why does this simple script fail???
tiga
Post by tiga »
i am writing a script that needs to update 2 text devices with some energy values but it wont work.
so i wrote this simple test script and it fails allso.
commandArray['UpdateDevice'] = 7705 ..'|0|'.. "why does it"
commandArray['UpdateDevice'] = 7704 ..'|0|'.. "not work?"
i run it on a time base.
but it only updates the second commandArray and skips the first.
how can i fix this?
jvdz
Domoticz version: 4.107
Re: why does this simple script fail???
Post by jvdz »
tiga wrote: Friday 20 May 2022 19:12 but it only updates the second commandArray and skips the first.
Makes sense as LUA returns a Array variable (commandArray) and you are using the same key in the array so your array only contains one entry.... the last one. :)
Guess something like this will work.
commandArray[7705] = 7705 ..'|0|'.. "why does it"
commandArray[7704] = 7704 ..'|0|'.. "not work?"
tiga
Post by tiga »
this does not work.i get an error on this script
tiga
Post by tiga »
maybe this makes more sense...this is the part of the origional script i am making that is going wrong.
it only updates the 7704 text device.
if stroomverschil > 0 then
    commandArray['UpdateDevice'] = 7705 ..'|0|'..stroomverschil.. " kWh over "
if stroomverschil < 0 then
    commandArray['UpdateDevice'] = 7705 ..'|0|'..-stroomverschil.. " kWh tekort "
gas_nu = Round(gas_nu/1000, 0)
gas_verbruikt = gas_nu - gas_1jan
if gas_verbruikt > 0 then
commandArray['UpdateDevice'] = 7704 ..'|0|'..gas_verbruikt.. " m3h "
jvdz
Post by jvdz »
Yes that makes it clearer, and sorry about the missing updatedevice part previously.
try this version to allow for multiple UpdateDevice commands:
	commandArray['7705'] = { ['UpdateDevice'] = 7705 ..'|0|'..stroomverschil.. " kWh over " }
	commandArray['7705'] = { ['UpdateDevice'] = 7705 ..'|0|'..-stroomverschil.. " kWh tekort " }
	commandArray['7704'] = { ['UpdateDevice'] = 7704 ..'|0|'..gas_verbruikt.. " m3h " }
Jos :)
tiga
Post by tiga »
it does not update either devce.
for the sake of testing i include a print command like this
    print('regel 44')
    print('regel 49')
    print('regel 57')
in the log regel 44 and regel 57 are showing up but no updates on the devices 7705 or 7704
jvdz
Post by jvdz »
You do have the line "return commandArray" at the end?
tiga
Post by tiga »
yes it is in there at the bottom
jvdz
Post by jvdz »
.. or else try this version :
	commandArray[#commandArray + 1] = { ['UpdateDevice'] = 7705 ..'|0|'..stroomverschil.. " kWh over " }
	commandArray[#commandArray + 1] = { ['UpdateDevice'] = 7705 ..'|0|'..-stroomverschil.. " kWh tekort " }
	commandArray[#commandArray + 1] = { ['UpdateDevice'] = 7704 ..'|0|'..gas_verbruikt.. " m3h " }
tiga
Post by tiga »
i dont know why my version does not work but this version of you works!!
thank you Jos!!
