Tuya TS0042 Topic is solved
julienb
Tuya TS0042
Post by julienb »
I'm currently in the process of setting up a domoticz home, using zigbee devices, raspberry pi 3, debian buster, zigate+ and zigate plugin. I have successfully paired several devices (mostly lidl home devices). Now i'm trying to control everything via physical switches, instead of clicking on domoticz ui buttons. So, i bought a Moe's two-button scene switch, which appears to be a Tuya TS0042.
I have paired it fine, and both buttons are recognized. I have click, double click and long click working correctly. However, i struggle to understand how to put it back to "OFF" position. Clicking on the OFF button in domoticz does not yield any result, and gives the following in the logs :
2022-05-13 13:16:58,384 INFO    : [       MainThread] mgtCommand - You are trying to action not allowed for Device: Inter cuisine 1 Type: [('01', '26', 'Button_3')] and DeviceType: Button_3 Command: Off Level:0
First question: is this expected ?
Second question: the idea is to use it as a toggle switch : 1 click toggle light status, next click, toggle again. Is this possible ? (currently, i need to double click to get a click event again). I can't find the module in blockly, did not try yet with dzvents, but obviously i am missing something.
Thanks for your help.
pipiche
Re: Tuya TS0042
Post by pipiche »
You might have a look to the WebUI > Settings > Advanced
In the Devices Management settings,
you can enable "forcePassiveWidget" this will allow you to be able to action the Widgets itself.
you can also set the "Number of sec after the Selector is reset to Off" to a value different than 0 to get the switch back to Off.
For the scripting I leave to other specialists which probably can help you. I think in dzVents there is a way to toggle the state of a widget
julienb
Re: Tuya TS0042
Post by julienb »
This is exactly what i was looking for (and would never have found), this works fine, thanks.
For the missing module in blockly, it looks like it was a refresh issue, everything works fine, and also with dzVents.
glory50
Domoticz version: 2022.1
Re: Tuya TS0042
Post by glory50 »
I have the same problem but in the WebUI of my Zigate, there is no "forcePassiveWidget" paramter neither "Advanced" section.
Plugin 6.3.008, fw 320
pipiche
Re: Tuya TS0042
Post by pipiche »
This as been Named into 'Allow Domoticz actions on Widgets fromremote devices'
glory50
Re: Tuya TS0042
Post by glory50 »
As you see from my posts' screenshot, it is enabled. I made a longer description here:
viewtopic.php?t=39717
