MQTT AD: WSDCGQ11LM temp + hum only
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
I was planning to migrate the Z2M plugin to the native MQTT AD plugin. The only thing that seems to be different is the selector switch for buttons is swapped with multiple action devices, but that's not a problem.
The other thing that seems to be different is the devices that get created for temperature devices (eg. WSDCGQ11LM). MQTT AD creates a temp+hum+bar device, while the Z2M plugin creates multiple (temp, hum, bar, temp+hum and temp+hum+bar). I don't need the barometer info as it shows info like "comfortable/normal" and predictions which I don't like. Is there a possibility or workaround to let the MQTT AD plugin create a temp+hum device too?
jenssen
Domoticz version: stable
Re: MQTT AD: WSDCGQ11LM temp + hum only
Post by jenssen »
Same problem here, WSDCGQ11LM only recognized as barometer when adding it to Domoticz, however the temp and humidity is shown at the data column when you click on device overview.
You can read the data from the sensor with http://IPADRESS/json.htm?type=devices&rid=IDX
