zigbeefordomoticz/zigate and Sonoff Zigbee 3.0 plus Stick
Posted: Wednesday 20 July 2022 21:18
I have a Sonoff Zigbee 3.0 plus stick and want to use it with domoticz.
I use zigbee for domoticz/zigate beta 6as a plugin, but I run into problems
settings
logging
[update 21/07/2022 00:42]
Unfortunatly the problem persists
I have flashed my stick with CC1352P2_CC2652P_launchpad_coordinator_20220219.hex
Also I tested the API:
settings
logging
022-07-20 21:37:32.205 Error: zigbee11: WriteDeviceList - self.pluginconf.pluginConf['pluginData']: /usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Data/ , self.DeviceListName: None
2022-07-20 21:38:12.453 Error: zigbee11: 'onStart' failed 'RemoteDisconnected':'Remote end closed connection without response'.
2022-07-20 21:38:12.453 Error: zigbee11: Exception traceback:
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1679 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onStart
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 427 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onStart
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 156 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Classes/DomoticzDB.py', function __init__
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 163 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Classes/DomoticzDB.py', function load_hardware
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 93 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Classes/DomoticzDB.py', function domoticz_request
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 222 in '/usr/lib/python3.7/urllib/request.py', function urlopen
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 525 in '/usr/lib/python3.7/urllib/request.py', function open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 543 in '/usr/lib/python3.7/urllib/request.py', function _open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 503 in '/usr/lib/python3.7/urllib/request.py', function _call_chain
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1352 in '/usr/lib/python3.7/urllib/request.py', function http_open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1330 in '/usr/lib/python3.7/urllib/request.py', function do_open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1369 in '/usr/lib/python3.7/http/client.py', function getresponse
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 310 in '/usr/lib/python3.7/http/client.py', function begin
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 279 in '/usr/lib/python3.7/http/client.py', function _read_status
2022-07-20 21:39:21.059 Error: zigbee11: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:21.089 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:39:31.087 Error: zigbee11: [ 80] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:31.118 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:39:41.066 Error: zigbee11: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:41.098 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:39:51.090 Error: zigbee11: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:51.122 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:01.063 Error: zigbee11: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:01.096 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:11.097 Error: zigbee11: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:11.131 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:21.074 Error: zigbee11: [130] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:21.130 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:31.087 Error: zigbee11: [140] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:31.147 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:41.069 Error: zigbee11: [150] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:41.121 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:51.086 Error: zigbee11: [160] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:51.145 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:01.095 Error: zigbee11: [170] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:01.154 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:11.101 Error: zigbee11: [180] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:11.153 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:21.061 Error: zigbee11: [190] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:21.115 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:31.072 Error: zigbee11: [200] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:31.126 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:41.086 Error: zigbee11: [210] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:41.142 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:51.101 Error: zigbee11: [220] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:51.158 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:01.066 Error: zigbee11: [230] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:01.125 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:11.077 Error: zigbee11: [240] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:11.132 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:21.095 Error: zigbee11: [250] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:21.152 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:31.065 Error: zigbee11: [260] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:31.123 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:41.083 Error: zigbee11: [270] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:41.139 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:51.096 Error: zigbee11: [280] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:51.153 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:01.066 Error: zigbee11: [290] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:01.123 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:11.078 Error: zigbee11: [300] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:11.132 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:21.091 Error: zigbee11: [310] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:21.147 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:31.068 Error: zigbee11: [320] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:31.127 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:41.083 Error: zigbee11: [330] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:41.136 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:51.092 Error: zigbee11: [340] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:51.149 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:01.103 Error: zigbee11: [350] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:01.162 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:11.077 Error: zigbee11: [360] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:11.130 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:21.069 Error: zigbee11: [370] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:21.124 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:31.083 Error: zigbee11: [380] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:31.140 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:41.102 Error: zigbee11: [390] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:41.157 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:51.080 Error: zigbee11: [400] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:51.139 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:01.101 Error: zigbee11: [410] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:01.157 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:11.058 Error: zigbee11: [420] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:11.114 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:21.077 Error: zigbee11: [430] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:21.133 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:31.098 Error: zigbee11: [440] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:31.153 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:41.062 Error: zigbee11: [450] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:41.117 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:51.084 Error: zigbee11: [460] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:51.145 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:01.057 Error: zigbee11: [470] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:01.113 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:11.078 Error: zigbee11: [480] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:11.137 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:21.095 Error: zigbee11: [490] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:21.154 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:31.064 Error: zigbee11: [500] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:31.125 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:41.083 Error: zigbee11: [510] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:41.142 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:51.103 Error: zigbee11: [520] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:51.161 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:01.066 Error: zigbee11: [530] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:01.120 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:11.086 Error: zigbee11: [540] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:11.145 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:21.098 Error: zigbee11: [550] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:21.152 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:31.062 Error: zigbee11: [560] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:31.118 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:41.086 Error: zigbee11: [570] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:41.137 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:51.101 Error: zigbee11: [580] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:51.161 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:01.073 Error: zigbee11: [590] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:01.133 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:11.087 Error: zigbee11: [600] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:11.143 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:21.097 Error: zigbee11: [610] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:21.151 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:31.064 Error: zigbee11: [620] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:31.117 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:41.083 Error: zigbee11: [630] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:41.143 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:51.103 Error: zigbee11: [640] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:51.160 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:01.068 Error: zigbee11: [650] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:01.133 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:11.090 Error: zigbee11: [660] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:11.149 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:21.105 Error: zigbee11: [670] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:21.165 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:31.063 Error: zigbee11: [680] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:31.120 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:41.078 Error: zigbee11: [690] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:41.140 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:51.098 Error: zigbee11: [700] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:51.154 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:50:01.061 Error: zigbee11: [710] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:50:01.119 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:50:11.083 Error: zigbee11: [720] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:50:11.143 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:50:21.101 Error: zigbee11: [730] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:50:21.160 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
pi@raspberrypi:~ $
Redirecting output to ‘wget-log.6’.
wget http://127.0.0.1:8443/json.htm?type=command¶m=updatehardware&htype=94&idx=4&name=zigbee11&address=0.0.0.0&port=9999&serialport=%2Fdev%2Fserial%2Fby-id%2Fusb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_54686f0
[50] 14978
[51] 14979
[52] 14980
[53] 14981
[54] 14982
[55] 14983
[56] 14984
[48] Done address=0.0.0.0
[49] Done port=9999
[51] Done param=updatehardware
[52] Done htype=94
[53] Done idx=4
