Minimum dimmer level
fvdp80
Domoticz version: 4.10303
Post by fvdp80 »
To prevent a flickering lamp i want to restrict the dimming level when the light is dimmed through a remote control.
Is there a way to set this minimum level in dzvents?
I tried the follow code, but it interferes with some other scripts when using the switchOff() function.
	on =
		devices =
		304,
	    logging =
            level = domoticz.LOG_ERROR, -- set to LOG_ERROR when tested and OK
            marker = 'Woonkamer-Plafondlamp)'
	execute = function(dz, item)
   lamp = dz.devices(304)
    if lamp.level < 30 then
       lamp.dimTo(31)
mgugu
Re: Minimum dimmer level
Post by mgugu »
You are right, the switchOff() command triggers momentarily the dimmer level. This is not normal.
You can use this workaround:
      if lamp.state == 'On' then
          lamp.dimTo(31)
fvdp80
Post by fvdp80 »
Works, thnx!
