How to sort data
tomes
How to sort data
Post by tomes »
I have got variable "online":
data = { online = { initial = {}, history = true, maxItems = 20 }}.
There are data like this (added by add command):
aaa, ccc, bbb, eee, ddd
Is it possible to sort it alphabetically or rewrite alphabetically to another data variable?
I will just add that aaa, bbb ..... are the names of Domoticz devices that are getting according to criteria determined by the command:
domoticz.devices().forEach(function(device)
	if string.match(device.name, ' .* PINGER') ~= nil then
		domoticz.data.online.add(string.match(device.name, "(%w+) "))
end)
And i want to print it out alphabetically .
I will be grateful for your help.
Tom
Re: How to sort data
You should be able to use the standard Lua table.sort() function: https://www.tutorialspoint.com/sort-fun ... rogramming#
tomes
Post by tomes »
Thank You! Is it possible to use it with
or should I convert to local variable and than use table.sort?
Tom
I really do not know. You can give it a try. The link I gave had some nice examples.
