server_print.conf, print_enable
[defaults_setting]: /mnt/mtd/server_print.conf
[FStreamer_config]: Wtite poweroff time to log----------------------------------------------------------------
[yuntai_get_xy_fromfile]: g_init_x=-1  g_init_y=-1 g_init_z=-1 g_init_f=-1
[getvar_from_file]: /mnt/mtd/video_options.conf open failed
[getvar_from_file]: get_name=HD_RES
[getvar_from_file]: default /mnt/mtd/video_options.conf, HD_RES
[defaults_setting]: /mnt/mtd/video_options.conf
[getvar_from_file]: /mnt/mtd/ptz_center open failed
[getvar_from_file]: get_name=center_x
[getvar_from_file]: default /mnt/mtd/ptz_center, center_x
[defaults_setting]: /mnt/mtd/ptz_center
[FStreamer_config]: center is -1, -1, -1, -1
[eth0_set_mac]: mac = ifconfig eth0 hw ether 6E:7C:72:4C:E2:49
*************************init_buf_list JD...
[detect_wifi]: get wifi mode=1
[hi_video_stream_switch_set]: bStart=1
[hi_video_stream_switch]: stream value is 1,g_stream_switch=1
PHY: himii:01 - Link is Up - 10/Half
[detect_qr_mode]: customer=3,g_bCustomer_extra=42,no use qrmode_conf
[update_version]: no machine_conf
[factory_write_wifi]: NO SD CARD
[factory_test_mode]: NO SD CARD
[InitVideoCfg]:
[InitVideoCfg]: video resolution list:
[InitVideoCfg]: res_list[0]=4
[InitVideoCfg]: res_list[1]=2
[InitVideoCfg]: res_list[2]=3
[InitVideoCfg]: res_list[3]=0
[InitVideoCfg]: res_list[4]=0
[InitVideoCfg]: res_list[5]=0
[InitVideoCfg]: res_list[6]=0
[InitVideoCfg]: res_list[7]=0
[apx_start_msg]: start module MAIN
[hi_av_init]: sensor type 2, cpu type 5
[hi_av_init]: chn [0] res [16] bps [768] fps [20] encType [96]
[hi_av_init]: chn [1] res [7] bps [512] fps [25] encType [96]
[hi_av_init]: chn [3] res [6] bps [512] fps [25] encType [96]
[hi_set_cpu_type]: cpu type 6
[hi_set_cpu_type]: g_uiViFps=25
g_CpuType is 5
[hi_main_get_version]: avcapture version is 100
*** Board tools : ver0.0.1_20121120 ***
[debug]: {source/utils/cmdshell.c:166}cmdstr:himm
0x200f0040: 0x00000000 --> 0x00000002
[END]
0x200f0044: 0x00000000 --> 0x00000002
[END]
0x200f008c: 0x00000000 --> 0x00000002
[END]
0x200f0090: 0x00000000 --> 0x00000002
[END]
0x200f0094: 0x00000000 --> 0x00000001
[END]
0x2003002c: 0x000C4003 --> 0x000C4001
[END]
[hi_init_cache_buf]: cacheBufSize[0] is 512
[hi_init_cache_buf]: cacheBufSize[1] is 512
[hi_init_cache_buf]: cacheBufSize[2] is 512
[hi_init_cache_buf]: cacheBufSize[3] is 128
[hi_init_cache_buf]: cacheBufSize[4] is 128
[hi_init_cache_buf]: cacheBufSize[5] is 128
s32ChnNum = 4
[SAMPLE_VENC_1080P_CLASSIC]: blk cnt is 4
=============SAMPLE_COMM_VI_SetMipiAttr enWDRMode: 0
linear mode
ov9732 sensor config
===ominivision ov9732 sensor 720P30fps(Parallel port) init success!=====
[SAMPLE_COMM_ISP_Run]: cpu 3518ev200
[apx_start_aac_encoder]:
SAMPLE_COMM_AUDIO_StartAenc,u32AencPtNumPerFrm=320
[SAMPLE_OSD_DateTime]: handle_name=1,osd_width_name=266,osd_height_name=25
[SAMPLE_OSD_DateTime]: handle_name=4,osd_width_name=152,osd_height_name=15
[SAMPLE_OSD_DateTime]: handle_name=7,osd_width_name=152,osd_height_name=15
[SAMPLE_OSD_DateTime]: handle_name=10,osd_width_name=134,osd_height_name=13
[update_motion_pra]: update_motion_pra
[update_motion_pra]: motion percent is 60
[update_motion_pra]: mdparam[0].bValid=0
[update_motion_pra]: mdparam[0].start_x=0
[update_motion_pra]: mdparam[0].start_y=0
[update_motion_pra]: mdparam[0].end_x=320
[update_motion_pra]: mdparam[0].end_y=240
[update_motion_pra]: mdparam[0].m_percent=60
[update_motion_pra]: mdparam[1].bValid=0
[update_motion_pra]: mdparam[1].start_x=0
[update_motion_pra]: mdparam[1].start_y=0
[update_motion_pra]: mdparam[1].end_x=0
[update_motion_pra]: mdparam[1].end_y=0
[update_motion_pra]: mdparam[1].m_percent=0
[update_motion_pra]: mdparam[2].bValid=0
[update_motion_pra]: mdparam[2].start_x=0
[update_motion_pra]: mdparam[2].start_y=0
[update_motion_pra]: mdparam[2].end_x=0
[update_motion_pra]: mdparam[2].end_y=0
[update_motion_pra]: mdparam[2].m_percent=0
[update_motion_pra]: HI_CMD_SET_MD_PARAM ret is 0
[thread_hisi_osd_show]: camDesc[] g_equipinfo.camDesc[IP CAMERA] cmpret[-73]
[thread_hisi_osd_show]: g_video_rel.OSDTimer had change-------------------7
startx0[0],starty0[0], endx0[320],endy0[240],m_percent=60
set osd param
set osd param
[thread_hisi_osd_show]: [73] OSD device name before change
[thread_hisi_osd_show]: [86] OSD device name after change IP CAMERA
[thread_hisi_osd_show]: osd change, timezone 15
set osd param
set osd param
[apx_osd_update_windows]: handle_name=1,osd_width_name=128,osd_height_name=25
[apx_osd_update_windows]: handle_name=4,osd_width_name=74,osd_height_name=15
[apx_osd_update_windows]: handle_name=7,osd_width_name=74,osd_height_name=15
[apx_osd_update_windows]: handle_name=10,osd_width_name=64,osd_height_name=13
chn[3] over write, now serial is 44
[hi_set_ie_channel]: g_video_pra.def_bs is 0
[hi_set_ie_channel]: g_iIEChn is 0
[hi_msg_proc]: src [MAIN] dst [AV] cmd [27] no func, do you register?
[Hi_msg_pthread]: process msg error
[get_dwdr_status]: ################# v200 get dwdr 0
[main]: g_wdr_status=0
[hi_set_mirror]: HI_CMD_SET_MIRROR ret is 0
[hi_video_set_mirror]: 3516a: set mirror value is 0
[2] first time
[thread_push_video]: g_bQrMode=0,g_QR_enable=0
[2] first time
[set_g_Iframe]: chn is 0
[hi_video_request_idr]: chn is 0
[hi_video_request_idr]: HI_MPI_VENC_RequestIDR ret is 0
[hi_video_set_mirror]: 3516a: set mirror value is 2
chn[2] over write, now serial is 19
[hi_set_brightness]: brightness =50
set brightness value is 50
[hi_set_contrast]: contrast =50
set contrast value is 50
[hi_set_saturation]: saturation = 50
[hi_video_set_saturation]: set saturation value is 50
[hi_set_hue]: val=50
set hue value is 50
[hi_set_aec]: picturecfg->aec_value=1
[hi_set_aec]: val=50
[hi_set_mic_gain]: devicevol_mic-----------devicevol_mic=7
[hi_set_audio_outvol]: devicevol_speaker-----------devicevol_speaker=8
[init_buf_list]: *************************init_buf_list...
[main]: >>>>>>>>>>>>>>>>>disable wifi manager...
[thread_create_avsave]: start avsave
[savefile][main]: avsave time is [Dec 14 2017] [09:39:17]
[apx_start_msg]: start module RECORD
killall: mini_httpd: no process killed
[httpdsvr_restart]: start httpdsvr::mini_httpd -C /etc/mini_httpd.conf -p 80
socket: Address family not supported by protocol
mini_httpd: started as root without requesting chroot(), warning only
[thread_send_remotedate]: @@@@@@@@@@@@@@@@@@@@@@@@@@@thread_send_remotedate...
[thread_onvif_start]:
[thread_onvif_start]: /bin/NVTServer Not Found!
[thread_onvif_start]: /app/bin/NVTServer Not Found!
[thread_wait_local_client]: @@@@@@@@@@@@@@@@@@@@@@@@@@@thread_wait_local_client...
[thread_wait_remote_client]: @@@@@@@@@@@@@@@@@@@@@@@@@@@thread_wait_remote_client...
[thread_wait_remote_client]: :thread_wait_remote_client()Listen socket =6###############################################
[thread_timer]:
[thread_send_ftp_smtp]:
auth_type=1
    *   rtspServLib build information: [v2.0.2, 2014-03-23]    *
[0] first time
[thread_vga_search]:
[thread_ntpupdate]:
[main]: call shell /app/bin/homewizard.sh
[thread_sd_detect]:
[hi_set_nr_params]: ret is 0
[hi_set_gamma]: ret is 0
[hi_ircut_status]: stGpio.value=0, gGpioNum[EN_GPIO_IR_CUT].day=0
[homewizard.sh] ----------------------> Started <----------------------
[SAMPLE_IQ_SetGammaTable]: gamma enable is 1
use gamma5
[hi_av_set_nr_params]: val is 13, 70, 55, 12, 0, 0, 16, 0, 0, 0, 0, 24, 32, 0
use gamma0
[hi_video_set_sysgain]: gain val is 9050
cat: can't open '/mnt/mtd/wpa.conf': No such file or directory
[1] first time
killall: wpa_supplicant: no process killed
killall: hostapd: no process killed
***link down status changed***.
PHY: himii:01 - Link is Down
chn[0] over write, now serial is 131
killall: udhcpc: no process killed
killall: udhcpd: no process killed
chn[4] over write, now serial is 127
ircut change,wait 10:40...
[ptz_int_check_or_wait]: start detect
[4] first time
chn[1] over write, now serial is 198
ircut change,wait 20:40...
ircut change,wait 30:40...
ircut change,wait 40:40...
[set_sound_type]: 1
[set_sound_type]: 0
[play_sound]: open sound /mnt/music/welcom.wav error
[play_sound]: open sound /app/music/welcom.wav error
[hi_main_music]: MusicInfo.cmd = 0
[hi_main_music]: stMusic.music_name = /mnt/music/beep.wav
[play_sound]: ##############zzh hi talk start()
[hi_talk_start]:
[hi_talk_switch]: talk value is 4
first time: hi_talk_get_data_init
read talk frame error, channel[0], result is -20
[0] first time
[homewizard.sh] ----------------------> Ended AP MODE <----------------------
Client access control not enforced !
[himain] apxmain process [1041] started...
[apx_start_msg]: start module THIRD
hi_send_msg(1, 14, 3, 4, 0)
[himain] Camera running in Access Point mode, basic setup only...
00:00:25:293 unabto_common_main.c(110) Device id: 'c000000.cameras.smartwares.eu'
00:00:25:294 unabto_common_main.c(111) Program Release 4.4.2
register module
00:00:25:317 unabto_stream_event.c(235) sizeof(stream__)=6144
00:00:25:318 unabto_context.c(55) SECURE ATTACH: 1, DATA: 1
00:00:25:318 unabto_context.c(63) NONCE_SIZE: 32, CLEAR_TEXT: 0
00:00:25:364 unabto_common_main.c(183) Nabto was successfully initialized
00:00:25:366 unabto_context.c(55) SECURE ATTACH: 1, DATA: 1
00:00:25:366 unabto_context.c(63) NONCE_SIZE: 32, CLEAR_TEXT: 0
00:00:25:371 unabto_attach.c(770) State change from IDLE to WAIT_DNS
00:00:25:371 unabto_attach.c(771) Resolving DNS for c000000.cameras.smartwares.eu
00:00:25:482 unabto_attach.c(784) DNS error (returned by application)
00:00:25:482 unabto_attach.c(785) State change from WAIT_DNS to IDLE
00:00:27:491 unabto_context.c(55) SECURE ATTACH: 1, DATA: 1
00:00:27:491 unabto_context.c(63) NONCE_SIZE: 32, CLEAR_TEXT: 0
00:00:27:492 unabto_attach.c(770) State change from IDLE to WAIT_DNS
00:00:27:492 unabto_attach.c(771) Resolving DNS for c000000.cameras.smartwares.eu
00:00:27:601 unabto_attach.c(784) DNS error (returned by application)
00:00:27:601 unabto_attach.c(785) State change from WAIT_DNS to IDLE
[play_sound]: >>>>>>>>>>>>>delay 400ms.[hi_talk_stop]:
[hi_main_set_led_blinking]: ledid=1,on_ms=500,off_ms=500
[hi_main_set_led_blinking]: g_led_blink:ledid=1,on_ms=500,off_ms=500
[hi_main_set_led_blinking]: ledid=3,on_ms=0,off_ms=0
[hi_main_set_led_blinking]: g_led_blink:ledid=3,on_ms=0,off_ms=0
[hi_talk_switch]: talk value is 5
00:00:35:611 unabto_context.c(55) SECURE ATTACH: 1, DATA: 1
00:00:35:612 unabto_context.c(63) NONCE_SIZE: 32, CLEAR_TEXT: 0
00:00:35:613 unabto_attach.c(770) State change from IDLE to WAIT_DNS
00:00:35:613 unabto_attach.c(771) Resolving DNS for c000000.cameras.smartwares.eu
00:00:35:720 unabto_attach.c(784) DNS error (returned by application)
00:00:35:721 unabto_attach.c(785) State change from WAIT_DNS to IDLE
(none) login:
So, here ominivision ov9732 sensor
SPI flash partition:
U-boot is locked by password.
root password unknown
