zigbeefordomoticz/zigate and Sonoff Zigbee 3.0 plus Stick Topic is solved
wenoi6
Post by wenoi6 »
I have a Sonoff Zigbee 3.0 plus stick and want to use it with domoticz.
I use zigbee for domoticz/zigate beta 6as a plugin, but I run into problems
settings
logging
022-07-20 21:37:32.205 Error: zigbee11: WriteDeviceList - self.pluginconf.pluginConf['pluginData']: /usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Data/ , self.DeviceListName: None
2022-07-20 21:38:12.453 Error: zigbee11: 'onStart' failed 'RemoteDisconnected':'Remote end closed connection without response'.
2022-07-20 21:38:12.453 Error: zigbee11: Exception traceback:
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1679 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onStart
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 427 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/plugin.py', function onStart
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 156 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Classes/DomoticzDB.py', function __init__
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 163 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Classes/DomoticzDB.py', function load_hardware
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 93 in '/usr/local/bin/domoticz/plugins/Domoticz-Zigbee/Classes/DomoticzDB.py', function domoticz_request
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 222 in '/usr/lib/python3.7/urllib/request.py', function urlopen
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 525 in '/usr/lib/python3.7/urllib/request.py', function open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 543 in '/usr/lib/python3.7/urllib/request.py', function _open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 503 in '/usr/lib/python3.7/urllib/request.py', function _call_chain
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1352 in '/usr/lib/python3.7/urllib/request.py', function http_open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1330 in '/usr/lib/python3.7/urllib/request.py', function do_open
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 1369 in '/usr/lib/python3.7/http/client.py', function getresponse
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 310 in '/usr/lib/python3.7/http/client.py', function begin
2022-07-20 21:38:12.453 Error: zigbee11: ----> Line 279 in '/usr/lib/python3.7/http/client.py', function _read_status
2022-07-20 21:39:21.059 Error: zigbee11: [ 70] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:21.089 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:39:31.087 Error: zigbee11: [ 80] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:31.118 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:39:41.066 Error: zigbee11: [ 90] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:41.098 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:39:51.090 Error: zigbee11: [100] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:39:51.122 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:01.063 Error: zigbee11: [110] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:01.096 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:11.097 Error: zigbee11: [120] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:11.131 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:21.074 Error: zigbee11: [130] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:21.130 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:31.087 Error: zigbee11: [140] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:31.147 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:41.069 Error: zigbee11: [150] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:41.121 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:40:51.086 Error: zigbee11: [160] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:40:51.145 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:01.095 Error: zigbee11: [170] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:01.154 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:11.101 Error: zigbee11: [180] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:11.153 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:21.061 Error: zigbee11: [190] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:21.115 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:31.072 Error: zigbee11: [200] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:31.126 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:41.086 Error: zigbee11: [210] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:41.142 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:41:51.101 Error: zigbee11: [220] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:41:51.158 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:01.066 Error: zigbee11: [230] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:01.125 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:11.077 Error: zigbee11: [240] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:11.132 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:21.095 Error: zigbee11: [250] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:21.152 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:31.065 Error: zigbee11: [260] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:31.123 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:41.083 Error: zigbee11: [270] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:41.139 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:42:51.096 Error: zigbee11: [280] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:42:51.153 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:01.066 Error: zigbee11: [290] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:01.123 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:11.078 Error: zigbee11: [300] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:11.132 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:21.091 Error: zigbee11: [310] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:21.147 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:31.068 Error: zigbee11: [320] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:31.127 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:41.083 Error: zigbee11: [330] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:41.136 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:43:51.092 Error: zigbee11: [340] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:43:51.149 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:01.103 Error: zigbee11: [350] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:01.162 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:11.077 Error: zigbee11: [360] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:11.130 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:21.069 Error: zigbee11: [370] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:21.124 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:31.083 Error: zigbee11: [380] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:31.140 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:41.102 Error: zigbee11: [390] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:41.157 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:44:51.080 Error: zigbee11: [400] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:44:51.139 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:01.101 Error: zigbee11: [410] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:01.157 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:11.058 Error: zigbee11: [420] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:11.114 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:21.077 Error: zigbee11: [430] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:21.133 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:31.098 Error: zigbee11: [440] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:31.153 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:41.062 Error: zigbee11: [450] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:41.117 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:45:51.084 Error: zigbee11: [460] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:45:51.145 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:01.057 Error: zigbee11: [470] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:01.113 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:11.078 Error: zigbee11: [480] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:11.137 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:21.095 Error: zigbee11: [490] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:21.154 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:31.064 Error: zigbee11: [500] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:31.125 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:41.083 Error: zigbee11: [510] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:41.142 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:46:51.103 Error: zigbee11: [520] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:46:51.161 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:01.066 Error: zigbee11: [530] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:01.120 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:11.086 Error: zigbee11: [540] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:11.145 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:21.098 Error: zigbee11: [550] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:21.152 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:31.062 Error: zigbee11: [560] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:31.118 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:41.086 Error: zigbee11: [570] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:41.137 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:47:51.101 Error: zigbee11: [580] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:47:51.161 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:01.073 Error: zigbee11: [590] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:01.133 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:11.087 Error: zigbee11: [600] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:11.143 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:21.097 Error: zigbee11: [610] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:21.151 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:31.064 Error: zigbee11: [620] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:31.117 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:41.083 Error: zigbee11: [630] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:41.143 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:48:51.103 Error: zigbee11: [640] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:48:51.160 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:01.068 Error: zigbee11: [650] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:01.133 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:11.090 Error: zigbee11: [660] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:11.149 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:21.105 Error: zigbee11: [670] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:21.165 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:31.063 Error: zigbee11: [680] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:31.120 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:41.078 Error: zigbee11: [690] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:41.140 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:49:51.098 Error: zigbee11: [700] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:49:51.154 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:50:01.061 Error: zigbee11: [710] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:50:01.119 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:50:11.083 Error: zigbee11: [720] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:50:11.143 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
2022-07-20 21:50:21.101 Error: zigbee11: [730] I have hard time to get Coordinator Version. Mostlikly there is a communication issue
2022-07-20 21:50:21.160 Error: zigbee11: [ ] Stop the plugin and check the Coordinator connectivity.
[update 21/07/2022 00:42]
Unfortunatly the problem persists
I have flashed my stick with CC1352P2_CC2652P_launchpad_coordinator_20220219.hex
Also I tested the API:
pi@raspberrypi:~ $
Redirecting output to ‘wget-log.6’.
wget http://127.0.0.1:8443/json.htm?type=command&param=updatehardware&htype=94&idx=4&name=zigbee11&address=0.0.0.0&port=9999&serialport=%2Fdev%2Fserial%2Fby-id%2Fusb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_54686f0
[50] 14978
[51] 14979
[52] 14980
[53] 14981
[54] 14982
[55] 14983
[56] 14984
[48]   Done                    address=0.0.0.0
[49]   Done                    port=9999
[51]   Done                    param=updatehardware
[52]   Done                    htype=94
[53]   Done                    idx=4
pipiche
Re: zigbeefordomotics/zigate and Sonoff Zigbee 3.0 plus Stick
Post by pipiche »
Sonoff is based on Texas Instrument, so you should use exas instruments ZNP (via zigpy)
last is 127.0.0.1 authorized without authentication in Domoticz Settings ?
wenoi6
Post by wenoi6 »
pipiche wrote: Wednesday 20 July 2022 22:04 Sonoff is based on Texas Instrument, so you should use exas instruments ZNP (via zigpy)
Yeah I use Texas Instruments ZNP
I tested the API and it seems to connect fine, so I think its not the API (see topic start)
pipiche
Re: zigbeefordomoticz/zigate and Sonoff Zigbee 3.0 plus Stick
Post by pipiche »
Seems fine, what do you mean ?
pipiche
Post by pipiche »
What is the result of the command ?
wget http://127.0.0.1:8443/json.htm?type=hardware
cat json.htm\?type\=hardware
I see that you put 8443, is that not expecting SSL ? and in such this should be https:// and not http . Which on a local network and even on the loopback doesn't make more sense for me, but up to you.
wenoi6
Post by wenoi6 »
I fixed the issue by switching from the beta6 plugin branch to the stable6 plugin branch. Working very well now!
pipiche
Post by pipiche »
wenoi6 wrote:I fixed the issue by switching from the beta6 plugin branch to the stable6 plugin branch. Working very well now!
Yes because stable6 is not using the same and is buggy.
keros
Post by keros »
I think you have a mistake in the plugin parameter : for the DomoticZ API Port,your screenshot shows http:127.0.0.1:8443 with is the port define just underneath for the plugin WebUI. It should be the DomoticZ port (8080 by default).
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
