The native buienradar hardware installs a TempHumBaro device. Looking at the dashboard this also shows a prediction, which seems to be totally inaccurate.
Today is a bright summer day with good predictions. The temphumbaro shows 18.5 degrees celclius, 63% humidity and a very stable 1014 hPa pressure (dropped 2 hPa over the last 24 hours). Yet, the icon also shows a prediction "cloudy". How is this determined ? Is it interfaced from buienradar API (I doubt it) or is it determined internally by the domoticz system? Can it be configured/corrected in some way?
temphumbaro prediction wrong
- Domoticz version: 2026.3
Re: temphumbaro prediction wrong
Seems to be only based on pressure. from https://github.com/domoticz/domoticz/bl ... nradar.cpp
line 404
No possibility to change, only by changing the source code....
line 404
if (!root["airpressure"].empty())
barometric = root["airpressure"].asFloat();
if (barometric < 1000)
barometric_forecast = wsbaroforecast_rain;
if (temp != -999.9F)
if (temp <= 0)
barometric_forecast = wsbaroforecast_snow;
else if (barometric < 1020)
barometric_forecast = wsbaroforecast_cloudy;
else if (barometric < 1030)
barometric_forecast = wsbaroforecast_some_clouds;
barometric_forecast = wsbaroforecast_sunny;
}Domoticz running on Udoo X86 (on Ubuntu)
willemd
- Domoticz version: 2024.1
Thanks, so i will just ignore that value then.
Good to know the code is published and available for reading anyway.
It is even better, you are free to contribute and enhance the code for allwillemd wrote: Wednesday 22 June 2022 15:56 Thanks, so i will just ignore that value then.
