Hi there,
I'd like to show the sunrise and sunset time that is shown e.g. on the dashboard or in the settings in in a virtual device. I've tried to calculate the time out of sunriseInMinutes but it results in a diferent time than in domoticz. I assume it is because of the location I've set in domoticz.
Thx for any hints,
Zavjah
[SOLVED] Get sunrise and sunset time from domoticz
- Domoticz version: V2022.1
Re: Get sunrise and sunset time from domoticz
Is this where you are looking for?
Where you need to devices (Sunset and Sunrise)
Found the code on the forum, all credits to Waaren (viewtopic.php?t=26677)
Or have a look on this link, a lot of time options
viewtopic.php?f=72&t=28103
-- dzVents version >= 2.4.7
timer = { "at 00:03", "at 06:03" }, -- twice a day to be sure and 3 min past the hour because at the hour already quite busy
execute = function( dz )
local function minutes2time(minutes) -- integer in; string out
local hour = string.format("%02d",math.floor(minutes / 60))
local minutes = string.format("%02d",minutes - (hour * 60))
return (hour .. ":" .. minutes) -- string out
dz.devices("Sunset").updateText("Sunset: " .. minutes2time(dz.time.sunsetInMinutes).. "\nCivil twilight end: " .. minutes2time(dz.time.civTwilightEndInMinutes or "-"))
dz.devices("Sunrise").updateText("Sunrise: ".. minutes2time(dz.time.sunriseInMinutes).. "\nCivil twilight start: " .. minutes2time(dz.time.civTwilightStartInMinutes or "-"))
Hi there,
thx hoeby, thx waaren, that's exactly what I was looking for. It seems my converion of minutes into hours was wrong, that's why i got different times than shown on dashboard.
Cheers,
zavjah
Cheers,
zavjah
- Treve
- Domoticz version: v4.11474
Re: [SOLVED] Get sunrise and sunset time from domoticz
FYI, Waaren is not with us anymore. He past away.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
