Maybe a stupid question. But does the zigbee2mqtt plugin also has a web based front end.
Plugin is working fine. but you can choose to put in the configuration.yaml file "frontend: true"
But when I try to access on port 8080 I get message site not available. I use the same adress as my domoticz but change the port at the end in 8080
Zigbee2mqtt web based front end
jf2020
Re: Zigbee2mqtt web based front end
Not sure what you are doing but the plugin web interface is directly accessible from the custom tab of the main Domoticz interface.
- Xenomes
- Domoticz version: 2025.2
By frontend: in the config you need these three values.
restart the service.
frontend:
port: 8080
host: 192.168.1.*
auth_token: PasswordHP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
This is what I now have in my Domoticz under the custom tab
But I thought there was also a Zigbee2mqtt front end like this
I also tried this but nothing happen
frontend:
port: 8080
host: 192.168.1.*
frontend:
port: 8080
host: 192.168.1.*
- Domoticz version: 2025.1
See https://www.zigbee2mqtt.io/guide/config ... ntend.html
but port 8080 could conflict with your domoticz User interface that defaults on the same port 8080
My domocticz port :8084waltervl wrote: Wednesday 22 June 2022 14:07 See https://www.zigbee2mqtt.io/guide/config ... ntend.html
Front end I used :8085
But doesn't matter which port I choose it is alwasy saying can't reach page
- Xenomes
did you change the * to your ip and password?Platte73 wrote: Wednesday 22 June 2022 13:48 I also tried this but nothing happen
frontend:
port: 8080
host: 192.168.1.*
It is working now.
I had the docker container in bridge mode instead of Host. Changed it and now it's working
Thanks for all the support
