temphumbaro prediction wrong
Posted: Wednesday 22 June 2022 11:25
by willemd
The native buienradar hardware installs a TempHumBaro device. Looking at the dashboard this also shows a prediction, which seems to be totally inaccurate.
Today is a bright summer day with good predictions. The temphumbaro shows 18.5 degrees celclius, 63% humidity and a very stable 1014 hPa pressure (dropped 2 hPa over the last 24 hours). Yet, the icon also shows a prediction "cloudy". How is this determined ? Is it interfaced from buienradar API (I doubt it) or is it determined internally by the domoticz system? Can it be configured/corrected in some way?
Re: temphumbaro prediction wrong
Posted: Wednesday 22 June 2022 14:37
by waltervl
Seems to be only based on pressure. from https://github.com/domoticz/domoticz/bl ... nradar.cpp
line 404
if (!root["airpressure"].empty())
		barometric = root["airpressure"].asFloat();
		if (barometric < 1000)
			barometric_forecast = wsbaroforecast_rain;
			if (temp != -999.9F)
				if (temp <= 0)
					barometric_forecast = wsbaroforecast_snow;
		else if (barometric < 1020)
			barometric_forecast = wsbaroforecast_cloudy;
		else if (barometric < 1030)
			barometric_forecast = wsbaroforecast_some_clouds;
			barometric_forecast = wsbaroforecast_sunny;
No possibility to change, only by changing the source code.... :)
Posted: Wednesday 22 June 2022 15:56
by willemd
Thanks, so i will just ignore that value then.
Good to know the code is published and available for reading anyway.
Posted: Wednesday 22 June 2022 17:09
by waltervl
willemd wrote: Wednesday 22 June 2022 15:56 Thanks, so i will just ignore that value then.
It is even better, you are free to contribute and enhance the code for all :-)
