HIKVISION AX PRO ALARM PANEL
ftsikogi
Domoticz version: 2022.1
Post by ftsikogi »
I am the owner of a new Hikvision AX Pro Alarm Panel. I would like Domoticz to act as an Alarm Receiving Center (ARC) using l SIA or any other compatible protocol. Is there anyone that knows how to do it? I am running the latest Domoticz version on Raspbery PI.
Domoticz version: 2025.1
Re: HIKVISION AX PRO ALARM PANEL
Perhaps the jablotron alarm (SIA) plugin is compatible?
viewtopic.php?t=36386
ftsikogi
Post by ftsikogi »
Tried this but i had no success. The alarm panel "talks" to the plugin because i get a notification from the alarm system but no new devices are created.
You could try to contact the plugin author through github for some extra information.
ftsikogi
Post by ftsikogi »
i will try it. Thanks
You could also try to modify the python script that was mentioned in the same topic to your own situation.
ftsikogi
Post by ftsikogi »
i am not a python expert so it is not easy for me but i will give it a try
