closed] getting value of watercounter
BartSr
- Domoticz version: V2024.7
I am having an working incremental counter which monitors the water consumption
Daily consumption is shown as 0,191m3 whereas total shows 939.995m3.
So far so good.
Now I like to see these values in a lua script.
I am not good using lua so I will do step by step (goal is to create daily file with time interval of e.g.10 minutes)
In lua I coded:
print(otherdevices_svalues['watermeter'])
Now I get this in logfile:
2022-05-18 23:22:04.412 Status: LUA: 18446744073709379679
What does this show while looking at 0,191m3 and 939.995 m3?
TIA for your help
-Bart
So far so good.
In lua I coded:
TIA for your help
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2026.3
Re: getting value of watercounter
If you are not good at LUA better learn DzVents as there it is just very easy to get it.
In LUA it seems not possible (please someone correct me if wrong). See also
viewtopic.php?p=282202
Toulon7559
- Domoticz version: <2025
Please publish the complete lua-script, enabling the forum to see whether the declaration of values is correct.
Publishing is easiest if you set the code-markers and then copy the script-text inbetween those 2 markers, as shown below.
If the script is long, use spoiler to set the markers: then the view is small, but contents can easily be called.
text of scriptSet1 = RPI-Zero+RFXCom433+S0PCM+Shield for BMP180/DS18B20/RS485+DDS238-1ZNs
BartSr
Here we go; as said I am going step by step. So 1st step is : how to get the value of a device
if I want to see a tempvalue I do:
(I find expected tempvalue in logfile)
So as shown here
It seems to be impossible to catch a counters'value. This is weird for me.
Any suggestion?
TIA
-Bart
local a
print ("watermeter")
a = otherdevices_svalues['watermeter']
print (a)
return commandArrayif I want to see a tempvalue I do:
local a
a = otherdevices_svalues['Vv trapgat aanvoer']
print (a)
Any suggestion?
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
@Watervl:
I.ve been programming databases for years using procedural code as well as OOP.
For me LUA is closest to those.
DzVents is very steep learning curve for me.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Nobody who has an advise?
KR
-Bart
KR
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- RonkA
- Domoticz version: 2025.1
print(otherdevices_svalues['watermeter']) gave you 2022-05-18 23:22:04.412 Status: LUA: 18446744073709379679
Is the status output a constant number or is it changing?
Also in your latter post it states /a = otherdevices_svalues['Vv trapgat aanvoer']/ that looks to me not relevant to the counter..
Grt Ron.
Grt Ron.
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
BartSr
Hi Ron,
I did not check for some time but currently it sents: 18446744073709369520
So there is a change.
KR
-Bart
KR
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- RonkA
Im NOT a educated person in programming but i like tinkering,
You didn't disclose the type of meter, maybe a manual wil give some clarity?
It could be there are more values beeng delivered like 2 or more.. like P1data gives out 6 values.
I have a script thats getting 2 values out of a solarmeter device, maybe this could get other values out of your meter
solar_p is getting the current power and solar _e is the day couter,.
Modify and try i would say..
solar_p, solar_e = otherdevices_svalues[solarmeter]:match("([^;]+);([^;]+)")Modify and try i would say..
BartSr
Thanks fro your help Ron, but the problem is that what I am measuring is just counting the number of rotations of the watermeter.
That gives correct indication in Domoticz. But when I want to retrieve the value, as shown by Domoticz as a scriptvalue the weird data is received.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
