help for telegram silent with python
david31
Domoticz version: 3.8153
Post by david31 »
Hello
I would like to send a silent message with python.
With LUA on domoticz, it's working fine.
but not in python ...
def send_mqtt_publish(topic, data):
        data_mqtt = json.dumps(data)
        mqttc.publish(topic, data)
def on_connect(client, userdata, flags, rc):
        mqttc.connected_flag=True
        mqttc.subscribe(MQTT_TOPIC_IN)
        mqttc.subscribe(MQTT_TOPIC_OUT)
mqttc = mqtt.Client()
mqttc.on_connect = on_connect
mqttc.connected_flag=False
mqttc.connect("127.0.0.1", 1883, 60)
mqttc.loop_start()
send_mqtt_publish(MQTT_TOPIC_IN, '{\"command\": \"sendnotification\", \"subject\": \"Alarme\", \"body\": \"Probleme arrosage, intervention immediate\", \"Priority\": -1}')
time.sleep(time_disconnect_mqtt)
mqttc.disconnect()
sys.exit(0)
The flag priority not work ... message have always a sound ...
Sorry for my bad english
Re: help for telegram silent with python
what does the log file say? Can it read -1 ? Perhaps try
\"Priority\": \"-1\"}
david31
Post by david31 »
On log file, none error
I have tested, not working ...
According wiki:
"priority": 0 }
So not: Priority (case sensitive)
jvdz
Domoticz version: 4.107
Post by jvdz »
Try using lowercase for priority:
send_mqtt_publish(MQTT_TOPIC_IN, '{\"command\": \"sendnotification\", \"subject\": \"Alarme\", \"body\": \"Probleme arrosage, intervention immediate\", \"priority\": -1}')
ps: Which version are you running?
david31
Post by david31 »
Los case, same problem
Version: 2022.1
Build Hash: c9526851b
Compile Date: 2022-01-31 09:34:32
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
jvdz
Post by jvdz »
Ok ... Show me the LUA script that is working so I understand what you are doing. :)
(but the parameters in MQTT need to be lowercase!)
{"command": "sendnotification",
"idx": idx,
"name": "Some name",
"subsystem": "target subsystems"
"subject": "Message Subject",
"body": "Message Body",
"extradata": "extradata"
"priority": priority,
"sound": "mysound",
"brfromnotification": "brfromnotificationdata" }
david31
Post by david31 »
It's working
send_mqtt_publish(MQTT_TOPIC_IN, '{\"command\": \"sendnotification\", \"subject\": \"Alarme\", \"priority\": -1, \"body\": \"Probleme arrosage, intervention immediate\"}')
low case priority and after subject only
Thanks for all
jvdz
Post by jvdz »
Do you mean you need to define the priority After the subject field?
This is also working fine for me:
{"command": "sendnotification", "subsystems": "telegram" ,"priority": -1, "subject": "Alarm", "body": "Test, message2"}
david31
Post by david31 »
If priority is lastest, not work for me ...
Work somewhere
The message is receive all cases
jvdz
Post by jvdz »
Works for me anywhere I place "priority" and that is what is expected as the JSON is translated into an Object with and you address them through their keywords. SO as long as the JSON is coded correctly things should work irrelevant the sequence of these keywords. ;)
