why does this simple script fail???
Posted: Friday 20 May 2022 19:12
by tiga
i am writing a script that needs to update 2 text devices with some energy values but it wont work.
so i wrote this simple test script and it fails allso.
commandArray['UpdateDevice'] = 7705 ..'|0|'.. "why does it"
commandArray['UpdateDevice'] = 7704 ..'|0|'.. "not work?"
i run it on a time base.
but it only updates the second commandArray and skips the first.
how can i fix this?
Re: why does this simple script fail???
Posted: Friday 20 May 2022 20:25
by jvdz
tiga wrote: Friday 20 May 2022 19:12
Makes sense as LUA returns a Array variable (commandArray) and you are using the same key in the array so your array only contains one entry.... the last one.
Guess something like this will work.
commandArray[7705] = 7705 ..'|0|'.. "why does it"
commandArray[7704] = 7704 ..'|0|'.. "not work?"
Posted: Friday 20 May 2022 21:06
by tiga
this does not work.i get an error on this script
Posted: Friday 20 May 2022 21:14
by tiga
maybe this makes more sense...this is the part of the origional script i am making that is going wrong.
it only updates the 7704 text device.
if stroomverschil > 0 then
commandArray['UpdateDevice'] = 7705 ..'|0|'..stroomverschil.. " kWh over "
if stroomverschil < 0 then
commandArray['UpdateDevice'] = 7705 ..'|0|'..-stroomverschil.. " kWh tekort "
gas_nu = Round(gas_nu/1000, 0)
gas_verbruikt = gas_nu - gas_1jan
if gas_verbruikt > 0 then
commandArray['UpdateDevice'] = 7704 ..'|0|'..gas_verbruikt.. " m3h "
Posted: Friday 20 May 2022 21:33
by jvdz
Yes that makes it clearer, and sorry about the missing updatedevice part previously.
try this version to allow for multiple UpdateDevice commands:
commandArray['7705'] = { ['UpdateDevice'] = 7705 ..'|0|'..stroomverschil.. " kWh over " }
commandArray['7705'] = { ['UpdateDevice'] = 7705 ..'|0|'..-stroomverschil.. " kWh tekort " }
commandArray['7704'] = { ['UpdateDevice'] = 7704 ..'|0|'..gas_verbruikt.. " m3h " }
Jos
Posted: Friday 20 May 2022 21:47
by tiga
it does not update either devce.
for the sake of testing i include a print command like this
print('regel 44')
print('regel 49')
print('regel 57')
in the log regel 44 and regel 57 are showing up but no updates on the devices 7705 or 7704
Posted: Friday 20 May 2022 21:56
by jvdz
You do have the line "return commandArray" at the end?
Posted: Friday 20 May 2022 21:58
by tiga
yes it is in there at the bottom
Posted: Friday 20 May 2022 22:03
by jvdz
.. or else try this version :
commandArray[#commandArray + 1] = { ['UpdateDevice'] = 7705 ..'|0|'..stroomverschil.. " kWh over " }
commandArray[#commandArray + 1] = { ['UpdateDevice'] = 7705 ..'|0|'..-stroomverschil.. " kWh tekort " }
commandArray[#commandArray + 1] = { ['UpdateDevice'] = 7704 ..'|0|'..gas_verbruikt.. " m3h " }
Posted: Friday 20 May 2022 22:08
by tiga
i dont know why my version does not work but this version of you works!!
thank you Jos!!
